Projects Side project 56 Dodge truck
Discussion in 'Traditional Hot Rods' started by wheeldog57, Dec 13, 2020.
  1. wheeldog57
    wheeldog57
    I had posted a couple threads asking about info on 56 Dodge trucks and straight six Chevy engines. Well, my coworker asked me to get his project road worthy.
    It runs and drives but does not stop so first order of business is brakes and brake lines. It'll need a carb rebuild, new radiator, and whatever else he wants. 20201212_113700.jpg 20201212_114018.jpg 20201212_123636.jpg
  2. wheeldog57
    wheeldog57
    So far I have hit it with a pressure washer and cleaned out the carb. The power valve rod was disconnected and missing the little bitty clip. I stole one off another carb, it runs better but still falls on its face on tip in.
  3. Budget36
    Budget36
    Dang, at 17 years old, I thought they were ugly as sin (Chevy guy) but now realize what a great looking truck they are. :)
  4. Frankie47
    Frankie47
    from omaha ne.
    Love the West Coast Jr. mirrors and clearance lights.......
    osage orange and wheeldog57 like this.
  5. wheeldog57
    wheeldog57
    We believe this to be a 1961 235 transplant.
    Okie Pete, Nailhead A-V8 and adam401 like this.
  6. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    cool truck for sure. My shop truck is a 56... Been a great lil truck for sure.
    God to see another one someone is doing something with.
  7. Greg Rogers
    Greg Rogers
    Neat old truck, and that Chevy 6 should be a good one!
    wheeldog57 likes this.
  8. earlymopar
    earlymopar
    Really neat truck....just better with a slant 6 in it!
  9. wheeldog57
    wheeldog57
    So nobody cared to warn me about left-handed threads on the lugs?!?
  10. lonejacklarry
    lonejacklarry
    They are only on the driver's side. When you get to the spring shackles you will really be impressed.
  11. wheeldog57
    wheeldog57
    Both fronts were left threaded bolts- hmmmmm
    osage orange and lonejacklarry like this.
  12. wheeldog57
    wheeldog57
    Some real ummmm ingenuity here.
  13. wheeldog57
    wheeldog57
    Note the bolt with lock washer securely fastened. This I just couldn't believe. Owner found a new "shoe anchor" along with all new brake parts. He brought them over yesterday so itll go back together as time allows.
    Okie Pete and Nailhead A-V8 like this.
  14. wheeldog57
    wheeldog57
    Driver's side was much better, its getting cylinders, shoes, hoses, lines, etc.
    Okie Pete and stubbsrodandcustom like this.
  15. Rickybop
    Rickybop
    One of Mater's many cousins.
    Definitely looks to be worth the attention you're giving it.
  16. Wanderlust
    Wanderlust
    Just a little back yard farmer enginuity, nothing to worry about, carry on
    wheeldog57 and Frankie47 like this.
  17. studebaker46
    studebaker46
    From how the pass brakes were anchored and left hand studs, the brakes came apart and ruined the drum,as wanderlust stated typical farmers enginuity. Tom
  18. I gotta ask... was a Chev inline-6 in a Dodge p/u of that era a somewhat common swap, or it's just what you've been presented with?
    looks like a fun project
  19. KenC
    KenC
    First thing I did to my 56 was drill the hubs front and rear for studs. All RH thread too. I've always hated having to hang the wheel on the hub while starting bolts. Especially if the hubs had the starter pin removed so the PO could used some other 5x4.5 wheel. Yours had LH bolts on the LH side only when it left the factory. Of course parts changes are almost inevitable on 65YO truck.
    Every older vehicle I've owned had some 'creative' previous owners.
  20. I drilled mine on my ‘57 as well, I needed to be able to use shank lug nuts for the cragar wheels
  21. nobby
    nobby
    first thing i noticed is
    where is the lower back plate bolt?
    do they just have the two top ones stock?
  22. FYI those are the early style brakes, similar to the pre 48 Mopar vehicles. With the concentric adjusting bolts at the bottom. There is special tool that sets the contact area distance for both the shoes and the drum. If you dont get it right, the brakes never feel like the pedal is high or fully bled
    There is photos of a home made version of the tool also, you just need to do some searching.
    https://p15-d24.com/topic/12410-ammco-brake-tool/
    https://p15-d24.com/topic/50093-brake-adjustment-tool/
    https://p15-d24.com/topic/52713-brake-centering-tool/
    you can bleed the brakes for days.
    Frankie47 and wheeldog57 like this.
  23. KenC
    KenC
    The lower bolts are the two concentric shoe major adjusters. they serve both functions.
  24. Yes and the minor adjusters are about halfway up the backing plate
  25. mike bowling
    mike bowling
    You’re a good man to help a buddy and put aside your own projects!
  26. wheeldog57
    wheeldog57
    This is as bought by my friend Mike.
    gotta56forme likes this.
  27. wheeldog57
    wheeldog57
    Those bolts hold backing plate and steering arm too, kinda neat set up.
  28. Love those old Dodge trucks....my family had a few back in the day...they make me smile for sure...glad you got one to tinker with...
    thanks for sharing on here...
    MikeC
  29. wheeldog57
    wheeldog57
    Got some time to work on the truck this week. Plumbed new brake lines and hoses, put new shoes, greased front hubs, etc. While I was under there I noticed a chunk of frame broken off. It was part of a shock support that is missing. I'll need to fab up another support. 20211214_110023.jpg 20211214_110032.jpg 20211214_121514.jpg
    The floor was/is layers of roof flashing secured by nails and roofing cement over bolted together thin plate, yikes!
  30. wheeldog57
    wheeldog57
