1956 Oldsmobile air conditioning car rebuilt harmonic balancer triple grooves and a triple Groove water pump pulley four hundred bucks for the pair shipped in the US. 1956 Oldsmobile generator brackets 30 bucks shipped in the US 1949 Ford 3 speed overdrive perfect condition inside 400 prefer pick up 1950 Mercury 3-speed overdrive good shape with flywheel clutch and bellhousing $400 can get pics later of it. Model a rear cross members gold one in good shape just needs bracket trim. 50 bucks. brown one little rougher twenty bucks 1940 ford rear wishbones twenty bucks and 1940 sway bar 20 books 1940 Ford rear crossmember twenty bucks great shape. Model a front spring 20 bucks 2 model a rear springs 40 bucks each. 40 Ford front spring 40 bucks 8ba bell housing perfect shape 40 bucks. Surfaced flywheel new clutch and pressure plate with miscellaneous bolts and throwout bearing hundred books. Starter and plate 50 bucks. 1949 Cadillac lower bell housing and working hydramatic transmission a hundred bucks prefer pick up. Old hot rod front end with cut and split bones 40 bucks. 1949 Cadillac 2 barrel intake carb air cleaner and bolts 40 bucks. 1933 Ford radiator held coolant and water ,lower necks cut off but come with the prices ,good for a recore 50 bucks. All plus ship if not in description Brian 6618780676
Bttt offers? I can deliver to the Cars and Coffee show tomorrow morning in Valencia at the Kmart parking lot
Bttt.model a spring and rear wishbones sold.cad hydro gone but still have slipyolk.cad lower bell gone.
