Hot Rods M/T Pontiac Tempest 4cyl with chain driven 471 blower
Discussion in 'The Hokey Ass Message Board' started by drumyn29, May 11, 2021.
  1. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Yeah, no doubt! My first thought would be to drop it in a hoodless Track T.
    Stogy, Tman, Deuces and 1 other person like this.
  2. ottoman
    ottoman
    from Wisconsin
    I have a race one in my shop also... no blower but big domed cast pistons... crank also says "arma steel" on it and its a cast crank.. not sure but I think all the 4 cyl cranks were cast and said "arma steel" on them
  3. Deuces
    Deuces
    Could have been cast steel... Or maybe even nodular iron....
    Stogy and loudbang like this.
  4. carbking
    carbking
    The Tempest 4-cylinder M/T valve cover is listed in the 1962 M/T catalog. This was the second edition of the catalog. I do not have a first edition, nor do I know when it was printed.
    Jon.
    Stogy, Runnin shine, Deuces and 2 others like this.
  5. Pretty sure cast steel for Pontiac cranks. With the more rare forgings in a few examples on the V8s. Same story on rods, Pontiacs have cast steel rods, with the more rare forged rods.
    Stogy, Thor1, Deuces and 1 other person like this.
  6. Ebbsspeed
    Ebbsspeed
    Many years ago, the General Motors (GM) metalcasting division developed an alloy known as Armasteel for use in differential parts, engine crankshafts, automatic transmission stator shafts, connecting rods and other components.
    Armasteel served the automaker well in many critical areas. In the GM Corvair, for example, it was used for differential ring gear carrier/cover assemblies. The material also was used for the crankshaft in the high performance 421-cu.-in. Pontiac engine and the connecting rods in the lightweight Buick/ Oldsmobile V-8 engines of the 60s.
    However, confusion about the nature of this material has recently emerged in the casting community. Much of this results from GM's marketing efforts to apply a certain mystique to standard engineering materials. First, Armasteel is not steel but a GM trade name for a grade of pearlitic malleable cast iron. As a 1982 GM brochure explains, it is a ferrous alloy with temper carbon in a matrix of tempered pearlite or tempered martensite. It was produced at the GM Central Foundry Saginaw Malleable Iron plant (SMI), which was closed in mid-2007.
    A brief history of the plant was given in the article "A History of Innovation" in the Jan. 2001 issue of MODERN CASTING. According to the article, "SMI was one of the first to develop a melting technique in which cupola iron was transported to electric arc furnaces and 'duplexed,' or treated for metallurgical control and held until it was needed at the molding lines. SMI also developed and introduced pearlitic malleable iron (known as Armasteel) in 1936, which was used extensively for military applications during WWII and the Korean War and also for the conversion of crankshafts and connecting rods from steel forgings to cast components in the 1950s."
    As heat treatment technology was refined and moved from coal fired batch ovens to continuous gas or electric atmosphere controlled ovens, so did the manufacturing approach and available grades of Armasteel. The resulting four Armasteel grades listed in the GM brochure were referenced by hardness and strength ranges.
    Beyond the heat treatment to convert the white iron cementite to a temper carbon form, these specific grades were made by either a controlled air quench and temper from the malleablizing temperature (resulting in a tempered pearlite) or a second heat treat operation consisting of reheating followed by an oil quench and temper (tempered martensite).
    The confusion over Armasteel also arises from malleable iron becoming less popular over the years. As ductile (nodular or spheroidal graphite) cast iron started to gain acceptance as an engineering material, much of the former malleable iron work (malleable dates back to about 1900, while ductile was invented in 1948) was converted to ductile cast iron. Malleable iron is more difficult to cast and requires the lengthy heat treatment operation to create the temper carbon. Ductile iron can be made directly from magnesium as an alloy treatment addition to the base iron. In addition, most of these Armasteel grades now can be made as-cast with alloying additions of copper or manganese to the base metal.
    If you are looking for a replacement alloy for Armasteel, look no further than standard ferrous materials. Any malleable cast iron produced with proper controls will be similar, if not identical, to Armasteel. Ductile iron equivalents also are available for all four grades of the alloy.
    tomcat11, Stogy, catdad49 and 12 others like this.
  7. lumpy 63
    lumpy 63
    Diggin the 4 bolt main Tempest block:cool:
    Stogy, triumph 1, Thor1 and 2 others like this.
  8. pontman
    pontman
    I talked with the seller Norm and had many questions about this engine. He had sold it and didn't want to talk, he did say it sold for $1000. Is this true? Had planned to make a offer but being 1000 plus miles away doesn't help.
  9. drumyn29
    drumyn29
    yes, it sold for $1000 but I bought it for more.
