Projects 1927 T Roadster Build
Discussion in 'Traditional Hot Rods' started by Joe Coughlin, Dec 16, 2020.
  1. Joe Coughlin
    Joe Coughlin
    Some pictures of cutting the original dash and welding in the dash panel. I cut a relief in the new dash panel for the steering column. A piece of 1/8 inch plate was added to the back to reinforce the area around the steering column. I tried a few different ways of doing a steering column mount and this seemed the cleanest way. I added a plate at the top of the relief and used a correct size exhaust clamp to mount the steering column to the dash. I was quite happy with the result
  2. HemiTCoupe
    HemiTCoupe
    from TN.
    You have given me many idea's. I am working my "T", and I am doing floors, and fire wall now. Although mine has a V8/200r4, it's different, but the same. I never stop getting idea's on things I have yet to do, from many others. Thanks, Pat
    Joe Coughlin likes this.
  3. Joe Coughlin
    Joe Coughlin
    The HAMB is a great place for information and inspiration
    kidcampbell71 and HemiTCoupe like this.
  4. Nice work, subscribed
  5. Tim
    Tim
    from KCMO
    I always love T on A chassis builds because they with out fail are full of clever little tricks and ideas. Loving this one
    sko_ford, HemiTCoupe and Joe Coughlin like this.
  6. Lovely - a bit of T and A always gets my attention.
  7. Joe Coughlin
    Joe Coughlin
    Everybody has there own way of tackling the little problems of mounting the Ts on the A chassis.
    Tim likes this.
  8. Joe Coughlin
    Joe Coughlin
    Thanks
  9. Joe Coughlin
    Joe Coughlin
    LOL
  10. Joe Coughlin
    Joe Coughlin
    Some pictures of fitting the 28-29 Model A gauges to the new dash. Because I didn’t have a cowl fuel tank to fill the fuel gauge hole in the dash i modified it to fit the light switch and high beam indicator light. I also installed the reproduction choke cable for a later model ford
    IMG_6476.JPG IMG_7182.JPG IMG_7185.JPG IMG_7186.JPG IMG_7424.JPG IMG_7445.JPG IMG_8673.JPG
  11. Joe Coughlin
    Joe Coughlin
    I wanted to share the pictures of the the fuel tank and battery box in the trunk of the roadster. I built a frame under the floor to support the weight of the fuel and the battery, covered it with the original floor and mounted everything on top. The frame was built from 1/8 in channel and is bolted into the car so it can be removed in case I need to make changes.
    IMG_6953.JPG IMG_6955.JPG IMG_6966.JPG IMG_6968.JPG IMG_7005.JPG IMG_7057.JPG IMG_7010.JPG IMG_7030.JPG IMG_7033.JPG IMG_7035.JPG IMG_7036.JPG IMG_7038.JPG IMG_7086.JPG IMG_7088.JPG IMG_7089.JPG
  12. Mr Last Minute
    Mr Last Minute
    Love the work you did on the dash. If I can work out how to subscribe to this build I will!
  13. JB401
    JB401
    I am enjoying what you are doing here. A T roadster is a contender for my next project if an affordable body pops up. You have some sheet metal skills for sure. I will be following along for updates
  14. Joe Coughlin
    Joe Coughlin
    Thanks
  15. Joe Coughlin
    Joe Coughlin
    Thanks, complete T roadster body's seem a little harder to find than other body styles
  16. Joe Coughlin
    Joe Coughlin
    Some pictures of the drivers side bun panel replacement.
    IMG_6600.JPG IMG_6601.JPG IMG_6610.JPG IMG_6621.JPG IMG_6624.JPG IMG_6629.JPG IMG_6630.JPG
  17. As far as I’m aware, if you post a message in a thread, then you are automatically ‘subscribed’ to it and you'll get notifications of new posts. If you look near the top of a thread, just under and to the right of the thread title, you’ll see ‘Watch Thread’. Click on that and you’ll be able to ‘subscribe/watch’. If it says ‘Unwatch Thread’, then you are already ‘subscribed/watching’ it.
    Hope this helps.
    Great work on the bun panel. I still dream of building a T roadster one day.
    Glen.
  18. rusty valley
    rusty valley
    nice work. may i ask, how did you roll over the rear curve that attaches to the body brace near your green rol lock disc?
  19. Joe Coughlin
    Joe Coughlin
    Thanks Glen
  20. Joe Coughlin
    Joe Coughlin
    I had to weld a strip of steel up the back because the patch panel just came to a stop there.
    rusty valley and alanp561 like this.
  21. Spocker
    Spocker
    IMG_2963.JPG Here's one I put together last year in Calgary. It's not 100% finished but it's close
  22. Blue One
    Blue One
    from Alberta
    Just replying to a thread doesn’t automatically give you notifications when someone else posts or when the original poster updates the thread.
    You have to choose to subscribe to a thread yourself.
    dana barlow and loudbang like this.
  23. Ahh, thanks for that, I got it wrong... sorry.
    :oops:
  24. roen132
    roen132
    Metal work looks great!!awesome build
  25. Joe Coughlin
    Joe Coughlin
    That’s a good looking car. What area of Calgary are you in?
  26. Joe Coughlin
    Joe Coughlin
    Thanks
  27. Jacob Foster
    Jacob Foster
    Joe Coughlin and loudbang like this.
  28. Spocker
    Spocker
    The car is in the SW , most of the work was done at Highwood R&C by myself. That body was in pretty bad shape too
  29. Joe Coughlin
    Joe Coughlin
    Thanks
  30. Joe Coughlin
    Joe Coughlin
    I’ve seen some of the highwood cars, you guys do some good work.
