Projects Swedish 34 Ford Fordor
Discussion in 'The Hokey Ass Message Board' started by Tomastudor, Apr 29, 2020.
  1. Gary Addcox
    Gary Addcox
    I really like your extended bracket off the pumpkin for the stabilizer bar. The longer, the better. Really nice build.
  2. Gary Addcox
    Gary Addcox
    That chop is perfect. It keeps the civilians guessing. A slightly chopped 4 door is the shits, in a great way. You're doing super work, especially with what you started with.
  3. Gary Addcox
    Gary Addcox
    I think you you have really killed it on the build of your '36 bars with the added bars on top. Many American builders who use the '36 bars don't do this and I think it is a mistake. My '34 had just the '36s but I only had 175 horsepower. That thing wouldn't pull someone's tooth. Again, you are putting thought into this ride. Great job, Bud !
  4. Tomastudor
    Tomastudor
  5. Johnboy34
    Johnboy34
    from Seattle,Wa
    I'll add another atta boy! Great job you've done so far on the build. When you get your second wind you have way less to do than what you've already accomplished! You'll get a lot of years of enjoyment driving it!
    Sent from my SM-G973U using The H.A.M.B. mobile app
    fegsta and loudbang like this.
  6. Tomastudor
    Tomastudor
    After the engine I rebuild the transmission a 89 Th 700 R4 it will have a FTI 2400 stall converter.
    I beefed it up with Alto reds and Kolene steel, wider 2-4 band .500 boost valve, corvette servo and a B&M shift improver kit. It was the first time I rebuilt a 700 transmission a little tricky with the seals but Youtube can be helpful. 20201008_104003.jpg 20201008_104504.jpg 20201018_100315.jpg 20201028_183114.jpg 20201029_112849.jpg
    brEad, AndersF, 47chevycoupe and 4 others like this.
  7. I like your transmission cradle. Do you run the bolt in, and use jamb nut to hold it in place? Does the whole thing mount on an engine type stand?
    nunattax and loudbang like this.
  8. Tomastudor
    Tomastudor
    Nice that you like it, Its a 5/8 rod that fits in the hole on the trans on the backside and on the front a M16 bolt that fits in the opposite hole no jam nut. There is a 3/8 bolt ont top of the trans that presses on the case and it fits in a engine stand.
    47chevycoupe and loudbang like this.
  9. Tomastudor
    Tomastudor
    I have assembled th 3rd member its a case that I had laying around and a old TracLoc differential the gears are used Ford 3.70s . I did not get the contact pattern thast I wanted I think the gearset is pretty worn but will see how it works. I want to use a pair of Edelbrock valve covers with no holes so I have modified the Performer EPS intake, A AN8 fitting in the front of the intake that goes to the PCV valve, I will also fill oil via the AN fitting. On the back of the intake there is a AN 6 fitting that will take air from the aircleaner. 20201108_131458.jpg 20201103_152153.jpg 20201103_152240.jpg 20201109_114343.jpg 20201109_114431.jpg
  10. Tomastudor
    Tomastudor
    Engine transmission and 3rd member painted. 20201111_151725.jpg 20201111_151735.jpg 20201115_102842.jpg 20201115_183545.jpg 20201115_183637.jpg
  11. Fortunateson
    Fortunateson
    Stogy, Baumi and loudbang like this.
  12. Tomastudor
    Tomastudor
    Time to do some fabricating I have made brackets for the headlights, I want them as low as possible and still be able to steer and open the hood. The headlights are 34 Ford commercial . 20201120_152133.jpg 20201120_152144.jpg 20201120_154407.jpg 20201120_154852.jpg
    brEad, kidcampbell71 and nunattax like this.
  13. loudbang
    Will those low lights pass inspection in Sweden?
    brady1929 likes this.
  14. Fabulous50's
    Fabulous50's
    from Maine
    Very nice fab work! I'm just a bit sad the flattie V8 isnt in it.
    From all your pictures, Sweden looks just like northern Maine USA where I live.
  15. Tomastudor
    Tomastudor
  16. Tomastudor
    Tomastudor
    Have made brackets for the tail lights and a frame for the rear license plate . 20201122_150639.jpg 20201122_151142.jpg 20201122_151203.jpg 20201125_155645.jpg 20201126_122011.jpg
    brEad, chryslerfan55, pwschuh and 7 others like this.
  17. Tomastudor
    Tomastudor
    I have bought a flexplate made by Scat it was a little bit concave it came very close to the starter gear and far away from the converter so I made a 3 mm spacer between the crank and flexplate, now its fine I think. Also started to make tke cooler lines for the transmission. And installed the dipstick for the Th700. 20201205_132841.jpg 20201208_153204.jpg 20201220_115906.jpg 20201220_115912.jpg
    brEad, chryslerfan55, AndersF and 3 others like this.
  18. Tomastudor
    Tomastudor
    I tought that the uppershock mounts were a little to tall so I shorted them and painted them black .
    Painted the transmission oilpan and a lot of small parts. Have aslso installed my March Performance AC , gen, PS pump and water pump drive kit. 20201231_153252.jpg 20201231_153515.jpg 20210102_074056.jpg 20210102_074105.jpg 20210102_101703.jpg
  19. Tomastudor
    Tomastudor
    The lower radiator hose that I bought was a little bit to short and the motor mount was in its way so I had a piece of 1 3/4" exhaust pipe and now it fits. Its tight between the AC compressor and fan but I think it will work. 20210102_102146.jpg 20210102_102200.jpg 20210104_152302.jpg 20210105_102238.jpg
    brEad, loudbang and chryslerfan55 like this.
  20. nunattax
    nunattax
    from IRELAND
    i currently have a green stripe flex hose on my truck.its stiff and doesnt like to bend too tight.also have 2 gates hoses i purchased #20242 and gates#20225.20242 was too short for my application #20225 looks an option for me but id have to trim the ends. havnt gotten round to fitting it yet.i could take a few photos if u like .finding a suitable bottom hose has been breaking my chops for a long time .be glad to help /compare if i could..ideal solution is a single hose for no leaks chris
  21. Tomastudor
    Tomastudor
    Thanks I think the one I modified is a 20242 do you have any pics of the 20225? Thomas
  22. nunattax
    nunattax
    from IRELAND
    ill take some tomorrow
  23. nunattax
    nunattax
    from IRELAND
    bottom hose pictures 20242 and 20225 comparison bottom rad hoses 001.JPG bottom rad hoses 002.JPG bottom rad hoses 003.JPG bottom rad hoses 001.JPG bottom rad hoses 002.JPG bottom rad hoses 003.JPG
    brEad and loudbang like this.
  24. nunattax
    nunattax
    from IRELAND
  25. nunattax
    nunattax
    from IRELAND
    rad end .if u need more photos or measurements shout.
  26. gonzo
    gonzo
    Great looking car. Nice work.
  27. Tomastudor
    Tomastudor
  28. Tomastudor
    Tomastudor
    I have bought a 42 mm polished stainless pipe from a company that makes handrails and some 5 mm thick plates and made a rear spreader bar. The front bar is from CW Moss. 20210211_110639.jpg 20210211_123608.jpg 20210211_123737.jpg 20210216_114216.jpg 20210221_115542.jpg
    brEad, loudbang, Shadow Creek and 2 others like this.
  29. nunattax
    nunattax
    from IRELAND
    i like the spacer behind the throttle pedal .home made?. discreet man.keep us informed on the sniper injection .interested in it.
  30. Tomastudor
    Tomastudor
    Yes its home made a piece of a 40x40x3 square tubing. The angle of the pedal was really strange without it.
    nunattax likes this.