    Stogy, Thor1, Tman and 1 other person like this.
  10. 296ardun
    296ardun
    catdad49, Stogy, jimmy six and 3 others like this.
  11. 296ardun
    296ardun
    Love this! Ron Benham was a friend and mentor when I worked at Blair's in the early '60s. He built cars for many decades. Here is the Willys coupe he build with Earl Wooden, photo from the Don Tuttle collection...they ran it at both the drags and the lakes.
    WC145, catdad49, Stogy and 5 others like this.
  12. drumyn29
    drumyn29
    I'm building this heap now, I wonder if it would be ridiculous if I built it similar to Wooden/Benham's but with the 4cyl Pontiac. I have a magnesium Halibrand quick change for it. IMG_5072.jpeg IMG_0237.jpeg
    WC145, Jet96, catdad49 and 9 others like this.
  13. King ford
    King ford
    from 08302
    Bingo Flyer!! ...when I read " steel crank" I too looked.....needs a little Bessemer process to be steel!!.... still COOL STUFF AND STORY though!!
    Stogy, loudbang, Deuces and 1 other person like this.
  14. Very cool find!
    Stogy, loudbang and Deuces like this.
  15. 296ardun
    296ardun
    Why not? It was a classic.
  16. jimmy six
    jimmy six
    Burke introduced himself as the “ Worlds tallest Midget”. He was quite a guy.
  17. jimmy six
    jimmy six
    You must have bought it from Norm. I knew Ron very well. Marched to a different drum beat. Built a lot of race cars...
    Stogy, loudbang, Thor1 and 1 other person like this.
  18. jimmy six
    jimmy six
    Moved to aFED later but never ran as the guys got married and the car sold..as told to me by Jack Underwood.. one of the players in its conception and running in the Willys at Lions
    elgringo71, Stogy, loudbang and 2 others like this.
  19. I know of Burke from my friendship with Glen B RIP
  20. Those Pontiac armasteel cranks seem to be pretty tough. I've never hurt one. The engine in my 34 is an early [1957] Pontiac and they came with forged steel rods and crank. Some guys attached the name "rubber rods" to the forged rods....said they would stretch at high RPMs because of incomplete heat treating. I dunno...my rubber rods haven't stretched ....yet. I keep it below 5500 RPM tho.
    Cool 4 banger motor! I'd put it in something really light like a HAMB drags dragster with all early parts.
    Stogy, catdad49, Runnin shine and 2 others like this.
  21. It would be in a T modified for me!
  22. drumyn29
    drumyn29
    Jnaki, you always have the best pictures and information. Thank you
    WC145, lothiandon1940, Stogy and 4 others like this.
  23. drumyn29
    drumyn29
    Question for ya! What front brakes did these guys use on early willys race cars, was there a disc brake set up other than the Volvo brakes? Or even on 39-48 ford axles, what was available.
    Stogy likes this.
  24. Rusty O'Toole
    Rusty O'Toole
    Don't know how they did the Fords but Dodge Clutch Flites used a power steering pump plumbed into the transmission.
  25. MeanGene427
    MeanGene427
    from Napa
    Pretty close, but C4s could indeed exist in '63- the casting numbers actually represent the year model the casting was designed for, in this case '64, and the vehicle line that paid for the engineering, in this case A or full-size Ford. It could be used by any of the vehicle lines, but that line paid for the engineering. To be used in early '64 vehicles, the castings would start production in early/mid 63 to allow for machining, building and installation in time for new-car introduction, which is well before the first of the year- so C4 transmissions did exist in '63. Never seen a clutch-C4, mine is a C6 which was a Ford/B&M collaboration, but MT was never afraid to conjure up some pretty innovative (bizarre?) stuff on his own. As was mentioned, that one doesn't have the fingered cage to drive the pump as the C6's used, so ? This is the clutch-C6 drive
    Deuces, Stogy, Thor1 and 1 other person like this.
  26. Marcia
    Marcia
    I think I have the Baby Whale. The front half looks the same. Drury must have got it from Benham. PXL_20230925_032608445.jpg PXL_20230921_213009044.MP.jpg Screenshot_20230514-070246.png
  27. drumyn29
    drumyn29
    lothiandon1940 likes this.
  28. drumyn29
    drumyn29
    the engine and car belong together.
  29. Marcia
    Marcia
    It had Drury's timing tag on it so I'm restoring it to that time.
    WC145, Thor1, lothiandon1940 and 3 others like this.
  30. drumyn29
    drumyn29
    Thats cool! Which engine did they run in it? I thought they only ran the Pontiac. but I don't know much about the car or story.
    WC145, Thor1 and lothiandon1940 like this.
