Projects 1962 Pontiac Tempest
Discussion in 'The Hokey Ass Message Board' started by CGkidd, May 4, 2021.
  1. CGkidd
    CGkidd
    Well thought I would post a build I am working on while the 46 Chev is at the paint shop. It's a 1962 Pontiac Tempest LeMans. Original trophy 4 cylinder, 4 barrel, 4 speed with 3.55 gears. For those of you who don't know these cars Pontiac took a 389 and cut it in half length wise to make the four cylinder. It actually uses the 389 head and pistons. I bought it was driving home and promptly ran out of gas. LOL while waiting for the GF got a call from the old man I bought it from telling me if the gas gauge says 1/4 tank it's actually empty. Finally got it home and started a tune up I knew it had a gnarly vacuum leak. Finally got that straightened out but just couldn't get it to run right. It ran quiet no Knocking just couldn't make any power. Pulled valve cover to replace gasket and checked the rocker arms 3I and 4I rocker were super loose, not good. So I pulled the intake and valley pan. No lobes left on 3 and 4 intake. So out came the engine and full rebuild is done. That's where I am now. 28332.jpeg 28336.jpeg 28339.jpeg
    Sent from my E6910 using The H.A.M.B. mobile app
    34 GAZ, wicarnut, mgtstumpy and 22 others like this.
  2. CGkidd
    CGkidd
  3. Jokester
    Jokester
    Some long, unused brain cell reminded me that these engines used to be hard on timing chains and gears. But I'd still like to have it.
    .bjb
  4. jeepster
    jeepster
    from wisconsin
    That is one neat lil' set of wheels, enjoy!
    Deuces and loudbang like this.
  5. squirrel
    "rode hard and put away wet"....dang...
    Nice little car, good to see you're keeping it on the road.
  6. CGkidd
    CGkidd
    Rebuild of the original engine. sleeved back to standard bore. Ross pistons, h beam rods, prted and polished head, long branch exhaust manifold and original Cal custom valve cover. KIMG0493.jpeg KIMG0684.jpeg KIMG0789.jpeg KIMG0665.jpeg KIMG0671.jpeg KIMG0824.jpeg KIMG0825.jpeg KIMG0827.jpeg KIMG0828.jpeg
    partssaloon, Aaron65, 34 GAZ and 26 others like this.
  7. vtx1800
    vtx1800
    That is a pretty rare car and in nice shape (well other than the engine) and the interior looks Soooo nice:) I think I remember one of those cars in the area I grew up in, looks like it will be a fun car to drive:)
    lothiandon1940, Deuces and loudbang like this.
  8. bchctybob
    bchctybob
    Very cool!!! Glad to see it getting back on the road. Nice job with the engine.
  9. catdad49
    catdad49
    Nice little Poncho! The only thing I might add are 4 more cylinders (except then you might have to upgrade the rear end).
  10. jaracer
    jaracer
    A buddy had a 61, 62 and 63 Tempest LeMans. He was a Fuller Brush man and put lots and lots of miles on his cars. He traded every year. He won a lot of trophy's at the drag strip with his 61. He told me the only thing that could beat him off the line, in his class, was a Corvair Monza. The Monza's lead didn't last long.
    He was trying to get me to work for him selling Fuller Brush so I got to drive the 62 quite a bit. Nice little car. Like someone else mentioned, the timing chain got very noisy at around 90K miles. That's about the time he traded for a new car.
  11. Squablow
    Squablow
    Love the car, love the hot 4 cylinder build.
  12. Nicely done, and love the touch of the Cal Custom cover!!!
  13. Doublepumper
    Doublepumper
    from WA-OR, USA
    I had one years ago for my daily and drove it everywhere. I liked how it drove, had plenty of power even with the push button auto trans.
    A buddy just had to have it, so I sold it to him. He gave it to his wife and she drove it everywhere, until one day she went to the grocery store and came out to find it in flames.
    Apparently there was an electrical issue somewhere that caused the fire. Burnt it to the ground.
