Projects ‘30 coupe, heavy chop and fendered
Discussion in 'Traditional Hot Rods' started by Ken Carvalho, Dec 20, 2020.
  1. hotrodlane
    hotrodlane
    It looks really cool! It looks good with the hood but it is a Sin to cover up the Flatty.:D
    Ken Carvalho likes this.
  2. Barn Hunter
    Barn Hunter
  3. 6sally6
    6sally6
    Looks really cool...........like how you did the key/instrument panel too!
    6sally6
    Ken Carvalho and Thor1 like this.
  4. Ken Carvalho
    Ken Carvalho
    Just another quick update (something I’m not very good at keeping up with) my daughter and I sewed up a seat, I made a base out of the A’s seat sides and welded a bottom and back to them. Cut out wooden platforms glued some foam and the “presewn” diamond pleats to them. We sewed up the smooth flat vinyl to the pleated vinyl.
    kidcampbell71, Stogy, Thor1 and 4 others like this.
  5. Ken Carvalho
    Ken Carvalho
    Then I made panels for the roof, quarters, back area and today will finish up the doors and kick panels.
  6. Ken Carvalho
    Ken Carvalho
    ....also I’m a California boy living in the PNW, and I get cold easily, so I wanted a heater that didn’t look out of place and was small. I had a broken gas fired Southwind one. I gutted out the internals, put in a 12 volt cooling fan/motor, and came across a small aluminum 4”x6” radiator used for computer cooling. Put a switch where the original knob was, carefully drilled out the knob and epoxied it to the switch handle. Combined everything made a shroud inside for the fan to blow thru that small radiator and it works!! The rad has 7/16” outlets and I used some fittings to connect it to the 5/8” heater hoses. Not a ton of heat, but WAY more than one of those heaters mounted to the exhaust manifold on a 4 cylinder!?!!
  7. Tim
    Tim
    from KCMO
    Looks fantastic man
    kidcampbell71 and Ken Carvalho like this.
  8. Tim
    Tim
    from KCMO
    Any shots of the heater going together?
  9. Ken Carvalho
    Ken Carvalho
    No, didn’t think about it when I was building it. It’s just a 12 volt motor/fan mounted in the same spot the 6volt one was, then the brace that held al the gas heater parts is where I mounted that computer radiator. Then I bent a 6” piece of tin and pop riveted it to the back to form a shroud around the fan. Then I screwed it all together. Wherever there were some gaps I put in some RTV/caulk to seal it up. The 3 way switch came with the fan, and it is just mounted where the original Southwind pull knob was.
    Thor1 and Tim like this.
  10. Tim
    Tim
    from KCMO
    Cool thanks for the info :)
  11. Ken Carvalho
    Ken Carvalho
    Dusted of my Coats 2020 and got my Radirs installed. Filled up the fender well nicely. I have a T spring with only a couple of leafs to drop it down, but I think I’ll put a couple back in for some tire clearance.
    catdad49, Tim, Thor1 and 1 other person like this.
  12. Ken Carvalho
    Ken Carvalho
    A11AF7E3-5AAD-4508-911B-BDF9035C1584.jpeg Also other than the tires, I’ve been bodyworking the chop on the coupe, but the cold weather has prevented me from doing any lately, so I’ve been tinkering with my Sedan. I did a 4” rear to 5” front chop, 4” channel in front, with 1” in back. Raised the rear crossmember up 3”, moved the body forward 2” and have a bellybutton SBC with 6 - 2’s.
    Vic Walter, Tman, catdad49 and 3 others like this.
  13. AHotRod
    AHotRod
    Ken .... if you select FULL IMAGE pictures, it is so much easier to see .... the Coupe looks awesome!
  14. Ken Carvalho
    Ken Carvalho
    I’ll have to try to figure that out. I just press upload a file and that’s what I get loaded!?!?
    ....and thanks!!?
    AHotRod likes this.
  15. Tim
    Tim
    from KCMO
    -Brent- likes this.
  16. catdad49
    catdad49
    They both look Great, you have been Busy!
    Thor1 and Ken Carvalho like this.
  17. mtb1981
    mtb1981
    That's a huge chop. Nice interior work!
  18. typo41
    typo41
    We are in So Cal and it gets COLD, so we went with $50.00 seat heaters off The Bay, place under the seat covers plug in and warm butt and back, luxury in a roadster
    Ken Carvalho, -Brent-, Tman and 2 others like this.
  19. in-the-weeds
    in-the-weeds
    from WA
    Bitch’n man. Really like the chop and fender look.
  20. oddrod46
    oddrod46
    from Georgia
  21. Doug Hines
    Doug Hines
    I like this car a lot. I have another 31 coupe and I want to build it with fenders and get it all low. Thanks for posting the blueprint.
    Ken Carvalho, spikemd11 and Thor1 like this.
  22. fordgezzer
    fordgezzer
    from texas
    When I finish my '36, that coupe is what I would like next. Thanks for sharing.
  23. Ken Carvalho
    Ken Carvalho
    Was having some fun and “heard/felt” a thud. I knew the rearend was weak, but figured it would hold up a little bit longer than it did. Broke 2 teeth on the pinion gear, and destroyed all the spider gears. Oh well, I have another rearend and I’ll be more careful. F65F62F0-3B77-494E-867A-1151E07B3F5F.jpeg
    Thor1 likes this.
  24. 19Fordy
    19Fordy
    Any way to "pull in" those rear wheels?
  25. Ken Carvalho
    Ken Carvalho
    B45BFED2-64BE-4AD7-994A-5E763665FDD6.jpeg Re-assembled the rear end last weekend from the carnage of my burnout and installed it this weekend. Drove it around and all seems to be good. Had to raise the spring a little as the fenders kept bottoming out on the slicks. Also put the 16” wheels on the front.
    Vic Walter, Tman, alfin32 and 4 others like this.
  26. Ken Carvalho
    Ken Carvalho
    Been driving the T-Bucket daily to work too. C5AEB648-860E-4A77-A299-1FED3EBC671D.jpeg
    Vic Walter, alfin32, AHotRod and 3 others like this.
  27. 1971BB427
    1971BB427
    from Oregon
    Love your cool coupe, and the chop is spot on! What I really love is it doesn't have another darn '32 Grille on a '30 Ford! Seems like well over half of them I see have had a '32 grille used, and I'm really over seeing another.
    I used the same black diamond material to do my interior on my '39 too. I also stripped my seats and made inserts for the buckets, and sewed them in with the same material to match is up.
  28. Ken Carvalho
    Ken Carvalho
    EE9F1E07-F95A-4FA6-BCE5-598067B3411D.jpeg 10DB2530-316F-490C-91CF-A04405714F7F.jpeg Finally got the bodywork done on the chop, and ran into some issues with the previous owners metal insert install. Did the best I could , but it was/is really bad. But, it’s a HotRod so it’ll have to do. I may just eventually glue a padded canvas insert onto it to make it look better, as I’m not too keen on cutting it out to redo it.
  29. Ken Carvalho
    Ken Carvalho
    Also changed out the rusty chrome rims to stockers, minor painting, some B284CAB0-EC29-4ED3-A08A-281011A7C447.jpeg trim rings, & spider caps.
    Jet96, Vic Walter, Thor1 and 3 others like this.
  30. Ken Carvalho
    Ken Carvalho
    5D11EBE7-6406-4BB6-9DA2-44C66011D70F.jpeg Kept going back and forth between Kingbees and the Model A lights... Decided on the original headlights on a dropped bar.
    Jet96, Vic Walter, Thor1 and 5 others like this.
