Projects Project 29 Phaeton
Discussion in 'The Hokey Ass Message Board' started by 340HilbornDuster, Jan 29, 2013.
  1. loudbang
    Ok got you that is the back of the second plug. :confused:
    brady1929 and Stogy like this.
  2. 340HilbornDuster
    340HilbornDuster
    Soon ... Tub time...
    "Some" Wiring design...(have to fix our computer) .... time frame. ????
    Sent from my SM-G930T using The H.A.M.B. mobile app
    Stogy, USMercUte, 1-SHOT and 2 others like this.
  3. 1-SHOT
    1-SHOT
    from Denton
    Looks like you used a chain saw to cut the wires.
    Stogy and loudbang like this.
  4. 340HilbornDuster
    340HilbornDuster
    (Spider) Hairy Picture!...forgot I posted that!....Chainsaw?...Pretty much...
    2 center pins (9 & 10) was soldered together...Needed all 19 circuits!
    Lesson learned again = Use a Soldering gun with a fine point and Lots of Heat...
    I had to heat the tip with a Propane torch...
    Stogy, loudbang and AndersF like this.
  5. nunattax
    nunattax
    from IRELAND
    possible cause bad /low quality solder.when I got some proper stuff my job became much easier
    Stogy likes this.
  6. 340HilbornDuster
    340HilbornDuster
    Hi Nunattax....
    That's a Good Point Man!...didn't cross my mind!
    What's the brand/type of Proper Stuff Solder You Got?
    loudbang and Stogy like this.
  7. nunattax
    nunattax
    from IRELAND
    I started out tring to work with DRAPER brand it was crap.my electric guy gave me 2ft of good stuff..a quality roll was e40 for about 100ft of it.when I would only use a foot or 2.
  8. 340HilbornDuster
    340HilbornDuster
    USMercUte, Stogy, brEad and 5 others like this.
  9. 340HilbornDuster
    340HilbornDuster
    "moved out for a while" ...my last words...(1 year ago!)
    Vaja con dios Duster... 20200731_202716.jpeg 20200731_191222.jpeg 20200802_101257.jpeg
    Sent from my SM-G960U using The H.A.M.B. mobile app
    Stogy, brEad, loudbang and 1 other person like this.
  10. Stogy
    Stogy
    How's that Tub coming along 340? It's looking good...The Wires and Tires look aces on it...you have to have went around the block a few times with maximum motor sounds a blazin'...
    brady1929, patmanta and loudbang like this.
  11. 340HilbornDuster
    340HilbornDuster
    Hi Stogy...thanks for checking in Man...
    I haven't been on The HAMB for a while now...
    Been working on the Truck and Life's "Curve Balls"...
    I just finished the wiring diagram...(I was out of computer for a while & I have to draw it to wire it right!)
    Includes some diodes (hoping to prevent frying the Brain in "Ol'Smokey" again)
    [external]
    [internal]
    Going to build me a hitch so I can tow it easily back and forth to the garage and get the wiring done...
    (Almost there)
    Remember when I cut out the Crap Relays with the wiring nightmare?
    New Fuse / Relay Box - Almost done ~ a year ago...time to finish and drive it this summer.
    Again thanks for the "Kick" Stooge!
    Stogy, Algoma56, brEad and 5 others like this.
  12. 340HilbornDuster
    340HilbornDuster
    OahuEli, Dean Lowe, brEad and 7 others like this.
  13. 340HilbornDuster
    340HilbornDuster
    OahuEli, brEad, kidcampbell71 and 5 others like this.
  14. 340HilbornDuster
    340HilbornDuster
    waiting for new electrical quick connector for the dash...
    Remembered these my byddy gave me...
    brEad, USMercUte, LAROKE and 5 others like this.
  15. Stogy
    Stogy
    @340HilbornDuster, I missed your update, good to see you back on it...truly you're honing in on the 4th quarter milestone...The truck looks fantastic and understandably handy too...
    I totally get life effecting things as well...;)
    brady1929 and loudbang like this.
  16. 340HilbornDuster
    340HilbornDuster
    I think this might be it...?....Perfect Prefect...
  17. Stogy
    Stogy
    Are you going to add metal underneath, ends and hinge on top to attach to a hood top and fair in the bottom to the frame?
    loudbang and brady1929 like this.
  18. 340HilbornDuster
    340HilbornDuster
    Probably add metal front and back...
    Solid base for a future Hood.
    I like the line that the louvers bring.
    I like the swoop below...and will try to Continue that line.
