Technical Trunk mounted battery setup
Discussion in 'The Hokey Ass Message Board' started by Malibu406, Apr 8, 2021.
  1. Malibu406
    Malibu406
    88A95FB2-DA34-4B15-8C4E-347FA684EB51.jpeg 578F3F86-26E2-4CDB-B986-A9BE5AD95D98.jpeg C241FE9F-D99D-48FC-9D1F-95AFB82DC4B7.jpeg 5A971F49-17E0-4BA1-B6D8-961CA571F028.jpeg 5C5C4000-3BC1-4FC7-868F-A8583F62F5CB.jpeg FF70DB8E-0825-4ADB-8C03-580F2FA258DA.jpeg 11C7781A-EAB8-40FF-8AC0-5B86298A9038.jpeg Here is my trunk mounted battery setup for those interested.
    aluminum battery box made from scratch.
    Hard hydrogen vent line to gas door.
    150 Amp slow burn main fuse mounted on side of box.
    150 Amp circuit breaker on altenater feed and chassis wiring.
    #1 altenator wire
    1/0 starter and ground
    Remote mounted solenoid and jumped starter.
    Ground battery to frame at back.
    Second ground from battery to engine block
    Ground engine block to frame
    Ground connecting both heads, body, then back to frame with block
    reagen, jazz1, Elcohaulic and 6 others like this.
  2. Nice 50 Pontiac. I hear so often that it's imperative to run your ground all the way up to the starter but hell, even my daily drivers have the battery in the back with the ground strap going to the unibody. I maintained a fleet of dump trucks and snow plows for almost 30 years and they used the frame for a ground.
    Anyway, nice setup.
    Hamtown Al and loudbang like this.
  3. squirrel
    It's only imperative to use a separate ground cable, if you're not capable of making the connections to the frame properly.
    57 Fargo and Fabulous50's like this.
  4. Elcohaulic
    Elcohaulic
    I would get a bolt on terminal like the battery's have, then drill a hole through the frame. Clean the metal up by the hole, once installed cover it with grease..
  5. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    I had a good frame ground, but then playing around ran a ground to the starter and it spun much faster, so i kept it.
    reagen and lothiandon1940 like this.
  6. Elcohaulic
    Elcohaulic
    I run a #8 stranded from the battery to the frame then to the engine block and starter bolts...
    Get a pair of jumper cables, at idle, turn everything on including wipers and try bonding different parts with the jumper cables and then check the line with the amp probe and see how much current is going through.
    At 12 volts there is hardly any pressure, so make all connections very clean and covered with grease..
    Even though electrons flow better in copper then steel, the mass of the frame and chassis makes it a worthy conductor.. I use both..
    An engineer suggested to me to always use stranded conductors with D.C. (battery) or even pulsating D.C. (alternator / generator)..
  7. SPEC
    SPEC
    Never use the frame for the ground, run the ground cable to the engine block then run grounds off the ground cable to the frame. The frame is ok for low current grounds not high current grounds.
    reagen and rockable like this.
  8. 6sally6
    6sally6
    Who sez?!..........I thought 'a-ground-was-a-ground'!?
    6sally6
    Stogy and Elcohaulic like this.
  9. There is in fact a theory that an old frame with perhaps rust or damage may have gone through metallurgical changes over the years that make it more efficient to run a dedicated ground from the battery to the block or at least a clean area of the frame closer to the starter. Others may disagree.
    reagen, Stogy, Joe Blow and 1 other person like this.
  10. 1971BB427
    1971BB427
    from Oregon
    Used the frame as a ground on numerous cars, and never an issue. I use 2/0 for my positive and negative cables at both ends, and crimped on cable ends.
    I'm puzzled by the mention by the OP of: "Ground connecting both heads, body, then back to frame with block"?? I can sue see grounding the block, and a strap to the body. But since there's no current flow through the heads why a separate ground to each head? Seems like over kill to me.
    Stogy and Crazy Steve like this.
  11. RmK57
    RmK57
    The whole thing looks overly complicated. My Mustang has a ground to the trunk floor, the positive cable running straight to the relay on the fender apron and that's it. Been that way since Nov. 1969.
    Stogy, Elcohaulic and Crazy Steve like this.
  12. Fabulous50's
    Fabulous50's
    from Maine
    The way you did it makes the most safe installation only having the starter cable hot when cranking. As well as using a 150amp breaker for all other loads. Nice thought!
    FWIW: If you use heat shrink over crimped and soldered ring terminals it gives a nice clean look as compared to black tape.
  13. Jalopy Joker
    Jalopy Joker
    Elcohaulic likes this.
  14. rockable
    rockable
    I never ground to the frame. I do ground to the body. There is nothing electrical on the frame. I ground directly to the engine and then provide some good grounding busses off the negative terminal for the low current stuff. That's just me.
  15. Malibu406
    Malibu406
    Answering a couple of questions.
