Does anyone have a photos of 32 with 4 bar set up? I have a vintage Pete and jakes frame with that set up, just looking to see how it looks on a complete car. Thanks
^^^^ pic of the truck above does not look to be a 1932 Ford 4 Bar , its looks Model A set up , a 32 "top bar " (about 2 inch up from bottom of frame rail) goes threw frame ,& bottom bar below frame , But model A set up will work.
Well, when I ordered that 4 bar setup in 1985, the part number was for a 1932 Ford. But if you say it’s a model A I’ll take your word for it.
Stllrng , Yours does not appear really Model A either (by looks of the photo) I have seen A's four bar & the top bar is 1 1/2 - 3 inch below bottom of frame rail , A 's 4 bar on 32 frame can drag on speed bumps ( brackets are longer ) Maybe first production design 4 bar going from using HairPins ?
I didn’t know there were differences between the two. In fact when the OP asked for 4 bar pics I was about to look for rear end mounting photos ! Post 3 suggests this. I still don’t know which end of the car he is trying to fix to his chassis......
