Hot Rods Falcons... Street/Strip cars..
Discussion in 'The Hokey Ass Message Board' started by Deuces, Mar 21, 2018.
  1. MUNCIE
    MUNCIE
    from Houston
    Question for everyone - Been doing some reading and it seems that the Boss 302 was rated at 290 hp. If that's the case a slightly modified (Power Performance top end package from Summit ) 289/302 naturally aspirated engine shouldn't need aftermarket rods and the such. I guess what I am asking is a set of H - Beam rods (Crower,Scat etc.) is considered overkill or money wasted on this type of engine? I would rather put the money towards additional parts if it will just be money wasted so to speak. I plan on driving it hard but not strip time. Opinions welcomed...
  2. MUNCIE
    MUNCIE
    from Houston
    Do you guys think that this gack would require a honing or oversize bore. Engine is currently at 0.030
  3. deathrowdave
    deathrowdave
    from NKy
    It should be fine where it’s located at .
    MUNCIE, loudbang and Deuces like this.
  4. MUNCIE
    MUNCIE
    from Houston
    Bottom of the cylinder bore. The engine was locked up and I had to get it unstuck, while tapping the rods out one of the bearings dropped in and gacked it when taping the rod out
    chryslerfan55, loudbang and Deuces like this.
  5. gimpyshotrods
    gimpyshotrods
    Just make sure there isn't a burr there that would gouge the piston skirt.
    Otherwise, carry on.
  6. Deuces
    Deuces
    Run it!!!!!....
    MUNCIE, Thor1 and loudbang like this.
  7. oldiron 440
    oldiron 440
    Unless it is a 289 K code motor the stock 289/302 rods are great for knocking holes in the oil pan. 5/16 rod bolts and spindly rod ends that don't have enough material to drill for 3/8 bolts safety you need good rods if your going to run over 5000 rpm.
    Deuces, loudbang, Thor1 and 2 others like this.
  8. MUNCIE
    MUNCIE
    from Houston
    Found some Crower 4340 Sportsman rods used along with some pistons by sealed power for around $500. I’m wondering if that is a good deal and how can I check the rods to make sure they are good?
    And yes I do want to spin it above 5k occasionally! :D:D
  9. loudbang
  10. loudbang
  11. loudbang
  12. Deuces
    Deuces
  13. loudbang
  14. loudbang
  15. mickeback65
    mickeback65
  16. loudbang
  17. loudbang
  18. SilverJimmy
    SilverJimmy
    I thought “Timeout” anything’s were banned on the HAMB?!
    LOL!
  19. mickeback65
    mickeback65
    Thor1 and Deuces like this.
  20. mickeback65
    mickeback65
  21. loudbang
  22. loudbang
  23. loudbang
  24. loudbang
  25. brianf31
    brianf31
    chryslerfan55, Deuces and Thor1 like this.
  26. Thor1
    Thor1
    LB, I assume you are joshing us, but the price is $18,500. The car has been for sale on an off for the last year. I looked at it about a year ago. Price was the same then too.
  27. loudbang
    I may be old but I can still read :rolleyes:
  28. brianf31
    brianf31
    That gold looks great. I'm considering a metallic color, maybe copper or silver with some fat metal flake in it. Or maybe I just stick with the old mint green...
    chryslerfan55, Thor1 and loudbang like this.
  29. Thor1
    Thor1
    LB,
    No, I know that the ad has the wrong price. - I just figured you knew that it was $18,500 and not $185,000. Sorry for the confusion.
    chryslerfan55, Deuces and loudbang like this.
