Could someone tell me if a finned aluminum Weiand timing cover will fit on a stock SBC engine with a stock water pump? Thanks in advance
Since it has a hole for an injector pump, it's not designed to be used with a water pump, at all. But if you use a long water pump, as suggested earlier, it should clear.
I have a Enderle cover and a long water pump wouldnt clear. With water pump spacers and a long water pump you could get it to clear but with the injector block off plate on it was another 1/4"or 3/8" taller. Mine was in bad shape, one of the ears broken off so I cut it up to clear a water pump riser but still alot of work. They do look good polished with f.i bed valve cover though.
Ask @Mitchell Rish he is using one in this post https://www.jalopyjournal.com/forum/threads/prefect-willys-gasser-build.958167/page-26#post-13958434
