This is a very desirable and hard to find car. There has been a ton of work already done, and this is on the right track. There are thousands of dollars invested in new Sheetmetal from BobDrake, which include The floor, running boards, firewall, and inner fender wells. The cowl still needs a right lower patch, which is available through Macs, or Drakes. The frame is in excellent condition and has had a Chassis Engineering rear parallel leaf kit installed with a Ford 9” rear axle. Front has Mustang ll front crossmember with factory style upper and lower control arms. SBC/700r4 from a 85 Suburban. Was told engine was functional when installed. Spins freely. This was meticulously disassembled and every bracket, and screw is bagged and tagged. All the Sheetmetal is in good condition with no rot or rust. I have a giant box of the wood that could possibly be used for templates. Car is located 5 minutes from Detroit Metro Airport, in Brownstown, MI. 48174 $8000 or may trade for something else I don’t need. Looking for Model A roadster, or decent coupe bodies. Clear Michigan Title. (734)558-8998 (734)558-89nine8
