Hot Rods need help identifying this
Discussion in 'The Hokey Ass Message Board' started by Dirty Old Dave, May 13, 2021.
  1. Dirty Old Dave
    Dirty Old Dave
    Bought this early GMC chassis and running gear. Don't know what year it is. Can't find any numbers on the chassis anywhere. Number on the engine is A228482182. Frame is approx. 174" long, 25" width at the front, and 46"wide at the back with a wheelbase of approx.116". Gonna stuff a Packard straight 8 in it.
    kidcampbell71 likes this.
  2. 51504bat
    51504bat
    Can't open photos
  3. Dirty Old Dave
    Dirty Old Dave
    just readded as individual files...try that please...thanks
  4. 302GMC
    302GMC
    from Idaho
    Take pictures of the trans. and a brake backing plate. Make them larger & more clear if you can.
    We can narrow it down to '53 or older with what we have now ...
  5. junkyardjeff
    junkyardjeff
    Steering box looks like 48 to 53 and possibly to 55 first series.
  6. texasred
    texasred
    from Houston
    what are you gonna put on top of it
  7. Dirty Old Dave
    Dirty Old Dave
    It'll be awhile for more pics. It's at my place in the mountains, won't be there till memorial weekend
  8. Dirty Old Dave
    Dirty Old Dave
    Plan to build some kind of speedster body
  9. Dirty Old Dave
    Dirty Old Dave
    Am I wrong that after like 47 the frame rails were paralell
  10. KevKo
    KevKo
    from Motown
    47-54 AD frame rails are wider at rear than front. I am assuming Chevy and GMC used same frame.
  11. mgtstumpy
    mgtstumpy
  12. 1934coupe
    1934coupe
    46 Chevrolet PU. The one I had the serial number was on the chassis by the steering box.
    Pat
  13. RichFox
    RichFox
    Look at the pad the distributor is located on. The first three numbers there will tell you which engine it is. Like 270XXXXXX- Or 248XXXXX. Still a good market for 302 Jimmies. The rest of them are sellable also
  14. Dirty Old Dave
    Dirty Old Dave
    Thanks to all. I will try all this stuff over memorial day and report back. I've had trouble finding any numbers.
  15. brading
    brading
    Does this help at all its a 3100 chassis. Got it by Googling 47 Chevy truck frame measurements.cha 3100 chassis.jpg
  16. Dirty Old Dave
    Dirty Old Dave
    Thanks. now I just have to get my eyes checked
  17. From the pictures that looks like a 47-54 Chevy 3100 (half ton) pickup frame. It is the same one that brading posted the diagram (above).
  18. Dirty Old Dave
    Dirty Old Dave
    Sorry these took so long, but here are the pictures you asked for.
  19. Dirty Old Dave
    Dirty Old Dave
  20. GMC. More than likely a 228 or 248.
    HD trans.
    The GMC and Chevy are very similar. The front xmember is GMC specific.
    The shock type can help you date it.
    Lever or modern tube style.
    The block will have casting numbers on it.
    Maybe you’ll hit the jackpot and score a 270 or 302
  21. ronzmtrwrx
    ronzmtrwrx
    I can tell you for sure, it’s not a 54-early 55. The kick up over the rear axle is much flatter on those than the frame you have. It does resemble the 48-53 though.
  22. junkyardjeff
    junkyardjeff
    The first digits in the engine number you posted tells it all,A228 is a 228.
    Hnstray likes this.
  23. GMC started using tube shocks in 1950
  24. Hnstray
    Hnstray
    from Quincy, IL
    Half ton frames are tapered…..3/4 not sure, but one ton up are parallel rails.
    Ray
  25. Dirty Old Dave
    Dirty Old Dave
    Can you tell if the trans is 3 spd or 4 spd?
  26. Dirty Old Dave
    Dirty Old Dave
    It had tube style shocks
  27. Looks like a sm420 as far as I can tell from the pic.
    There would be a removable plate on the drivers side for a PTO and a large bulge on the other side.
    Great truck trans
  28. Dirty Old Dave
    Dirty Old Dave
    Checked both sides and tops of frame. Still can't find any numbers.
  29. There probably aren’t any
    I think the only vin was the door jamb plate.
    That chassis with tube style shocks (factory) would be a 1950 to early 1955, /2 ton with 6 lug wheels)
  30. Dirty Old Dave
    Dirty Old Dave
    I don't recall any plate for a PTO but I wasn't really paying attention. I'll check it out next time I'm up there
    anthony myrick likes this.
