Hot Rods The El Stinko ‘60 El Camino
Discussion in 'The Hokey Ass Message Board' started by lewk, Jan 5, 2021.
  1. spanners
    spanners
    Do your scalp a favour and wrap a few turns of masking tape around the splined end of the steering column. They usually take a layer of scalp every time your head comes into contact with it. I have the scars to prove it.
    Stogy, ken bogren, Baumi and 2 others like this.
  2. Yeah mine doesn't compete with these fellas, never will lol. Lewk that's a solid start man, let me go through your cul pile when you're done ;)
    Stogy, Sandgroper, loudbang and 3 others like this.
  3. Went to an old yard this week and the guy has about 15 Elky's with about 4 1960 - no 1959's.....and he's still asking for better parts for his 1960.....!
  4. wheeldog57
    wheeldog57
    Are the vortec heads compatible with your intake? I remember some have a different profile at the intake mounting surface. I hope I am mistaken.
    Stogy, loudbang and lewk like this.
  5. lewk
    lewk
    from Mt
    Yup, it’s the bolt pattern. I need a vortec specific intake. The Edelbrock is $$$ but Jegs has a $170 copy.
    Stogy, wheeldog57 and loudbang like this.
  6. lewk
    lewk
    from Mt
    Oh damn, I hadn’t seen your El Camino yet. I’ve been watching your wagon. I’ve been kinda looking at 56/57 wagons for a while. I almost got a 56. I’ll go through your thread later. I’m trying to get my butt off the couch and go weld now... it’s cold out.
  7. lewk
    lewk
    from Mt
    4 ‘60s? Sounds like heaven. Too bad I’m halfway across the country.
    Stogy and loudbang like this.
  8. lewk
    lewk
    from Mt
    So I got the last half of the smugglers compartment floor in. A couple little patches and the trans tunnel and that’s done.
    I’ve been staring at the frame and cowl and things just haven’t looked right. The car has never had matching tires on it so I’ve been thinking that was the reason things looked crooked. The frame horns ahead of the crossmember are clean and I couldn’t find any damage until I finally noticed this kink on the passenger side right by the firewall.
    They must have jumped the fucking thing or hit a curb hard.
    I feel blind not seeing that before. I’ve looked and looked for damage. I put the back of the car on jackstands and got everything dead nuts level and then check the front side to side. The passenger side is a thumb knuckle higher than the drivers. Factory tolerance is 3/16”.
    I’ve either got to get this frame straightened or buy a parts car and just swap it out. I know of a couple cars I could buy, but then I’d have another rig at my house junking up the place. My buddy strongly feels that I should be shopping for a 4x4 chassis, but I don’t think I could do that to a first gen El Camino.
  9. spanners
    spanners
    Fixing that is easy for someone with chassis alignment setup in their collision repair shop. Chain front and rear down to floor anchors , jack up under the damaged area with the application of GENTLE heat until it's the same dimensions as the other side, then add a bit more for bounce back. Could also be done in the home shop using a universal beam ( I don't know the American term for it). Not worth the hassle of swapping a frame.
    bchctybob, lewk, Stogy and 1 other person like this.
  10. loudbang
    With most of the frame shops in the USA equipped like spanners ^^^ mentioned that is a fairly easy frame to straighten.
    bchctybob, lewk and Stogy like this.
  11. lewk
    lewk
    from Mt
    Some of my decisions are cost driven. Getting a shop involved sounds expensive. I can get a parts car for $400. I guess I better price frame shops. I do have an big I beam sitting around (I assume that’s a universal beam to you). I’ll need to think about where to chain it to my X frame as the shape is weird.
  12. spanners
    spanners
    Setup time plus repair I'd guesstimate 4 hours maximum barring 'oops' moments. I used to be in collision repair in my younger days, back when stuff was repaired.
    Stogy, loudbang, lewk and 1 other person like this.
  13. 19323window
    19323window
    from wisconsin
    looks like it will be a good looking camino like those early ones
  14. Budget36
    Budget36
    Any Tech Schools near you?
    Stogy, lewk and loudbang like this.
  15. lewk
    lewk
    from Mt
    Not that does any kind of autobody stuff. The closest we get is diesel tech and welding courses at our local community college. I'm kinda in the boonies so choices are limited.
  16. Budget36
    Budget36
    I know how that is. I have a frame-chain thing that was used for straightening frames, I’ll round it up and send you a pic, might or might not work for your needs.
    Heck, didn’t think I’d find it that quick
  17. ken bogren
    ken bogren
    Or punch a hole in a old tennis ball and stick it on the shaft.
    lewk, Stogy, Cosmo49 and 1 other person like this.
  18. lewk
    lewk
    from Mt
    So this happened.
    The frame is twisted, torn, cut, and welded. I’m not having happy feelings about this frame.
  19. harpo1313
    harpo1313
    from wareham,ma
    Good move.
  20. Budget36
    Budget36
    Seems the inexpensive run-around car, will start adding up.
    Can you fix and square things up?
    lewk, loudbang and BigDogSS like this.
  21. Bruce A Lyke
    Bruce A Lyke
    Kind of a flashback to my wagon being pulled of a 4x4 suburban frame.
    Squablow, Stogy, lewk and 2 others like this.
  22. Dick Stevens
    Dick Stevens
    Hell yeah, I'm ready to watch another El Camino build! Subscribed
  23. BigDogSS
    BigDogSS
    from SoCal
    Soooo.....it is now a full-on, frame-off restoration? I hate it when that happens.....
    Stogy, lewk, 1959Nomad and 2 others like this.
  24. Jacksmith
    Jacksmith
    from Aridzona
  25. lewk
    lewk
    from Mt
    Pretty much If I keep saying it will be done by June, maybe it will happen.
  26. lewk
    lewk
    from Mt
    Oh man, my buddy keeps pushing me to make mine a 4x4. I’ve gotta hurry up and get it low so he’ll calm down.
    brEad, Stogy and loudbang like this.
  27. lewk
    lewk
    from Mt
    It’s frame harvesting season. Luckily, my buddy and his uncle with an excavator were around to help. The junkyard guy has a pretty badass old Chevy V8 powered forklift too.
    We (I) missed the parking brake cable and when it broke as the excavator rotated that body started spinning and bobbing. I nearly had to buy a Subaru. Missed it by 3”.
    Not bad for a Saturday.
  28. bchctybob
    bchctybob
    So you just need to convince Lloyd that his Gasser Camino needs a nice 2x4 rectangular tubing front clip for the straight axle conversion and he needs to donate that heavy old factory stuff to your project.
    427 sleeper, loudbang and lewk like this.
  29. Jacksmith
    Jacksmith
    from Aridzona
    Like watching a fine ballet!
  30. Are the sedan and Camino frames the same? I always assumed the Camino, wagon and convertible frames would have been strengthened somehow.
    Cosmo49 and Stogy like this.