    I made the battery box because I like the challenge. If I just want bolt on stuff I would build a late model Camaro.
    grounding both heads, block and chasis came from an installation guide I had from Taylor Wires. Attached 787F14BC-E24C-4E60-9F29-557F02F2F771.jpeg
    reagen, chopped, 34 GAZ and 1 other person like this.
  16. Malibu406
    Malibu406
  17. gene-koning
    gene-koning
    I run both battery cables to the front where both connect to remote battery terminals mounted on either an inner fender or the firewall in a accessible location. From the remote terminals, the cables go where ever they need to go.
    On the current project I'm considering adding a power kill switch off the battery, but I don't like the idea of a removable key. Lots of debate about the shut off being on the positive or the negative battery terminal. Gene
  18. y'sguy
    y'sguy
    from Tulsa, OK
    Truck64, Stogy, Malibu406 and 3 others like this.
  19. Fabulous50's
    Fabulous50's
    from Maine
    Disconnecting either positive or negative battery cable has the same effect.....
    As far as which is the safest one, well I dont think it males any difference.
    I too like to fabricate all my own stuff, even if something is available, for all the same reasons you stated.
    Where did you find the 150amp circuit breaker?
  20. stanlow69
    stanlow69
    I like to line my metal battery boxes with a hard cell closed foam. Also, always mount a set of remote battery posts that are easy to get to. Didn`t see a set pictured. Also, an easy place to reach while driving to to have a battery shut off switch while you are at it. Prevents theft. Always use rubber grommets when routing wires and battery cables going thru metal holes.
    Truck64, Stogy and Elcohaulic like this.
  21. Elcohaulic
    Elcohaulic
    Heat shrink is nice but when making a wiring harness, use the tape designed for harnesses.. It looks like friction tape without sticky glue. You wrap it up nice and tight then use a slip knot at the end..
    The fuses used for this have to be special. Frankly I think a self re-setting breaker would be best.. But have a disconnect lever next to the floor shifter so you can pull it after getting to a safe spot to stop.. You never want have that fuse blow while going down one of these crazy super highways we have..
    Stogy likes this.
  22. Elcohaulic
    Elcohaulic
    You want the battery in between the front and rear tires on the passenger side to get the most out of the weight.. One of the best places for the battery in on the firewall passenger side.. It helps even out the weight of the car.. Chevy was smart, they put the battery, fuel pump, starter and alternator on the passenger side to balance the cars weight. If you look at the Corvette the engine is slightly more to the passenger side.
    I read in Herb Adams suspension book you want to keep the weight in between to front and rear tires. I remember when I changed to an aluminum fuel cell and mounted it more towards the center of the car how much better the car handled..
    Stogy and lothiandon1940 like this.
  23. All interesting :confused:o_O. At least i'm subscribed now . Reason being one of my '32 Fords has a battery way out back and smokey 6V starter stuff up front :eek:.
  24. Look at almost every Mopar built...the engines are almost all off set to the right side, for steering clearance.
    As far as grounds, someone should tell all of the manufacturers that the frame isn’t a suitable place to ground the battery. If it doesn’t work then you don’t have good connections
    Stogy likes this.
  25. hotrodharry2
    hotrodharry2
    from Michigan
    I've had several '40 Fords and all of them, I put the battery in the trunk. No kit, I used welding cables. I always had a kill switch I could reach from the drivers seat for safety. I had 1 emergency in many years of driving and the kill switch saved the car plus our belongings. It only took about 1/2 an hour on the roadside and I repaired the problem area and never had that problem again. I have tried both ways of having the ground go all the way back to the engine & I feel it provided the best ground to do that. As for handling, I never noticed any problems. I also had 1 = '40 Ford sedan the battery was under the rear seat, that was a pain in my butt. I'd say it's like building a Hot Rod, build it your way. Have Fun!
  26. ......I agree.:)
    hotrodharry2 likes this.
  27. squirrel
    If you have to use a wrench to disconnect the cable, then disconnecting the one that goes to ground, is safer. If it's a switch, then it probably doesn't matter...although for drag racing, NHRA requires the disconnect switch be on the side that's not grounded.
    Stogy, Fabulous50's and hotrodharry2 like this.
  28. 1971BB427
    1971BB427
    from Oregon
    All my cars have trunk mounted batteries, and all have disconnect switches. But I'm not passing NHRA tech, so my battery switches are not NHRA located at the back bumper. I locate them hidden so if I'm on a trip I can disconnect the battery and remove the key overnight when on the road.
    That Taylor wiring schematic is silly and overly complicated grounding. No reason to ever ground the heads as there's no power to the heads. And if 16 head bolts to each head isn't a good ground, then a strap wont help either.
    Stogy and loudbang like this.
  29. jazz1
    jazz1
    I used a tool box from 186DB508-783E-4C40-8CF7-C50FAEFCDD1F.jpeg parts truck in my avatar. Extra grounds came into play when I had trouble with tail lights as I was using a 12V source with low amps,,,not the way to install a wiring kit,,use a fully charged battery to eliminate electrical gremlins.
    Malibu406 likes this.
  30. Malibu406
    Malibu406
    Its a usa manufactured breaker, ebay.
