Technical Pantograph doors.
Discussion in 'Traditional Customs' started by CadMad, Nov 1, 2015.
  1. banjeaux bob
    banjeaux bob
    from alaska
    190295713_5466517456755084_8375854905403484585_n.jpg 1932 Bugatti Type 46 by Uhlik with sliding doors.
    Hnstray, stanlow69, mgtstumpy and 8 others like this.
  2. SR100
    SR100
    Here's the Uhlik 46 with the doors closed:
    Here it is with its owner, Prince Lobkowicz:
    This leads me to a question: The car has tremendous rear access with the doors forward, but little front seat access. In this pic, the interior handles are on the front, where it would be harder to reach to close the doors. Does that mean that the doors also slide to the rear for front seat ingress/egress? I couldn't find a pic with the doors to the rear, so I can't prove it, but I suspect so.
  3. Ned Ludd
    Ned Ludd
    If they did it would be extremely clever, providing optimal front and rear access through the same doors. I spotted it too: I'd have a lot of trouble getting into the front seats if the doors only slid forwards.
  4. Magfiend
    Magfiend
    Maybe the front seats slide back for access...
    Hnstray and banjeaux bob like this.
  5. 296moon
    296moon
    from england
    I would think that the doors also piviot suicside style...............................
  6. chrisp
    chrisp
    With the rail and wheels contraption at the bottom I can only see it slide forward. To stabilize the door there is probably a similar contraption around the belt line sliding in the cowl or door.
    I can't see this system sliding forward and backward unless the upper rail was in the roof which doesn't appear to be.
    Access is probably not the best but probably not that bad either, when you open non suicide doors you never get close to the front jamb.
    If it was never replicated there's probably a good reason for that.
    I think walking to the front of the car to slide it open is less convenient than sliding it to the rear, it's a much more natural movement to enter the car, you end up standing in the doorway not in front of the front fender or door.
  7. birdman1
    birdman1
    Like a sliding patio door
  8. banjeaux bob
    banjeaux bob
    from alaska
    Even at that I would find there is little leg room from the back of the front seat to the pedals. Unless the seat is slid all the way forward.
  9. banjeaux bob
    banjeaux bob
    from alaska
    190295713_5466517456755084_8375854905403484585_n (1).jpg Uhlik_12web.jpg ...and speaking of sliding doors, did you notice the door to the shop slides open like a barn door? Even has a man door.
  10. stanlow69
    stanlow69
    No harder getting in the car with the door open than getting in the building threw the door with the brick structure right against the door. But maybe it`s me, the door on the drivers side looks a bit shorter. Look at where the wing window would be and the distance on both sides. Look at the grille, not much of a side view angle. Then look at the rear cabin area. Has a bit more space(angle) on the drivers side compared to the passengers side. Look at the difference in size of the window openings with the doors shut.
  11. CadMad
    CadMad
  12. SR100
    SR100
    Unless the door could pivot at any point along its track, it wouldn’t help much. With the door fully slid forward, it would pivot right at the front of the seat, leaving no room to entry.
    I don’t think that there’s room in the cowl for a support similar to the one in the sill. If a second rail is in the middle of the door, it’d have to be something like the sill track, only mounted in the A pillar and pointed rearwards. Since the windows roll down, fitting that would be a remarkable piece of engineering.
    Good eye on the upper rail. An upper rail in the roof would be technically possible if it were attached at the rear of the door and had a ’U’ shaped hinge/roller, but that would preclude it sliding to the rear. Taking another look at the pic, I noticed that there is no latch in the B pillar. Wouldn’t one be necessary for the door to go both directions?
    I’d imagine that access is worse than you think. When you open a standard door, you have a couple of feet between the door and the seat. The Uhlik design leaves you maybe eight inches.
