Technical Early GM Hardware
Discussion in 'The Hokey Ass Message Board' started by Voh, May 10, 2021.
  1. Voh
    Voh
    I am putting the front end of my 1941 Chevy Sedan back together and need help on what size bolts/screws these are. There are (2) on each fender top brace and about 12 on the chin piece. Pic below is an original screw, next to a 1/4 lag bolt. The lag is VERY close.
    Thanks, VOH
  2. Voh
    Voh
    Does my question make sense? looks like a lot of looking, but no one has chimed in yet.
  3. GM used those for many years. Look at Tri Five parts dealers. They should offer a sack full. Lots of time a clip nut was used also.
    Hnstray and olscrounger like this.
  4. Voh
    Voh
    Thank you.
  5. AngleDrive
    AngleDrive
    from Florida
  6. 1/4" x 1" Square lag - Black Oxide (blacksmithsdepot.com)
    IN STOCK
    Square head lag bolts (100 pcs.)
    Item # 277c
    $0.30
  7. vtx1800
    vtx1800
    This might have what you need........pictures don't show all of the small parts though:(
    https://www.chevsofthe40s.com/dept/Fender/cat/Bolt+Kit.html
    Studes used that style of fastener into the 50's and 60's, can't remember the thread count but you might check Fastenal or a like store for them.
  8. See your in Texas. Call Jim Hawes in Kilgore . Classic Chevrolet Connection
  9. The Filling Station in Lebanon, Oregon
    800-841-6622
  10. Matt55folife
    Matt55folife
    If you dont mind the bolts not having a square head then those lag bolts will work. I put together my 55 with lag bolts from tractor supply. Think they was $2 a pound.
    Voh likes this.
  11. Elcohaulic
    Elcohaulic
    The threads are too rough for steel. They look like wood screws..
  12. Greg Rogers
    Greg Rogers
    That's what I was thinkin too, Maybe someone put that screw in there when apart before? I think I would check with other guys who own old Chevys or that classic Chevy place mentioned by someone above.
  13. Fordors
    Fordors
    I got this bag of hardware in a box of early Ford parts at an auction, same exact screws along with shims, B56CAE02-C8D9-4A03-BB92-985DF6C67530.jpeg FA991E72-1C73-42BC-A592-35CC3F9E027A.jpeg 2045590C-89B2-4E38-84EA-656A914B07A4.jpeg washers, screw clips and some 1/4-20’s.
    egads and Voh like this.
  14. Voh
    Voh
    Thank you guys for your help.
