I have what I beleieve is a 9" ford but not entirely sure but the bolt pattern is 5x4.25". I dident think they made a 9" with a bolt pattern other than 5x4.5" and 5x5.5". I have no idea what the rearend originally came from. Hoping I can just swap axles to a 5x4.5 bolt pattern. Has anyone seen this or have any idea what this could have came out of? Sent from my LM-K400 using The H.A.M.B. mobile app
First off that is not the way to measure wheel pattern. It is clearly a 9" and being it's in a Truck probably 5 on 5.5 pattern unless it's in an Econoline.
Its not the original rear to the truck, its under a 65 gmc truck and I have some 5x4.5 wheels off a mustang that will not fit lug pattern is too big. Please dont bust my balls too bad ive always measured wheels that way and never ran into this issue... Sent from my LM-K400 using The H.A.M.B. mobile app
4 They all had 5 on 4 1/4 but had IRS. The Lincoln verse I had a 9" with 5 on 4 1/2 with disk breaks.
Thanks for the help clearly im an idiot that measures wrong. Hope everyone got a laugh at my ignorance atleast. Sent from my LM-K400 using The H.A.M.B. mobile app
No body is laughing at ya because none of us knew until it gets explained to us. Your doing fine. At least you asked for help.
I'm only seeing four studs ?????????????????? Am I wrong? Is there one under the tape measure? Edit: Sorry, under closer inspection I think there are five (head slap).
I also bought a set of wheels and the guy said they came off his mustang, I measured them the same way "wrong" and they turned out to be 5x4.75. Everything makes perfect sense now... Sent from my LM-K400 using The H.A.M.B. mobile app
Don't worry about making a mistake........all of us have. At least you were smart enough to ask someone. There would be no need for this forum if we all knew everything.
This may help. Could be a early Bronco??? Ford 9 inch Tech (maliburacing.com) or here: Ford Axle History and Identification: Ford Differentials (diyford.com)
I have found what is the easiest way for me to recognize a 9" rear. Look at the nuts holding the center chunk in. If you cant get to the bottom nut with a socket, it appears to be a 9" rear.
Mercury from ‘55 up to ??? (somewhere in the ‘70s) were 5 x 5” Edsel ‘58 Corsair and Citation were 5 x 5” (I have two of those axles) Several Lincolns had 5 x 5” but I am ‘fuzzy’ on what year models, but have seen them from the ‘50s and into the ‘70s on various models. So, some of the later versions are 9” and/or 9 3/8” Ray
That would certainly have saved all the ink we have used on this thread.......................... Wait..........the internet does use ink doesn't it? It must do. I can read this as I am typing..................
