Technical Pictures of 1932 ford sub rails
Discussion in 'Traditional Hot Rods' started by Colton Leigeb, Mar 2, 2021.
  1. Colton Leigeb
    Colton Leigeb
    I figured I’d make a post uploading some of the 32 ford sub rail pictures I have to help out others. I struggled to find pictures of complete sub rails since my car did not have a complete set, so I had to make them from pieces. I didn’t find too many pictures on google or here. Wanting to help others who might be in the same situation, so These are a bunch of pictures I’ve stolen from friends cars, Instagram, here on the H.A.M.B., etc. Hope someone can gain from this post. I have more but figured these were some of the more important. If you want to see more, ask me and I can post a few more that I have. Thanks for looking!
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    -Brent-, deuceguy, Tim and 1 other person like this.
  2. Fortunateson
    Fortunateson
    " To let moisture out"? Is this a fact? How is that supposed to prevent moisture getting in?
  3. Colton Leigeb
    Colton Leigeb
    Haha, Maybe I should have cut all the words out and shown just the picture itself on these. These are all just screenshots I took then posted directly here.
  4. hotrodjack33
    hotrodjack33
    Yes, sort of a gravity drains on many early Fords. Roof insert, quarter windows, rear window, deck lid...none of it was absolutely water tight.:eek:
  5. gbones32coupe
    gbones32coupe
    I used 32 roadster rails on my five window and they fit pretty good they were 1/4 the price of the 5 window rails. they are not long enough but they work. That is going to be a nice car when it's done I'm subscribed 20170811_200832.jpeg Screenshot_20210303-231312.jpeg
    Sent from my LM-Q720 using The H.A.M.B. mobile app
    The37Kid likes this.
  6. I appreciate you doing this to help others, good attitude.:)
    296ardun, Colton Leigeb and The37Kid like this.
  7. 19Eddy30
    19Eddy30
    from VA
    Best To Mock up Body to sub rails on a Frame /Gig.
    Body ,Braces , Floor ,Doors gaps ,Cowl ,B pillar & so on.
    Before Welding / Rivets any parts .it will make life easier, 32 Fords R Curvy
    Front to Back ,Top to Bottom .
    Just Gary and X38 like this.
  8. F-head
    F-head
    Roadster rails interfere with the coupe door bottoms in the rocker sill area but they can be modified to work
    Tim likes this.
  9. Great post, thanks for sharing
  10. Colton Leigeb
    Colton Leigeb
    I agree completely. I’m going through all of that right now on a 5 window and just when you think your getting close, you do something and it throws everything else off. It should go without saying, but everyone do exactly what “19Eddy30” is saying and leave everything loose till your happy. Especially if your cars on the rougher side like mine is.
  11. gbones32coupe
    gbones32coupe
    Yes you are correct but not that much work involved to make it right. The only difference I see is the length of the cowl and length of the doors on a roadster are shorter but then again my doors are made of air on the bottom so I'm just making the doors fit the sub rails
  12. gbones32coupe
    gbones32coupe
    The first photo you can see the rails will need to be extended to the front of the cowl. In the second photo you can see where the post marks end up in front of the b pillar about 2 inch difference. Just posting for any one who is interested. My car was rotted into the ground so there was nothing on the bottom. I used turn buckles to square it up. I measured the body lines to the frame my friends 32 and then used those measurements to keep it square to the frame. Image%20(6).jpeg Image%20(7).jpeg Image%20(8).jpeg
  13. gbones32coupe
    gbones32coupe
  14. alchemy
    alchemy
    FYI gbones, the subrail is supposed to stop at the back edge of the firewall foot like you pic shows. The outer skin of the cowl is all that spans that gap. No subrail up to the cowl band.
    X38 likes this.
  15. gbones32coupe
    gbones32coupe
    Oh ok well did not know that I'm doing things a little different on my car because my body is going to have a hinge on the back so I can lift it up out of the way to work on the engine. So I'm making mine a little stronger. Remember you guys do not always take my word for things I do not always know what I'm talking about.im I'm here to learn and listen.
  16. alchemy
    alchemy
    It will be real hard to get your firewall out now. It's hard enough when there isn't a subrail running under it.
  17. 19Eddy30
    19Eddy30
    from VA
    On one of my 32, I removed the Rivets (replaced with button head bolts )in the firewall legs so I can remove bolts & legs cowl bolts. So I can remove firewall with out lifting body.
    Hinge on Back ??
  18. gbones32coupe
    gbones32coupe
    Yes that is exactly what I am doing
    It will be like this but the body will be fasten down with bolts remove bolts lift body
  19. gbones32coupe
    gbones32coupe
  20. 19Eddy30
    19Eddy30
    from VA
    Very cool!!!
    A funny 32
  21. V8-m
    V8-m
    from Alaska
    Could someone measure those two cross rails width, length and depth + distance between them+ material thickness....wow!
    Thanks!
  22. The37Kid
    The37Kid
    I like that simple cut on the 2x2 frame rail setup bracket to clear the beauty line. .
    -Brent- and V8-m like this.
  23. V8-m
    V8-m
    from Alaska
    Hello quoting myself and calling for help..
    Anyone?
  24. glennpm
    glennpm
    Hi V8-m,
    - Gauge is 16
    - 15-11/16" center to center of the two channels
    - Cross chassis width determined by the mounting bolts of the sub-frame to the main frame.
    Front channel
    Rear channel
    V8-m likes this.
  25. glennpm
    glennpm
    Boy I wish these replacement sub-frames had been around when I did my roadster! I had a friend's original 32 for reference dimensions. I modified a Tudor sub-frame from a great one I bought in Ronan MT. Lots of metal forming to create the roadster sill plates.
    V8-m likes this.
  26. glennpm
    glennpm
  27. V8-m
    V8-m
    from Alaska
    @glennpm you are my hero!
    Thank you so much for measurements!
  28. glennpm
    glennpm
    Glad to help and good luck!
    Glenn
    V8-m likes this.
  29. V8-m
    V8-m
    from Alaska
    Hello again,
    Glenn, thanks measurements from you I've made cross rails. It would be awesome if somebody could measure rocker panels. I would like to make them too.
    Nailhead Jason likes this.
  30. glennpm
    glennpm
    Nice job on the sub-rail cross members!
    These are my notes on the sills. #1 starts at the back of the door with equal spacing to the front. Get yourself the stainless sill plate finishing pieces which will help in getting the sills made.
    Glenn
    V8-m likes this.
