Hot Rods 1930's Fords hood tops with hidden latches
Discussion in 'The Hokey Ass Message Board' started by Roothawg, May 16, 2021.
  1. Roothawg
    Roothawg
    I am thinking on my next build(36 Ford PU) I will run without the side panels.
    I'm curious how you guys deal with this? I like the leather straps, but not for this build...wrong era.
    The front side would be easier I think, because of the access to the grille backside, but the back one confuses me.
    I was thinking of a spring loaded pin of some sorts, just trying to work out the sub-structure.
  2. Subscribed.
  3. OzyRodder
    OzyRodder
    I use screen door springs stretched across and fasten with R clips through hood side hinge pin holes
  4. fastcar1953
    fastcar1953
    Pictures? Also interested
  5. What are R clips? Don't remember ever hearing that term.
  6. OzyRodder
    OzyRodder
  7. Roothawg
    Roothawg
    I was thinking more along the lines of a spring pin loaded to the closed position or forward/ aft.
  8. alchemy
    alchemy
    Rubber bungy cords from side to side. Worked fine for me for years so far.
    325w likes this.
  9. Roothawg
    Roothawg
    That’s too easy.
    seadog likes this.
  10. 30tudor and cavman like this.
  11. Roothawg
    Roothawg
  12. I got way involved in a project like this. In the end it looks simple and works pretty well. We can run with or without side panels and open either side of the hood. Being it's a Chevy I needed rad support rods so I made the Hood Latch units replace them. With the sides off nothing shows below the hood top lower edge. With the sides on and top open you don't see anything. You can remove all 4 pieces and all that's there is the support tube with the latch pins in it. Maybe there's something here you can spin off of to get your job done. This file is Photo heavy and if you think this is something you'd like to see more of I will do a little work to transfer into something I can post up here. This photo is just the tube for each latch and is fully adjustable for hood and grill alignment. It was a little more than a days work but I like the end result, so does the Customer.
    guthriesmith and Guy Patterson like this.
  13. jaracer
    jaracer
    I have thought of doing the same. Does the hood stay in place when you fold it over or do you have to release the spring?
  14. Roothawg
    Roothawg
    That's where my mind was heading. I was picturing a rectangular tube like 1/2"-3/4" tall and maybe 1/4" thick. It could even be solid, but that seems like overkill.
  15. This ended up working out quite well. It let's me fully adjust for hood gaps. There are 4 latch points total mounted inside the sq. tube and both on each side release with one pull knob on each side. This started life as a kit and I then used what I liked and made the rest to end up with what I wanted. I folded up a channel and made it fit tight to hang the side panel on the tube then fastened it at the bottom. With the side off and the top down nothing shows. That's not at all how the Kit was designed to be installed.
    Roothawg and guthriesmith like this.
  16. V8 Bob
    V8 Bob
    I used spring-loaded non-metallic pins held in place with square tubing welded to my '32 hood. The pins lock into small "L" brackets screwed/welded/riveted to the radiator shell and firewall. These are completely hidden when the hood is in place and also allows hood sides if desired.
    Pist-n-Broke, 30tudor and Roothawg like this.
  17. Roothawg
    Roothawg
    That's very cool. That something you just put random pieces together or were they a repurposed latch? That's exactly what I am after.
  18. V8 Bob
    V8 Bob
    A friend suggested using those pins that secured his Brookville Roadster Model A pickup's tail gate. I bought them from McMaster Carr, but haven't seen or been able to find them for some time.
  19. With the Hood Sides on how do you access the release pins?
  20. Roothawg
    Roothawg
  21. V8 Bob
    V8 Bob
    The hood sides secure the tops, so the pins would just be pushed out of the tubing until the sides are removed.
  22. V8 Bob
    V8 Bob
    Roothawg likes this.
  23. Why make it hard the bungy works great.
  24. Steves46
    Steves46
    from Florida
    Same here.
  25. Roothawg
    Roothawg
    Without sounding crass, the bungy cord is kinda cheesy. No offense to the bungy crowd.
    Pist-n-Broke and V8 Bob like this.
