Hot Rods # 10 Track Roadster Build- Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jan 24, 2020.
  1. ................"ruminated"...................... I'm impressed! :)
  2. Dave G in Gansevoort
    from Upstate NY
    10 dollar word! They say I'm colleg edumucated. I dunno tho...
    Still, I was an industrial mechanic for 10 yars befor colleg. Whuda ever thot.
    Stogy and loudbang like this.
  3. Marty Strode
    Marty Strode
    Dave thanks, I encourage you to build that car, you won't be sorry. I spent a lot of my weekend on an English Wheel project, as I didn't want to weld the legs to the main frame. With the main frame being very heavy, due to the larger size, thick wall tube, it was very cumbersome to deal with. With that out of the way, work on the TR, will resume tomorrow. IMG_5716.JPG IMG_5722.JPG IMG_5723.JPG
    catdad49, Dirty Dug, OFT and 17 others like this.
  4. Dave G in Gansevoort
    from Upstate NY
    Wow! I'm telling She who must be obeyed we're moving to Oregon! That english wheel is a work of art. I don't think you will have much flex when wheeling 1/8-inch plate... At least it looks like it could handle that to me.
    catdad49, Stogy and loudbang like this.
  5. Marty Strode
    Marty Strode
    After a long hiatus, I have started back, first by mounting the grille shell to the radiator. Then, set it in place, mock up, and make the hood pattern. The grille shell brackets are 18 ga cold rolled steel, and weld to the shell and the radiator. The upper mounts will also carry the front hood latches. IMG_5817.JPG IMG_5818.JPG IMG_5819.JPG IMG_5823.JPG IMG_5826.JPG IMG_5828.JPG IMG_5829.JPG
    catdad49, Dirty Dug, OFT and 26 others like this.
  6. bymanr
    bymanr
    Glad to see you are able to use the brown paper!
  7. Marty Strode
    Marty Strode
    Thanks Rich, please keep me in mind for another roll.
  8. bymanr
    bymanr
    Will do, next time Erik and I come down for a visit.
    Stogy, Blown Red Ram and loudbang like this.
  9. Marty Strode
    Marty Strode
    Well, it looks like Bruce (Gearheads QCE) will be happy, it's going to get a quickchange. I have had this one for quite some time, it has been broken and repaired in the rear pinion support area. After reading one of Bruce's posts on the subject, I realized it could be used. Thanks Bruce, for the valuable advice ! I thought I could get away with the open drive, pickup banjo, but the driveline angle didn't look very promising, this is the solution. I will be using the ring and pinion, and the carrier from a 46 passenger car, my Brother Jerry gave me. I will need a rear cover, because I foolishly sold the Culver City one from this center, and I need to round up a 10 spline lower shaft, and yolk. These cars are a natural for a quickchange, as Track Roadsters had to be one of reasons the V-8 units were produced. IMG_5832.JPG IMG_5834.JPG IMG_5835.JPG
    catdad49, OFT, tractorguy and 12 others like this.
  10. TerrytheK
    TerrytheK
    Wow, I do believe you have everything figured out. That car has a perfect profile: proportions right on the money, nothing excess and everything has a purpose.
    Thanks for posting another great build thread!
    OFT, chryslerfan55, Stogy and 2 others like this.
  11. Marty Strode
    Marty Strode
    Terry, they haven't changed much, since I built this one in'98. Left to right, Ernie Martin, Spike Parham, Bobby Mead, and me, all great pals. I think I might still have the blue checkered shirt too ! Thanks. img20201120_0027.jpg
    catdad49, OFT, GordonC and 14 others like this.
  12. TerrytheK
    TerrytheK
    Cool track roadsters or fine wearing apparel... either way, the good stuff never goes out of style!
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  14. Dave G in Gansevoort
    from Upstate NY
    Any progress Marty? We're all feeling the drought. I need encouragement for my feeble efforts.
    j hansen, loudbang and A Boner like this.
