Hey fellas, So I’m in need of the 64 c10 long bed diagram if anyone knows where to find one? I’ve found a crap load on google but since I don’t know these trucks that well I’m not quite sure which one is the correct one. My truck is at a frame shop so I’m trying to give them the right information to fix it since their books don’t go that far back anymore. Any help would be greatly appreciated.
The factory assembly manuals usually have detailed diagrams of the frames. sometimes the measurements can be a tad hard to read depending on the quality of the print. Great for trying to figure out how to replace panels on the body too. There are lots of sources for them on the net. Factory Assembly Manual-americanclassic.com
Check this out, should have what you need. Open link below and scroll thru for more. http://67-72chevytrucks.com/vboard/showthread.php?t=325736
thanks! I saw those too but mine doesn’t have the X crossmember and I wasn’t sure which years the other diagrams were.
Try the " GM Heritage Center " it's a pdf file so I can't share it, but just Google that with the year of your truck.
