Technical Shop safety and organization, Fire extinguishers
Discussion in 'The Hokey Ass Message Board' started by Roothawg, May 20, 2021.
  1. Roothawg
    Roothawg
    So, what are the sizes? Are the big ones 10#?
  2. squirrel
    yup, I've been wearing them for years. I have to wear safety glasses at the robotics meetings with the kids, and at the competitions, and these glasses let me see little things with my tired old eyes. I've found them at welding stores, and online at places like mcmaster carr, I expect amazon has a bunch of them for cheap if you like to shop there.
    And you can get prescription bifocal safety glasses, too....Walmart can get them for you reasonably priced.
    chryslerfan55 and Truck64 like this.
  3. Zax
    Zax
    1. 1952-59 Ford Social Group
    When I bought my current house there were about 10 fire extinguishers that came with the house. Most were old and out of date. But in a rare stroke of luck Kidde had a huge recall on their fire extinguishers and most of the ones I had were on the list. So I have the two big ones in the garage. One by the bench and one by the doors. Plus several more spread through the house.
    https://www.kidde.com/home-safety/en/us/support/product-alerts/recall-kidde-fire-extinguisher/
  4. Roothawg
    Roothawg
    Man, I feel like a slacker. I think I may have 2 total.
  5. squirrel
    I had about six that were on the list, and got new ones free to replace them. I don't think it's a rare stroke of luck to posses a bunch of defective fire extinguishers :)
  6. Truck64
    Truck64
    from Ioway
    Woah woah WOAH! Don't see a sign above each one of them that says "Fire Extinguisher".
    I mean, how else would anybody know that is a fire extinguisher? You're playin' with fire pal!
    Are they ADA compliant? Conform with 1910.157(c)(1) ?
    You have read, and understand 1910.157(c)(1) yes?
    Hm?
  7. Grandadeo
    Grandadeo
    Going to a local rod event this Saturday where everyone brings door prizes that are given out to the attendees. Think I'll pick up a fire extinguisher.
    Lee
  8. I Have a couple of dry powder extinguishers and also a CO2 type, just in case I have something "purdy" catch fire and I don't want to spend the next 2 years cleaning the powder crud off. Also, a fire blanket is handy in case of a garbage can fire, etc. I also have a blanket and dry extinguisher in the kitchen. A sheetmetal barrier on wheels saves sending grinding sparks across the workshop into a pile of flammable stuff, or worse, into the paint on my cars. Safety glasses for low speed stuff, face shield for anything else. My daughter is an Optometrist, and every few days tells me about what she dug out of some lazy slob's eye because they thought their eyes were swarf-proof.
  9. Truck64
    Truck64
    from Ioway
    There's a guy on another forum who has put out a few car fires for folks out on the side of the road with the extinguishers he carries in his car. He said they weren't particularly grateful or seemed to understood that extinguishers cost money. He got tired of that. Charity has its limits, eventually, I guess.
    So he made it his policy and started inquiring whether they would repay him for the cost of the extinguisher while running up to their fire. That seems to work better.
    "YES YES YES HELL YES PLEASE!!!!!"
  10. quickfarms
    quickfarms
    When the extinguishers are filled at the factory the powder contains no moisture, so if you never open or use the extinguisher there is no need to shake it.
    If you are subject to a jurisdiction that requires the extinguishers to be serviced and they actually open them and don’t just put a new tag on them then there is now moisture in there with the powder and they will now need to be shaken.
    If the gauge is in the green the extinguisher should be good.
    I have used many an old fire extinguishers and never had an issue. The last one was an old rusty one from the 70’s and it worked great, and was empty, no powder or valve, when it was tossed in the scrap metal.
    chryslerfan55, Roothawg and loudbang like this.
  11. Dedsoto
    Dedsoto
    from Australia
    1. Aussie HAMBers
    I use an old latch style fridge as my flammables cabinet, never been unfortunate enough to find out if it's effective though.
  12. spanners
    spanners
    One extinguisher I keep handy is a plain trigger squirt bottle full of water,like you'd put penetrating fluid or glass cleaner in. If something such as a rag or piece of paper or even my shirt sleeve starts smouldering while welding or grinding, a squirt of water quickly douses it without reaching for the big extinguisher.
  13. TCATTC
    TCATTC
    Commercially here in Georgia, the Fire Marshal requires us to have a minimum of 5lb ABC's no more than 50ft apart.
    Also they must be mounted no more than 36" above the floor for wheelchair access.
  14. Truck64
    Truck64
    from Ioway
    Is that Federal Law?
    A fire extinguisher weighing less than 40 pounds, like the extinguishers found in your home, should be hung so that the top is not more than five feet above the ground, but no lower than four inches above the floor, according to the National Fire Protection Association's Standard for portable fire extinguishers, NFPA-10.
    It makes more sense to require all wheelchairs to carry a fire extingisher. Nome sayin'?
    chryslerfan55, egads and Roothawg like this.
  15. Truck64
    Truck64
    from Ioway
    Why do they need to open them? Maybe Jimmy Hoffa is in there or somethin'?
    Elcohaulic and chryslerfan55 like this.