    I think it'll be hard tie in to the frame and make it look good though?
    I just found/ notched them yesterday ...
    We'll see - Get it running first!
  19. 340HilbornDuster
    340HilbornDuster
    Old dash switch wiring removed.
    New wiring with Quick Connectors when removing dash...
    Removed all the Plastic sleeves on crimps and use shrink hose instead...Much cleaner! Used Shrink hose over terminals too!
    Stogy, patmanta, LAROKE and 3 others like this.
  20. 340HilbornDuster
    340HilbornDuster
    Almost there....Cleaned and Organized...The Quick Connectors makes it workable!
    Soon!...(Snart så Djävlar blir det åka av....)
    - Change Oil in Trans & Engine
    - Test the Breaks...
    - Check for Leaks
    - Finish Gas Pedal install
    - Torque the Bone Joint Bolts and Lock (And check all other bolts in the car)
    - And probably ~10 other things I'll find
    And then...(to start the inspection process)
    - Line up / bolt on the Upper Cowl.
    - Fix the windshield stanchion brackets
    - "Put" the windsheild in/on
    - Shop the Seats.
    - Install Seat Belts.
    - Install Windshield wiper
    Dean Lowe, brEad, patmanta and 6 others like this.
  21. AndersF
    AndersF
    Cool. Nice to see you working on it again.
    Its a damn cool hotrod.
    340HilbornDuster, loudbang and Stogy like this.
  22. 340HilbornDuster
    340HilbornDuster
    Man Tackar.!...Thank You Sir!
    Like Your Footer - True That!
  23. 1-SHOT
    1-SHOT
    from Denton
    Where did you buy the wiring sleeve to run the wires in? Thanks Frank
  24. 340HilbornDuster
    340HilbornDuster
    E-Bay somewhere (long time ago) ..search for "Braided PET Expandable Sleeve "
  25. 1-SHOT
    1-SHOT
    from Denton
    Thanks
  26. 340HilbornDuster
    340HilbornDuster
    2 main termination blocks wired up...
    Bolted up...
    The wires "kinda" disappears. After some tie wrap dress-up it should be pretty neat...at least compared to before...?
    - EFI Computer & Ignition pretty much done (Load the Software on my new laptop & Remember how to hook it up...I think I switched to BlueTooth receiver last time...or was it 9pin to USB?)
    B4 (Old Historic Picture)
    patmanta, brEad, LAROKE and 3 others like this.
  27. 340HilbornDuster
    340HilbornDuster
    Panorama Picture....(Lotso Crap in a small place...)
    Dash Connectors works Great!
    Stogy, patmanta, brEad and 4 others like this.
  28. 340HilbornDuster
    340HilbornDuster
    CHASING GHOSTS!...
    I had all the wiring working...after i figured out that the large dash connector was "reversible" (even though it has 2 index tabs)
    ...that's another story...
    I installed the Cowl Top Panel...(to figure out by windshield stantions).....NO MORE POWER!...DEAD!
    I blew a 30A glass fuse in the back...Couldn't see nay pinched wire anywhere...took it back off.
    Must have touched the power connection to the relay box...(Insulated it)
    I put in 2 fuse holders in the back (one spare / Spare fuse holder)
    Put the spare in (blew right away!!)..or so i thought...Measured it - OPEN!
    But it looks perfect...
    Removed feed wire - had weird up and down numbers to ground...when wiggling the wire..?
    Open up the harness / covers...nothing wrong!?
    The Ghost - Spare Fuse was Bad from the factory...
    Stogy, kidcampbell71, OahuEli and 3 others like this.
  29. 340HilbornDuster
    340HilbornDuster
    What Else have I done...
    Chopped the Austin Seat frames...
    Also cut out the front seat back panel - will weld in some sheet metal
    20210828_182051 (Medium).jpg 20210828_184646 (Medium).jpg 20210828_190121 (Medium).jpg
    Much Better height
    Stogy, brEad, kidcampbell71 and 3 others like this.
  30. 340HilbornDuster
    340HilbornDuster
    Replacing all the fuel lines ... it's 45 PSI...
    Fuel pump was to high up...needed to move down to suck.
    Made a new bracket...out of an old garage door bracket...
    Are those switch nobs to "Cheasy"
    Nut and Bolt everything - and some tuning... 20210822_125537 (Medium) (1).jpg 20210822_125603 (Medium).jpg 20210822_184944_03 (Medium).jpg
    brEad, kidcampbell71, OahuEli and 5 others like this.
