I have been dragging this around since 1978- tired of moving it. It was in my 1st 36 Ford. Has new spring shackles (well, unused) and the spring pack. It has a 63 Cadillac rear end welded to the rear radius rods from the 36. Big heavy iron plates- actually not bad for early 60’s. I was going to cut off all that, and use the rods to mount a lighter rear end; 40 years later I haven’t done it yet. Drums are 12” x 2-1/2” wide, 5 x 5” bolt pattern. A cheaper way of getting 36 radius rods, but you will need to work to get them off. Will get pictures on Friday. Selling for $200 but you have to pick it up here
Finally remembered to take pictures. I started cutting through welds but too much other stuff going on. Open to offers,thanks
