Hot Rods Olds Powered '29 Roadster Build. Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Apr 2, 2021.
  1. PINEAPPLE
    PINEAPPLE
    Great thread!, great history! subscribed and excited for updates. I have a 29 roadster body and some mangled deuce rails I have been saving for years. I love seeing the straightening and re-using of original rails. Great work Marty. I have always enjoyed your articles in the magazines when there were magazines. I just found those 2 books of Jims and bought them as well. This thread made my morning!
    Matt
  2. Marty Strode
    Marty Strode
    Matt,Thank You, let me know what you think of the books, for those that haven't read them, they are missing out !
  3. will be watching this even though it has valve covers!!!!
    Atwater Mike, Stogy and loudbang like this.
  4. continentaljohn
    continentaljohn
    Cool build
  5. flynbrian48
    flynbrian48
    I’m not using nearly as many old Ford parts (just the firewall and spindles), but I do have a cool old engine! Great stuff, I’m following!
  6. alanp561
    alanp561
    As many times as I have managed to smack my left hand index knuckle with a 4 pound hammer while attempting to drive out rivets, you'd think I'd learn to remember where I laid the vise grips so I wouldn't do that again.
  7. Marty Strode
    Marty Strode
    You are well ahead of me, great project you have there !
  8. Marty Strode
    Marty Strode
    Alan, Vice Grips are a fantastic invention, and great for tightening those knurled Allen bolts. BTW, I only use a 3 lb hammer, a little safer that way.
  9. Six Ball
    Six Ball
    from Nevada
    I just found this while on a search to expand my "watched thread" list. I can't do the big page often. are you going to re-rivet the cross members? I'm up for learning how to do that. This looks good and I loved the Olds in my '38 coupe way back in '62. The rear ends and trannys not so much. :rolleyes:
    Jack Greiner's roadster is my favorite '32 ever!
  10. alanp561
    alanp561
    Yes, they are. BTW, the striking force of a 3# or a 4# hammer figures out to roughly 10,000 - 11,000 PSI. Which ever one you use, you gotta be tough!:eek::eek::oops:;)
  11. Six Ball
    Six Ball
    from Nevada
    Ok, I've just been here a few minutes and the conversation has already covered every tool I own a monkey wrench, a cheater bar, crescent wrench, vise-grips, a punch, and a hammer. I do have a couple of different sizes of each and about 1/2 roll of duct tape.
    Woogeroo, ratrodrodder, Stogy and 7 others like this.
  12. Marty Strode
    Marty Strode
    My internet access has been rough lately, probably the W-7 I am using, a replacement is in the works. However today, the frame horns from @Weedburner 40, and the correct front crossmember showed up . Progress is on the way. IMG_6688.JPG
  13. Marty if you weld large washers on the end of your punch, you won't hit your hand as often as I used too! ha ha
    panhead_pete and loudbang like this.
  14. jimmysweden
    jimmysweden
    from sweden
  15. Marty Strode
    Marty Strode
  16. Marty Strode
    Marty Strode
    I got one frame horn fit and tacked on. Starting with making a template of the replacement horn, out of aluminum. It allowed me to layout the zigs and zags, retain the rivet holes in the top of the rail, and replace the nasty on the sides. The other side will be more of a challenge, as the drivers side rail, will require a "pull", to line up at the crossmember. IMG_6707.JPG IMG_6708.JPG IMG_6710.JPG IMG_6711.JPG IMG_6714.JPG IMG_6715.JPG IMG_6717.JPG IMG_6719.JPG IMG_6720.JPG IMG_6721.JPG
    Just Gary, alfin32, Woogeroo and 22 others like this.
  17. I love watching this kind of work. Apart from enjoying the workmanship, there's always something to learn.
  18. tractorguy
    tractorguy
    An artist at his (frame) canvas.......beautiful
  19. Marty's middle name is perfection. Nice Marty!!!
  20. alanp561
    alanp561
    Big end or the pointy end? I don't think washers on the pointy end is going to get you the desired result;)
    Stogy, chryslerfan55 and loudbang like this.
  21. Six Ball
    Six Ball
    from Nevada
    You'd need an even bigger hammer.
  22. Can't expect good answers from a trimmer
    Woogeroo, chryslerfan55 and loudbang like this.
  23. Marty Strode
    Marty Strode
    Like this one Tom ? When swing room is limited, I use the 12 -13 hammer, 12 lb head and a 13" handle. IMG_6725.JPG IMG_6726.JPG
  24. Marty Strode
    Marty Strode
    And a good trimmer you are Sam !
  25. Six Ball
    Six Ball
    from Nevada
    Damn Marty, you are tougher than I thought John Henry was killed by a 9 pound hammer but it did shine like silver......:rolleyes:
  26. alanp561
    alanp561
    Yeah, like that! I can remember when I could take one with a full length handle, hold it at arm's length, rotate my wrist and touch my nose with the head. It's hard to do with a 4# now.
  27. While I was swinging the heaviest short handled persuader in the tool drawer in tight quarters under a car on short jackstands, with my buddy holding the drift (brave as he was), he said, "ok, when I move my head you hit it". I laughed so hard, I didn't have the energy to swing.
    Don't mean to derail your thread Marty...love watching your stuff and progress. Thanks for taking the time to post.
  28. Six Ball
    Six Ball
    from Nevada
    Is there a hammer thread on here there seems to be a lot of information. I always hate it when I touch my nose with a hammer.:eek:
    alanp561, Stogy and loudbang like this.
  29. Marty Strode
    Marty Strode
    The lower flange on the RH frame rail, had a bad, rusty spot, where the K-member is attached, and need repaired. So, I rolled and punched a short section, and got it tacked in place. Now with the rail back in place, I can finish replacement of the driver side frame horn, and bolt in the K-member. IMG_6732.JPG IMG_6733.JPG IMG_6735.JPG IMG_6736.JPG IMG_6740.JPG IMG_6741.JPG IMG_6743.JPG IMG_6745.JPG IMG_6749.JPG IMG_6751.JPG
    Just Gary, alfin32, Woogeroo and 18 others like this.
  30. Six Ball
    Six Ball
    from Nevada
    Thanks for sharing all these great pictures of the build and your tools.