  16. MeanGene427
    MeanGene427
    from Napa
    In doing a lot of construction and demolition, I have been fortunate enough to "inherit" a lot of safety stuff, and most is very good quality. School demo/ refit is always good, they just toss everything (your tax dollars at work again). Many times at the end of a project, the job trailer gets cleaned out, and everything tossed. Many times stuff get tossed because a spec has changed, or a company changes suppliers. I have several NIB eye wash stations, big first aid station, and at least a dozen extinguishers, small and large, at the front and rear doors, easy to grab one and have it close. Got one of those rollaround truck inspection stairs that the gubmint left behind at an interstate scales we did a few yeas ago- works for my shelves. I haven't welded inside in years, my nice welding table on wheels has become a workbench- I have 50 amp outlets at the front and back doors with long extension cords, and another welding table by the back door. In front I just pull my dump trailer or tiltbed equipment trailer close to the door, they make great prep/welding tables. I would imagine that the requirement for refill and recert on extinguishers is directly related to the compaction of the powder- keep them loosened up and they seem to work fine
  17. I got an oily rag barrel after I came back into my garage after lunch and there was a half-consumed shop rag smouldering just inside the doorway. I'd been grinding before I left for lunch and didn't notice that I managed to shoot sparks from about 15 feet away.
    loudbang, chryslerfan55 and Roothawg like this.
  18. saltflats
    saltflats
    from Missouri
    One of those pump up sprayers with water could help with cost in some fire cases.
    loudbang and Roothawg like this.
  19. Almostdone
    Almostdone
    Lots of good info posted already. Here is my $0.02:
    Typically advisable to have an extinguisher for Class A (paper, wood combustibles. A.k.a things that leave an ash), B (petroleum products), and C (electrical) fires. They work on the most common fires.
    Dry chemical is the most common type to cover classes A, B, and C. They work well, but they do make a mess. Most of the time when there is a fire nobody cares about the mess, but you can come up with exceptions.
    Extinguishers are rated by the size of fire they can put out (in the proper hands). Larger extinguishers of course have more product in them and a higher rating for a given type (dry chemical, foam, or whatever), but they also have a greater application rate……. they squirt more for longer. You’ll like that if you need to use one.
    Common sizes of dry chemical extinguishers are 2.5, 5, and 10 lb. A 2.5 fits in the car nicely, a 5 lb might fit in a Lincoln, but not so much in a Model A, and a 10 lb is way too big for you car, unless you really want one. In a shop the 5 or 10 lb ones would be good.
    Your local fire department can help you with sizing and number if you want. The OSHA website probably has thatstuff too.
    Keep them near exits and perhaps near the areas you might logically have a fire.
    John
    Elcohaulic, loudbang, Truck64 and 3 others like this.
  20. Yep - fire extinguishers get an annual certification every year.....the larger type - also good to put one in your - show car or not !
  21. gimpyshotrods
    gimpyshotrods
    Just upped our service contract to include two Class D extinguishers, one at each end of the shop.
    We already have the legally required other ones, as well as sprinklers.
  22. Poverty cap
    Poverty cap
    I rented a old Body Shop in Minneapolis in the 1980’s eventually the fire Marshall came around and wanted to look at my paint storage area. I had gutted a old bathroom and used a paint room, the fire Marshall wanted me to vent it which was cost prohibitive. I explained to him that I was a renter and couldn’t afford it, he brought me plans for a paint storage cabinet made of plywood. The cabinet needed to be 1” thick plywood ( two 1/2” pieces of plywood screwed together ) not press board, it needed to be painted 2 coats in and out with fire proof paint, it had to have a 4” lip on the bottom, the doors needed to be self closing and have a exterior latch but not a lock.
    A few years later when it was pretty full the inspector asked me to build another. In today’s commercial world this cabinet probably wouldn’t fly. I still use a cabinet like this for flammable things in a storage garage.
    I had a semi retired painter work for me part time and I noticed when I came in in the morning after he had closed up that all the extension cords in the shop were unplugged. I asked him about it, he shrugged and said it’s always seemed like a good idea. I do it every night, it’s just a habit.
  23. TCATTC
    TCATTC
    I assume it's a state thing, I like them chest high, they made me lower mine.
    loudbang and Truck64 like this.
  24. Truck64
    Truck64
    from Ioway
    Reminds me I've seen shops disconnect the battery in the customer cars left inside the shop overnight. Defective wiring, rodents chewing on wires ... Better safe than sorry I guess.
  25. Elcohaulic
    Elcohaulic
    Spraying a water on some fires fuels them, H2O..
  26. Roothawg
    Roothawg
    Glad this came back up, I thought about something the other day.
    What do you guys do with your oily rags, once your bin is full? How do you dispose of them?
  27. squirrel
    When I used cloth rags, they went back to the uniform company they came from, and clean ones replaced them.
    I use paper shop towels now, they go in the garbage with the other garbage. I don't let them pile up much.
    TrailerTrashToo likes this.
  28. Roothawg
    Roothawg
    When I was on the floor, I used to have access to shop rags and laundering service. They would look at me funny if I brought in a bag of rags to be laundered now. Plus mine are red and the ones we have at work are white.
    I do use a lot of the industrial paper towels now. They go in the same bin.
  29. squirrel
    Letting oily rags or towels accumulate together is not a good thing...
    Roothawg likes this.
  30. Truckedup
    Truckedup
    in commercial garages any potential spark producing device like wall outlets, switches, furnaces, electric motors etc, must be a minimum of 18 inches above the floor...A good rule for you home garage..
