Technical Borg Warner Super T10 ID
Discussion in 'The Hokey Ass Message Board' started by pwrbydisel, Feb 13, 2017.
  1. pwrbydisel
    pwrbydisel
    from New York
    Hi all,
    I have a Borg Warner but i'm not sure how to identify it.
    The numbers are as follows:
    1304-065-903
    WG DIV
    2BN107378 which is on the top
    ML-344
    Thanks
  2. treb11
    treb11
  3. Bandit Billy
    Bandit Billy
    A super T-10 is all aluminum cased. 26 splined input and a 32 splined output shaft. pretty easy to identify.
  4. squirrel
    81 firebird transmission, I think. from the 2BN.... partial VIN.
  5. thorpe31
    thorpe31
    from nor-cal
    Super parts on the right in case it's been molested
  6. Bandit Billy
    Bandit Billy
    That would make sense. I recently sold a couple of 4 speed bandit cars that were super T-10s. Trans of choice from 75 and later in 4 gear Z28s and TA's.
  7. 56sedandelivery
    56sedandelivery
    You'll need the ring count on the input shaft to tell you exactly what you have. My trans has the same 1304065903 case number, has a 3 ring input shaft, and is a 2.64 first gear, 1.75 second, 1.33 third, and direct fourth. The same case could have been used in a 2.43 first, a 2.64 first, a 2.88 first, or a 3.42 first. The rear end ratio is what determined the trans gearing for the most part. I am Butch/56sedandelivery.
  8. mgtstumpy
    mgtstumpy
    • T10s were built from 1957 to 1965;
    • Super T10s (Second design) were built from 1974 to 1983. Richmond ended up taking over from B/W. Early T10 are cast iron case (Like Saginaw 4sd), later are alloy case.
    http://www.pontiacpower.org/BW.htm
    j-jock and lothiandon1940 like this.
  9. 343w
    343w
    I'm looking at a used T10 to buy, the seller doesn't know what it came out of, can anyone help me I.D. it by this # 13-04-066-905 casing
    Thanks for your help, the input has 4 grooves, 26 spines. looks like it will work for me!
  10. 343w
    343w
    Thanks guys for your help!
