Technical 40 Ford Sedan Delivery floor question
Discussion in 'Traditional Customs' started by Whoamel, May 2, 2021.
  1. Whoamel
    Whoamel
    from So Cal
    I have a silly question on a '40 Ford sedan delivery.
    Underneath the raised cargo wood floor, is the underlying floor the same as the sedan?
    I'm a rather tall fellow, and I'm looking to buy a '40 SD. I'm pondering if the front of the cargo floor could be shortened by about 12". If the floors are the same, it seems like it would be relatively simple to build a new front support for the shortened wood floor. At least, I am hoping that would be the case...
    Thanks!
    Algoma56 likes this.
  2. LOU WELLS
    LOU WELLS
    from IDAHO
    The Cargo Floor Is Oak And Behind The Front Seat Is Metal Back Far Enough To Support The Fuel Tank On The Drivers Side And Tool Box Area On The Passenger Side....1940/41 Ford Sedan Deliveries Are Based On The 4 Door Sedan Platform And Use The Same Doors...Cut It To Your Desires... 41%20ford%20panel%20388315%20017_zpspbfjaeb5.jpg
  3. rustythumb
    rustythumb
    i have a '46 s.d. & i moved the support back about 5". only bad thing is the stock gas tank will no longer fit. i had a new tank made that fits where the spare tire went.
    LOU WELLS likes this.
  4. Whoamel
    Whoamel
    from So Cal
    I'm going to guess that is the gas tank right behind the rear seat? If I was going to move the seat mounts back a bit, that looks like it needs to be moved.
    And thanks for the pic!
  5. fordflambe
    fordflambe
    I'm 6'3". I did exactly as noted above and moved the crossbar and flooring back to accommodate for my taller frame. My solution to the gas tank location was to use a 40' gas tank mounted in the rear as a coupe or sedan would be. Then I used a filler door mounted in the rear fender off of a 46' car. If I remember correctly, the frame already had the holes to mount the gas tank in the rear............hope this helps.
    LOU WELLS and 31Apickup like this.
  6. Whoamel
    Whoamel
    from So Cal
    Yes, that is a huge help. I thought I had read that somewhere, so thanks for confirming that. I appreciate it!
  7. 1-SHOT
    1-SHOT
    from Denton
    Put Tudor sedan doors on it and it’s easier to get in and out of
  8. hotrodjack33
    hotrodjack33
    As far as duct tape repairs go, that looks like a 2 roll'er;)
    anothercarguy and Whoamel like this.
  9. LOU WELLS
    LOU WELLS
    from IDAHO
    It Has Worked Fine For All Of These Years Of Actually Using The Delivery... 41%20ford%20panel%20388315%20022_zpsg6plo8jq.jpg
    40FORDPU and hotrodjack33 like this.
  10. LOU WELLS
    LOU WELLS
    from IDAHO
    Take Some Time And Look At The Delivery You Are Interested In... 41%20ford%20panel%20388315%20006_zpsquvl363r.jpg
    Jim Bouchard likes this.
  11. ken/alabama
    ken/alabama
    from Alabama
    Like that 40 delivery. !
  12. LOU WELLS
    LOU WELLS
    from IDAHO
    41%20ford%20panel%20388315%20032_zpszxyuhayf.jpg Mounting A Passenger Car Gas Tank In The Rear Requires Cutting Out The Spare Tire Compartment...
    Whoamel likes this.