  15. alchemy
    alchemy
    Last weekend I was paring down the remnants of a T touring body to weld together as a roadster. It'll be saved for a project similar to #10. Maybe throw in a little Eshelman influence.
    catdad49, OFT, Tman and 17 others like this.
  16. Marty Strode
    Marty Strode
    Jeff, that's a great example of having all the parts in the right places, the brace at the cowl for steering box was done very cleanly. As far as the #10, I did get the radiator mounted, and will install the support rods next, and follow with the hood. Been busy dialing in some equipment, English Wheel, and building a cart for the latest Tig Welder. More soon !
  17. Dave G in Gansevoort
    from Upstate NY
    Thanks Marty for the offer. If we were only a days drive apart I'd have been there today, but its just not possible like you said. Oh well, at least you gave me some ideas to consider if I find a T coupe around here in need of a new use.
    catdad49, chryslerfan55 and loudbang like this.
  18. That one checks off a lot of the “right” boxes for me. Thanks for sharing the pic, @alchemy!
    Stogy, chryslerfan55 and loudbang like this.
  19. Marty Strode
    Marty Strode
    I acquired my friend's fixture for assembling early Ford rear ends. He used a worn out brake drum from a Mack dump truck. He cut out a 10 ga steel disc, and drilled a bolt pattern to match the housing ends, and tack welded 7/16" nuts on one side. cut a center hole, large enough for the bearing snout to pass through, and drilled and tapped the perimeter. It works very well, using the stack and bolt method. When checking back-lash, it's waist high, for the average person. I will be using it on this project, when the time comes. IMG_5976.JPG IMG_5978.JPG IMG_5980.JPG
  20. ^^^^^^ Genius!
    Now I know what I can use my old vice stand for.
    Atwater Mike, catdad49, Stogy and 3 others like this.
  21. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Marty,
    I was just about to private message you to see if you wanted me to put that thing together for you.
    loudbang, brEad and kidcampbell71 like this.
  22. Marty Strode
    Marty Strode
    Bruce, I would do it in a minute, but the shipping would kill me. Probably cheaper to buy you a plane ticket out here ! I will be bugging you for advice.
    catdad49, bymanr, loudbang and 3 others like this.
  23. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    Yes,
    About $175 each way. I'd love to come for a visit, but I'm afraid I'd never leave. We could build some cool stuff, though.
    catdad49, OFT, GordonC and 4 others like this.
  24. Marty Strode
    Marty Strode
    Maybe we can put something together this Spring, depending on how things are. BTW, I have a 1/4 mile dirt track, 8 miles down the road. Sure sounds like fun to me !
    catdad49, Atwater Mike, Stogy and 2 others like this.
  25. alchemy
    alchemy
    How about I start shipping tin and iron out west and you guys can bolt my #11 together this spring?
    catdad49, tractorguy, Stogy and 3 others like this.
  26. Marty Strode
    Marty Strode
    Jeff, I do have an extra perimeter frame, ready to go.
    catdad49, Stogy, loudbang and 2 others like this.
  27. Marty Strode
    Marty Strode
    catdad49, bchctybob, dwollam and 16 others like this.
  28. Such cool roadsters Marty!
    catdad49 and loudbang like this.
  29. Marty Strode
    Marty Strode
    Since my progress is slow, I uncovered some pics of #7 when it was new, thought I would share them. I really enjoyed shooting pics with a Pentax with real film. The last one is my old buddy, Spike Parham, lettering the hood. img20201215_0030.jpg img20201215_0031.jpg img20201215_0032.jpg img20201215_0033.jpg img20201215_0035.jpg
    catdad49, bchctybob, dwollam and 11 others like this.
  30. Marty Strode
    Marty Strode
    On it's first outings in '98 img20201215_0036.jpg img20201215_0037.jpg img20201215_0038.jpg img20201215_0039.jpg
    catdad49, bchctybob, dwollam and 14 others like this.
