Technical ***March 2021 Banger Meet Thread - Equinox Sacrifice For Bangers***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 1, 2021.
  1. Jiminy
    Jiminy
    Link to previous month: https://www.jalopyjournal.com/forum...r-meet-thread-6-more-weeks-shop-time.1219653/
    Old Dawg informs us there is an effort to resurrect a F.A.S.T. newsletter but it would require 400 subscribers (minimum number to attract vendors). Subscription price is unknown at this point (2021/3/1) but if you are interested send an email to [email protected].
    Coming Events: (PM Jiminy with additions/corrections)
    El Mirage May 1-2, 2021
    Santa Margarita Time Trials are scheduled for 26 June 2021! No details yet. Save the date and keep your fingers crossed!
    International Speedsters Trials & Reunion June 23rd-26th 2021 Lincoln, NE
    Bonneville Speedweek August 7th - 13th, 2021
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: [email protected]
    phone: 951-695-7313.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    New Banger Block in the Works
    http://www.jalopyjournal.com/forum/threads/new-banger-block-in-the-works.616056/
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    stillrunners and chryslerfan55 like this.
  2. V4F
    V4F
    from middle ca.
    year went to fast
  3. Already March....
    J
    winduptoy likes this.
  4. Binger
    Binger
    from wyoming
    Checking in for the month from Cheyoming!
  5. Jet96
    Jet96
    from WY
    I was going to wait til 12:43 to check in but grew impatient...
  6. Thanks for being there, Jiminy!
    Jiminy likes this.
  7. Jet96
    Jet96
    from WY
    C303079A-6683-432D-9BC9-1B0A5E987411.jpeg Hays-Cooper roadster built in the 30's, I seem to remember a modded Chevy water pump? I can't remember...
  8. Phil Damon
    Phil Damon
    from San Diego
    Can't believe it's March already!
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Checking in from SF. My 'banger build *Marches* on. Oooh. Bolted on the Cragar valve cover yesterday. Next I'll be fixing my cracked intake, setting up the linkage and running fuel lines. Can't wait to fire it up in its new configuration!
  10. Fabber McGee
    Fabber McGee
    Will you gravity feed that carb?
  11. If it was mine I'd run gravity. No need for a pump with the carb sitting below the fuel tank. Ran my Winfield like that with no problems.
    chryslerfan55 and winduptoy like this.
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Because I live in San Francisco where every street is a hill, I'm running a Holley low-PSI pump that's mounted to the inside of the frame rail.
    chryslerfan55 and Old Dawg like this.
  13. Jet96, that does look like an early Chevy head under the mods/plates- interesting way to to add 4 exhaust, but I wonder what it looks like inside/under those side plates :D
    Jet96 and winduptoy like this.
  14. denis4x4
    denis4x4
    from Colorado
    Sent my FAST card in today.
    Jet96, Old Dawg and winduptoy like this.
  15. Airborne34
    Airborne34
    from Texas
    same here,
  16. winduptoy
    winduptoy
    I really like the 5 speed in the Roadster. I have to re-train the muscle memory and not take off in second gear and run over someone thinking I'm going to back up, when really in first....
    Jet96, Binger and Old Dawg like this.
  17. BeaverMatt
    BeaverMatt
    I too sent my info to FAST and asked to be part of the gang. Is there a listing for race events like the RPM Nationals & the Santa Margarita Time Trials somewhere? I usually hear about them after they've happened. I'm especially interested in West Coast events.
  18. You'll be informed here ("Jiminy posts the events every month); facebook (Santa Margarita Ranch Time Trials) and the F.A.S.T. Newsletter (if it's able to fly)!
    BeaverMatt and s.e.charles like this.
  19. joemac05
    joemac05
    Ditto
  20. Binger
    Binger
    from wyoming
    I get confused sometimes when I drive several different cars in a day. Between the T-5 in the coupe, a standard 3 speed in the roadster and '30 chevy, 3 on the tree in the 50, 4 on the tree in the Benz and then flipped over and backwards in the 2 early Buicks, I have to stop and think how to shift them. HAHA. Lucky Ts arent hard to remember how to shift.
    stillrunners, Jet96 and winduptoy like this.
  21. OOPS! I should downloaded the pdf, instead of the email address. Try this:
    johnneilson and winduptoy like this.
  22. winduptoy
    winduptoy
    I went for a stupid fast backwards couldn't get stopped ride in the T the other day. Hung the fat toe of my boot between the other two pedals....note to self again: Wear only pointed toe cowboy boots when driving T...yehaaa
    brjnelson, Old Dawg, J.Ukrop and 3 others like this.
  23. Binger
    Binger
    from wyoming
    Ts are hard to drive between the pedals being super close, my size 13 shoe and being tall and big around I can barely fit into some T's and and cant fit behind the wheel of some. I had to give my son a driving lesson so he could test drive one I was working on.
    Old Dawg, winduptoy and Jet96 like this.
  24. Speaking of T's, welcome this one to the stable!
    It's setup for a banger, so it's staying banger powered!
    This frame used to belong to Joe Gemsa at one point..
    I gotta figure out the steering situation, as it'll be center steer.
    J.Ukrop, Carter, stillrunners and 8 others like this.
  25. railcarmover
    railcarmover
    Went from 27" diameter tire to 30.5"..fender well is full, I even have a first gear now :) working on making her swank,top,splash aprons,fenders..hey,its a sport coupe..
  26. klawockvet
    klawockvet
    Checking in from UT waiting for the new driveway to get poured so I can get the roadster out. Went to drive it the other day and it had another dead Optima battery. Since the last time it went dead the battery was disconnected so its a battery problem, not a parasitic draw. Good news is that Summit sent a new one at no charge and doesnt require the old one back. Nice guys.
    winduptoy, Dustyp489 and Jet96 like this.
  27. Supplied a few old shock parts to a friend of mine who runs a machine shop across the way from work. Been following the project since then. The first prototype was run on a metal shaper for a 100 hours or so. After a few design tweaks he ran off a set of ten for some on-road real world testing.
    Popped down the other day to see them after they'd returned from the anodisers. This is one from the set that I'll be testing. Mmm - lovely. Guess I'll be driving the Coupe every day soon.
  28. Don't scrimp or "screw around" with antique junk; when it comes to steering! Been there done that (too many times)! Last time it happened I was coming down hill (near 70 mph) entering Turn 10 at Laguna Seca! I stopped inches from the wall (thank God for Kitty Litter")! I replaced the Old 20's Franklin steering box with a brand new Schroeder! A bit of a "Knot-Head", my first crash was in 1955 (with such junk)! It was in a '33 Ford Tudor "Jalopy" @ at Western Stadium. I really don't know what failed first: the steering or some of my "Shitty" welds! (or probably a combination of both) Either way, I hit the wall and ended up upside down in the infield; with my t-shirt, helmet and goggles full of clay. I ached all over for a week! If you want to go fast use good stuff! So when you see some neat junk for steering; DON'T DO IT!......Just my two cents! (with inflation: Twenty bucks!)
  29. railcarmover
    railcarmover
    No matter what you do its still a Sport coupe..my copilot rolls his SpongeBob car seat, he in the top corner, running to the playground.. he's a car guy till there's girls and a swing set, then the tools hit the shop floor and he's gone..
