Technical Heater Blower Motor
Discussion in 'The Hokey Ass Message Board' started by Helloosination, Nov 7, 2020.
  1. Helloosination
    Helloosination
    I'm looking for a thinner blower motor for my heater unit so I can mount the unit a little closer to the firewall.. Anyone have any ideas? IMG_20201107_163125559.jpeg
    Sent from my moto z3 using The H.A.M.B. mobile app
  2. mkubacak
    mkubacak
    Maybe start with giving us some measurements of what you have there?
  3. seb fontana
    seb fontana
    from ct
  4. brading
    brading
    Have a look on the NAPA site they do a range of fan blower motors.
  5. Garpo
    Garpo
    Could be worth looking at the heater motor in an Aisian small cat - some are usefully small.
    Or; compact radiator fans come in a multitude of sizes, -down to about 6" or so. If they are too busy (noisey) connect though an ignition ballast resistor - knocks a lot of speed and noise off but still moves a lot of air.
    firstinsteele likes this.
  6. Blake 27
    Blake 27
    I used a Spal 7" fan with a two speed switch from Ron Francis. I re-routed the hoses with 1/2' copper and them down the inside of my firewall. HPIM0916 (2).JPG HPIM0917 (2).JPG DSC00725 (2).JPG
  7. ^^ What heater core are you using?
  8. Blake 27
    Blake 27
    The original Arvin. Copper and brass, luckily it tested good.
    30tudor likes this.
  9. Helloosination
    Helloosination
  10. Blake 27
    Blake 27
    There is quite a difference between slow and full speed. It is a roadster but slow works fine when it's not too cold, and I also installed an inline water shut off which can be partially closed to help control the amount of heat. On low it's pretty quite but on high it's a bit noisy and really puts out the heat.
    Helloosination and jim snow like this.
  11. Joe H
    Joe H
  12. Helloosination
    Helloosination
    I have no idea what it's from. Just pretty cool and thought it would work well in my 35 Cabriolet.
  13. scrap metal 48
    scrap metal 48
    I've used computer fans before.. Very thin and some are 12v.. Not as powerful as a big fan but quiet and adequate.... Could probably buy cheap at a computer repair shop....
    Helloosination likes this.
