Technical Ford spoon pedal question
Discussion in 'Traditional Hot Rods' started by 65standard, Feb 11, 2021.
  1. B5603F18-E48D-49F2-972B-CA975834CA70.jpeg C7190A3A-7DEC-43BA-8D68-7F9AECD89CF4.jpeg F0B3AAD7-E147-453F-9EF1-A135FF092C0A.jpeg E3A048DA-4097-4F9E-AEA9-D77C91F4944E.jpeg I’m building a 32 Ford from nothing. I’m trying to keep it in the late 40’s style bonneville car. I found a 1935 Ford throttle assembly and have a question.
    What is the purpose of the cup washer? There is no pocket or provision for it on my firewall. I’m using a United Pacific undrilled firewall. I know I have to cut out a slot in that indent for the pedal and drill a hole to secure the mount to the firewall.
  2. rusty valley
    rusty valley
    the cup washer goes on the inside of the firewall, holds the insulation pad, and allows access to the nut so its not buried under the insulation.
  3. Thank you for the quick response.
    rusty valley likes this.
  4. nobby
    nobby
    I am liking the transmission tunnel
    big duece and rusty valley like this.
  5. A7706BF6-524B-4DB2-8324-D05C3BDE9C15.jpeg EA4A350B-8A82-43CF-BDE2-F11B9D7EB40E.jpeg F5DF1DC0-3271-4AB0-BAB9-AD5BD8CEE692.jpeg 02A2C3C0-B693-47D5-BDF8-669493100594.jpeg 50E38E64-CF6A-41D2-9F5D-1DDE40E3A5C0.jpeg Thanks for the good words. I had to shape my own trans cover because the engine/trans is about 1-1/2” higher than stock. I just about finished the spoon pedal install. Waiting on a new return spring. Not sure if I’m going to use a firewall pad, so I may just use a regular washer.
    V8-m likes this.
  6. Atwater Mike
    Atwater Mike
    Where is the source for that spring? I need 2 of them. Beautiful project, by the way...that firewall is pristine!
  7. rusty valley
    rusty valley
    i think i got mine from C&G, but most vendors would have them i am sure
  8. It should be, it's a new UPC piece.;)
    warhorseracing likes this.
  9. $8.99 at Mac's auto parts.
    Atwater Mike likes this.
  10. Atwater Mike
    Atwater Mike
    <<$8.99 at Mac's auto parts.>>
    Thanks, @Rusty AND @65standard! I was actually getting ready to do a shaft jig to wind a couple. (Rough with wire that diameter...)
  11. That is some fine sheet metal work on that transmission cover.
  12. alchemy
    alchemy
    Caution, stick in the mud ahead: When you mount a body you will find the floorboards sit about a half inch higher than the top edge of the frame. You might need to cut up that nice trans cover to make it fit again. One of those things that happens when a fella gets in a hurry without all his parts on hand.
    fiftiescat and X38 like this.
  13. Yes, a lot of things happen when building a car from nothing. I am still fabricating and mocking it up one step, one piece at a time. I will solve each snag as they come up.
    seabeecmc likes this.
