This is the only major rust damage on my car. It in the floor just forward of the seat. Passenger side is similar. This will be my first poll. Untitled by Travis Brown, on Flickr This was under the tag. Untitled by Travis Brown, on Flickr by Travis Brown, on Flickr As you can see the 49-50 pan is nothing like the 1951 stamping. If you could imagine a cut line through the "EMS Automotive", that's about all of the patch I would use. Another option is just replacing the whole pan but, that just seems excessive to me. The inner and outer rockers are excellent. The floor braces are also in excellent shape as well. The rust out is just in the floor pan. My brother has an equipped shop with a plasma cutter and various welders. He has just finished rebuilding the floors on a 65 fastback. I can get with him and arrange a time to get the Ford over there in a few months. In the mean time I can fabricate my patches. My idea on patches is to use poster board for a template and pound out a close mimic of the factory stamps. I might try do some type of jig. How would you fix this?
How about making a wooden hammerform to make new ones? Say, two layers of plywood with cutouts in one where you want the channels etc. pressed into the metal. https://www.jalopyjournal.com/forum/threads/hammer-form-material.1003933/#post-11325111
I’d just use a bead roller to replicate the needed shape on some fresh steel and weld it in. It’s wise to fully clean the rust off before making the replacement, so you don’t end up needing to make it bigger.
I would expect the amount of sheet metal that is going to need to be replaced is larger then you are expecting. You have to get to good enough metal to weld to, if there are pin holes nearby, the area with the pin holes also needs to be replaced. I'd be making arrangements with your brother to get it into his shop, pull the seats out, and replace anything that may be questionable. Then, next year you won't be asking about a different place that has rusted out. If the replacement floor pans do not match up with what you have, making pans out of the 19 gauge sheet metal is a better plan then buying something that doesn't fit. Beads add strength to flat sheet metal, but not everyone has a bead roller, or a place to keep one. Beads can be formed by hammering along the sides of round bar stock. Gene
I have the same issue, but only on the passenger. I found this website. http://bradleyfloorpans.com/49-51.0.html I may just make mine though when I finally get to it. Listen to others and clean up what you have so you know what to replace. CN
EMS is way expensive. Fab our own.....it's really not that difficult. I did the floors on my '54. A cheap HF bead roller, HF brake and MIG welder is all you'll need. Pull the interior and sandblast the floors to see how much metal you need to replace. I used some poster board to form a template on mine...... Cut out the offending cancer......... I made the tunnel transition with my vise and a 3" pipe............ My better half helped me form the stiffening ribs........ Tacked it in place............ Finish welded it and ground down the beads...........done!
