Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. 1-SHOT
    1-SHOT
    from Denton
    That’s like trying to operate on 2 people and interchanging parts.
    Tim_with_a_T and pennafxu like this.
  2. pennafxu
    pennafxu
    from Kentucky
    Hey we do kidney transplants all the time! But I agree the rejection rate of the organs is high if the HLA-B27 compatibility isn't correct!:D
    brEad and patmanta like this.
  3. patmanta
    patmanta
    from Woburn, MA
    1. MASSACHUSETTS HAMB
    You have guessed correctly!
    pennafxu likes this.
  4. patman
    patman
    New body needs a new frame. No question about it.
    You seem to have tastes that change over time. If you have TWO projects, you can pick the one that is closest to where your head is at that day.
  5. pennafxu
    pennafxu
    from Kentucky
    The more I have been on the H.A.M.B. 10 years now, I believe I have reached an equilibrium of what is truly correct, and why hot rodders do what they do, and why the cars look as such. What looks overcooked, not right etc, etc. I don’t believe I should jump the gun and build a speedster when I haven’t even built a conventional hotrod. I haven’t really paid my hotrod dues, and 10 years has taught me that...
    brEad, Tim_with_a_T and patmanta like this.
  6. pennafxu
    pennafxu
    from Kentucky
    Removing the regulator.
    brEad, Stogy and patmanta like this.
  7. pennafxu
    pennafxu
    from Kentucky
    Finally removed
    Stogy, patmanta and LAROKE like this.
  8. patmanta
    patmanta
    from Woburn, MA
    I am with you on this. I wish I kept it simple on my own build instead of trying to do something that required constant planning and changes to the plan to get something that's really a bit beyond what a first build should be shooting for conceptually. But all we gotta do is keep doing the work and eventually we will get there regardless!
  9. pennafxu
    pennafxu
    from Kentucky
    I am slowly buying engine bits too, to hopefully fire up my flatty... other take off parts are strewn all over the garage... :confused:
    A19332FB-53DB-4698-A98E-AE5B3ABC1287.jpeg 6DAA44EE-4F20-4931-A51D-08FEA60AC559.jpeg 0CCDA6C1-3AC1-4B40-8391-270F43AF0586.jpeg 1586EB2C-BA78-48BD-A6A0-32C6B5A44D2F.jpeg E0B6DBE8-DFAC-482E-BC68-D69F846BE68F.jpeg 7D2EF5A8-5923-4301-8C48-E053109DB63A.jpeg F8EFE54A-8062-49E1-B871-C99DD5CDC407.jpeg
    This is an original 8ba fan...
    patmanta and Stogy like this.
  10. junkman8888
    junkman8888
    The easiest way to remove window regulator mounting screws is with an acetylene torch, I light the torch, stick it through the access hole in the inner door panel, then while I watch through the window opening move the torch so the heat ends up on the mounting screw bosses. Heat to red-hot then let cool, repeat as necessary. It's a lot easier/safer than welding stuff to the head of the fastener.
  11. pennafxu
    pennafxu
    from Kentucky
    I’ve done that on my model T. I just wanted to try out another method... I do appreciate you taking out the time to point this method out though. Thank you.
  12. pennafxu
    pennafxu
    from Kentucky
    Found the oil filter assembly... will get it blasted and paint it red...
  13. alchemy
    alchemy
    Pay special attention to the fitting on the inward side of the filter housing. It should have a small (1/16"-ish) hole to restrict the flow and keep the pressure high in the rest of the system. Don't loose that fitting.
  14. pennafxu
    pennafxu
    from Kentucky
    Inside the housing?
  15. alchemy
    alchemy
    The fitting on the inboard side, outside the housing. The gauge sender probably screws in the same fitting. There is no fitting inside the housing.
  16. pennafxu
    pennafxu
    from Kentucky
    Do you have a diagram?
  17. alchemy
    alchemy
  18. pennafxu
    pennafxu
    from Kentucky
    The red area correct?
    Do I need to replace the yellow filter?
    What is the blue thing?
    Where do the green X lines go? As I have the accessory oiling set up..,
    Thank you!
  19. rusty valley
    rusty valley
    the red thing is the brass fitting with a restricted orifice. In the diagram its a T that also mount the blue thing, the oil pressure sending unit. some are a T, some are not. there are 2 oil ports at the rear of the block, one can be for the sender, or live gauge, the other is the feed to the filter, green line on right. green line on left is the filter return to block. i think 8ba's have a threaded boss for it on the left near the dip stick, otherwise a boss on the oil pan itself. Yes, you replace the filter just like any other car.
  20. pennafxu
    pennafxu
    from Kentucky
    Very helpful thank you... I ask about changing the filter, as it looks metal?? Also on many K and N filters you just wash and re-oil...
    Please Advise.
  21. rusty valley
    rusty valley
    No, its a filter you replace. I buy em on ebay, by the case !
  22. alchemy
    alchemy
    Pretty sure the KN filters that are washed are for air cleaners, not oil filters. Buy a Wix cartridge for a 50 Ford and you will be fine.
    I don't remember if you did something "modern" to your oil system on your engine like changing to an almost full filter system. If you did, then you should check with whomever designed your system for the proper routing of lines and fittings. If it's just like stock, then it's all easy and just make sure your canister uses that restricted fitting on the inlet side. I'd hate to see a new engine run with low pressure.
  23. pennafxu
    pennafxu
    from Kentucky
    Yes it does have some weird pressure release/accessory oiling system... trying to search back on my thread...
  24. rusty valley
    rusty valley
    Do you have what is known as the "95%" oil system?
  25. pennafxu
    pennafxu
    from Kentucky
    I don't know if you can see here but the two tapped holes...
  26. rusty valley
    rusty valley
    there are 2 tapped ports on the big raised up boss, one vertical, one horizontal, that is the stock system, but in your photo do i see a 3rd port to the right of the big boss? if so, you have the ports for a 95% system.
  27. pennafxu
    pennafxu
    from Kentucky
    There is one... the photos got lost on my post...
  28. rusty valley
    rusty valley
    so, you have 3 ports, it could be set up like the diagram you posted. stick a wire in the horizontal port on the left, and see if it goes all the way in to the 3rd port on the right. if it does not go all the way, you have the passage blocked with a grub screw, seen in the diagram, and you are set up for the 95% system. this will not use the ford filter can, to much pressure for that, and instead uses a modern spin on filter base mounted where ever you want it.
  29. pennafxu
    pennafxu
    from Kentucky
    Ok will check it later today...
  30. pennafxu
    pennafxu
    from Kentucky
    Need to paint this... will also fix the strap
    Original starter...
    brEad likes this.