    Deuces, loudbang and bchctybob like this.
  14. Nice car, seems that except for the worn out engine it is in real good shape. It's neat that you are keeping the 4 cyl and doing a mild performance rebuild on it. I am sure the increased power will make it even better driver. Was there a problem with just std boring of the block that required the sleeves? Rebuilt engine looks great with the valve cover and long branch exhaust.
    Just a dumb question, how is the rest of the drivetrain condition?
  15. 4ty
    4ty
    I worked at the local Pontiac/Cadillac dealership when they came out. Lots of timing chain problems. I had a 32 5W at the time with a 55 Olds in it. Picked up a 4 cyl Tempest engine and installed it, HD Taxi clutch and a 4 bbl intake with a Cad carb on it. No hood sides on the 32, Valve cover on one side and 4 bbl on the other, ran almost as good ad the V8.
    Paul in CT
    wicarnut, Deuces, loudbang and 2 others like this.
  16. Neat little Tempest. I bought a 62 Lemans convertible for my wife several years back, but we never did much with it. I like the cars though.
  17. CGkidd
    CGkidd
    Rest of the drive train is good. Engine was already .040 over. Probably could have just installed new rings but it would have been a little loose. Went with a very slight dish to drop compression from 10.25 to 9.5 to help with drivability.
  18. Yes they were.... I owned one of these briefly in the early '70s. The four-banger didn't use the standard V8 timing set either; it used a 'special' set, considerably tougher than the V8 one that was used as an 'upgrade' on the V8s. The real fly in the ointment was it also used a special tensioner on the chain, that tensioner cost about double of what the chain/sprockets cost and was in short supply. Apparently timing chain harmonics were brutal. At the time these parts were all dealer-only items and not cheap (over $100 IIRC) and on a $300 car a death sentence....
  19. oldiron 440
    oldiron 440
    The leaning tower of not so much power.
    Cool car.
  20. blowby
    blowby
    from Nicasio Ca
    Sweet car! Some period American TTs would look nice..
  21. 302GMC
    302GMC
    from Idaho
    Friend of mine's 15 yr. old little sister would sneak out the window at night, push the family '63 Tempest wagon with that engine down the block, fire it, then off to 1st street for the "evening program." It must have had a pretty deep transaxle, as the only things that would stay with it in a block were 301 Chevvies & 4.56 geared 409s. She was pretty good at making that rubber shift linkage work.
    wicarnut, Deuces, 54EARL and 3 others like this.
  22. Photogs189
    Photogs189
    My first car was a used 1962 Tempest Convertible
    Had the 4 cyl. with the auto lever on the dash like the Corvair.
    It was a great little car. Yours looks great. Best of luck with it.
  23. 56sedandelivery
    56sedandelivery
    I looked at your first photo and said, that's Washington State; just something about the "lighting". Beautiful little car. Would an actual V-8 Pontiac fit? Just curious. Surprised a camshaft is still available. I am Butch/56sedandelivery.
    Deuces, bchctybob and catdad49 like this.
  24. Wrench97
    Wrench97
    Back in the early 70's we dropped a 326 v8 in one fit ok but we promptly tore the transaxle out of it.
    Deuces, catdad49 and loudbang like this.
  25. Dennis D
    Dennis D
    What a neat car! Can't remember the last time I saw one on the road.
  26. drtrcrV-8
    drtrcrV-8
    Look for the thread : "Nunzi's '63 super duty Tempest on You tube" there are 2 separate videos.
  27. Cosmo50
    Cosmo50
    Thats a nice Tempest there. I had a 62, but it was an automatic. Cool cars.
  28. RichFox
    RichFox
    Bought a new 63 when. Loved it. Ate a few timing chains though
    Deuces likes this.
  29. triumph 1
    triumph 1
    Very cool car, I always wanted one.
    Nice work on the engine!
  30. AngleDrive
    AngleDrive
    from Florida
    Outstanding, I worked in a Pontiac dealership in '62
