Projects 1931 Model A Tudor build "flathead sedan"
Discussion in 'The Hokey Ass Message Board' started by Hurley50, Nov 27, 2018.
  1. Hurley50
    Hurley50
    from NC
    This is great, thanks!
  2. Hurley50
    Hurley50
    from NC
    Here are a few more photoshops I did of the chop. The second two images would have a 32 header with a leaned back A pillar. Big issue with that is the door hinges, got to take one out. The last one is a 5.5" chop. This is shown on a 32 frame just like my roadster, which I'm not totally ruling out ;-)
    shortypu and Nailhead Jason like this.
  3. The leaned A post and no visor really goes well with a heavy chop. The 32 Frame effect will be lost with a 6" channel won't it? Now if your going to run a 32 Gas Tank I say yes.
    The Wizzard
  4. Hurley50
    Hurley50
    from NC
    4" channel, but it wouldn't be channeled if I used the 32 frame. A lot of the channel work was done, but not enough that I can't go back.
  5. I mixed up numbers. I was thinking of my Roadster at the time, it's channeled 6". A 4" channel could work on 32 rails and if you used a 1" spacer to start leveling the flat floor on the 32 rails it might save you a ton of rework on the structure. Just thinking with the key board here.
    The Wizzard
    Hurley50 likes this.
  6. Hurley50
    Hurley50
    from NC
    Mocked up the t5 to the flathead. Made a simple stand so I can sit it on the floor.
    40FORDPU likes this.
  7. 392
    392
    Great work. I like the plan.
  8. Hurley50
    Hurley50
    from NC
    Took about 3.5” out of the stretched frame. I like this proportion better.
    I do have a 32 frame on order... so it could all change... or I will use it for the other body I have...
    Tim and Nailhead Jason like this.
  9. Hurley50
    Hurley50
    from NC
    My Dad put this engine together and got it running, this is before messing with the carb... I'll post a better video later.
    Aaron D. and Tim like this.
  10. Hurley50
    Hurley50
    from NC
  11. wstory
    wstory
    from So Calif
    Lookin like I'm about one year tardy into this conversation.
    I too am building a chopped A Tudor. Short story is, I started on the build of a Dodge Baby Hemi, not having a car to put it in. A chopped A Tudor, with pink slip, came to me almost before I was ready. So I jumped on it. A pinched 32 frame was ordered and is due mid Jan. 2021.
    I am eager to see how you have resolved "engine space",...i.e. radiator mounting and firewall. I'd rather not modify mine,....much.
  12. Hurley50
    Hurley50
    from NC
    Nice Sedan! I haven't updated this in a while.. I've been working on other things, but time to get back on this. I'll post some pics of progress. I have a 32 frame not pinched.
  13. Hurley50
    Hurley50
    from NC
    A little update. I now have a 32 frame from Blackboards. This sedan will no longer be channeled. Obviously I chopped the top which has helped the motivation, I think it looks great with a 5.5" chop. My kids and a few friends helped on chop day. Still a bunch of fitting and welding to do. IMG_3331.jpg 271065AB-27AF-43BF-B094-05CBAA9521D4.JPG IMG_3313.jpg
    Shadow Creek, RAT "T", Tim and 2 others like this.
  14. Hurley50
    Hurley50
    from NC
    Couple pics outside with the grill.
  15. Hurley50
    Hurley50
    from NC
  16. 51box
    51box
    from MA
    Looks great with that chop and 32 rails, are you still planning to do the 32 header?
  17. Hurley50
    Hurley50
    from NC
    Thanks! I am not planning on doing the 32 header at this point. I do think I'm going to section the visor so it doesn't look so heavy. .... stay tuned for that..
  18. v8flat44
    v8flat44
    Really sharp sedan and the pic with "the kids" is PRICELESS !! Love the stance too.......
  19. Hurley50
    Hurley50
    from NC
    Thanks! I try to get them a little involved...
    v8flat44 likes this.
  20. v8flat44
    v8flat44
    Thanks Hurley50...love the old "T" start up...
  21. wstory
    wstory
    from So Calif
    Ditto on the kids! They may never become Hot Rod folk but the investment of your time and love is a foundation they will benefit from as they establish their own lives..
  22. wstory
    wstory
    from So Calif
    How cool and coincidental. I have a Blackboard frame coming within a few weeks. The front crossmember is moved forward 1" which will yield a 107" wheelbase. I'm hoping to squeeze the little Hemi in w/o butchering the firewall.
    I note that your rear tires are nicely located in the wheel well. What is your rear spring set-up and are you living with the Blackboard "C" notch?
  23. Hurley50
    Hurley50
    from NC
    Nice. I have a 40 ford rear spring/rear end. It isn't totally in place yet, just mocked up where I want it.