    There could be any number of reasons it was a one-off. Patents, rebodied shortly after completion, not seen outside of Czechoslovakia, it’s owner died just a few months after taking delivery, engineering issues, etc. One of the questions that might clarify things is: How did the original owner intend to use it? As a daily driver, the engineering would be paramount, but a concours queen only needed to be novel and stylish. It would only need to be driven a few miles. Concours cars were often rebodied after a single showing.
    I think that’s an optical illusion caused by the angle that the picture was taken.
  13. chrisp
    chrisp
    It looks like there are 2, maybe 3 receptacles for locating pins in the B post, so that would require just the front latch. If the windows are operated with a pull strap, you have plenty of room for your sliding mechanism.
  14. stanlow69
    stanlow69
    What, hard getting in the car or hard getting in the Building.
  15. CadMad
    CadMad
    You guys are overthinking it. I have to say the Bugatti probably overthought it too.
    In any event it is less of a pantograph than a sliding track not unlike most commercial vans.
    The Hispano by Saoutchik is what I emulated and it works great. Access is good too.
    Hnstray likes this.
  16. SR100
    SR100
    Neither. I was talking about the rest of your post. Sorry, I meant to snip the quote to make it clear:
    "…the door on the drivers side looks a bit shorter. Look at where the wing window would be and the distance on both sides. Look at the grille, not much of a side view angle. Then look at the rear cabin area. Has a bit more space(angle) on the drivers side compared to the passengers side. Look at the difference in size of the window openings with the doors shut."
    I think that is caused by the camera angle.
  17. banjeaux bob
    banjeaux bob
    from alaska
  18. JimSibley
    JimSibley
    This is what hot rodding , especially custom hot rodding is all about! I love it. Here is my take on unique entrance options for my hot rod.keep up
    The odd work! 8799FCE6-14CC-4A8F-8411-B5E2D6DEC190.jpeg 96A6E219-2160-4A7C-B391-CAA1A2BF777F.jpeg 1FC57D01-F39B-4FA6-B145-8B2C15CB95D0.jpeg 0734BBFB-CE66-40D6-A233-BAB187EB6923.jpeg
  19. SR100
    SR100
    I was familiar with the Mohs SafariKar, but I had never seen a pic with the doors open. I didn't know the doors were pantograph. Mohs made three, so if you missed this one, you may still have an opportunity. The wild thing is that this is his most normal car. The Mohs Ostentatienne Opera Sedan and the UFO are, sadly, wayyy OT, so I can't post pics. Look them up at your own risk. :rolleyes:
    Hnstray likes this.
  20. CadMad
    CadMad
  21. banjeaux bob
    banjeaux bob
    from alaska
    pantograph doors start about 3 minutes in...
    mgtstumpy, Stogy and kidcampbell71 like this.
  22. CadMad
    CadMad
    682EA534-0835-4E64-BBC5-506650DFCB27.jpeg Thanks for that link. I’d seen this 39 Delage in pics but not this video. Good one.
    Exactly the formulas I used to create the Packard.
    That collection is something else. I’ll know I’ve made it when I have a curator and white floors.
    Now got to decide if I want the side pipes on the RH side. Will have to wait till I get an engine in it to see where the manifold sits. I’ve got some flex pipe in the rack just in case.
    I found these pics of Auburn pipes for reference.
    mgtstumpy, Hnstray and The37Kid like this.
  23. The37Kid
    The37Kid
    Thanks Bob! The Rich collection has some great cars, thanks for the link. Happy New Year!
    Bob
    banjeaux bob likes this.
  24. banjeaux bob
    banjeaux bob
    from alaska
    Bob, you're a Bugatti guy. This is about the Shakspeare cars and their current disposition.
    sorry guys this isn't about pantograph doors.
    mgtstumpy likes this.
  25. The37Kid
    The37Kid
    Thank You Bob. I saw one of the Type 57's at the Gooding auction at Pebble Beach this past August. Nothing had changed, maybe more parts were missing from the unrestored car. It sold for over $200,000, a bargain in the Bugatti world of today. Happy New Year everyone!
    Bob
