Hot Rods bought this vintage race olds 303 today
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Feb 23, 2020.
  1. ottoman
    ottoman
    from Wisconsin
    Any decent automotive machine shop can grab a piston ring catalog and match then up by bore size and a piston to measure ring grooves... not that hard to do
  2. Fordors
    Fordors
    Jahns did sell some forged pistons but those are definitely sand cast. I know the HAMB is all about being traditional, but knurled pistons? Really?
  3. Fordors
    Fordors
    If you are sure of the diameter of the pistons Jahns BITD used 1/16” top and second rings and the oil ring is 3/16”. Common stuff, sold everywhere.
    Your 3.897 measurement plus .008 for piston to wall clearance suggests those pistons are for a .030 bored block.
  4. drumyn29
    drumyn29
    I can work with that.
  5. drumyn29
    drumyn29
    You have to remember, I live in L.A. There isn't a racer or machine shop anywhere near me. I'd have better luck trying too find and honest person here.o_O
  6. speedshifter
    speedshifter
    Wow what a find! The heads have 10 cast over center ex ports. This means they are 1956 hds. Very sought after, bigger ports & valves.It might have a "hot cam" with solid lifters & maybe adjustable rocker arms. In my opinion piston clearance is extremely excessive .Years ago we ran the same cast Jahns in dirt track racers (50 wt oil) at .007" clearance. I think you will have a lot of compression blow by. You can try knurling them for a short life band aid fix if you are not going to make a street engine .I don't know all the answers,but I built my first "hot" Olds engine 1958 & Still running a hopped up Rocket in2020. A great find, have fun. Greg
  7. bchctybob
    bchctybob
    I used to use EMS (Engine Machine Services) in Inglewood and Vellio’s in Lawndale when I lived in L.A. Both did a wide range of hot rod machine work. I would have the pistons and cylinders miked to get an accurate piston-to-cylinder wall number. Knurling will take the rattle out of the excess clearance but it won’t last more than 10-15k miles. That may be ok for a fairgrounds cruiser.
  8. drumyn29
    drumyn29
    Well, I was just told that no one has ever made replacement connecting rod bearings for 1949 olds, so I guess I will be moving up to 1950-1956 connecting rods.
    Slowly getting it built, one concrete foot at a time.
  9. bchctybob
    bchctybob
  10. gonzo
    gonzo
    Those valve covers are cool, any more info on those?
    Speedy Canuck and loudbang like this.
  11. drumyn29
    drumyn29
    nada
  12. Black Panther
    Black Panther
    from SoCal
    I bought that engine originally from the family of the original builder. It was listed here on the hamb by them, years ago. The valve covers are handmade and super light. Even when new they probably did about a 75% job in keeping the oil where its supposed to be. They probably weigh half as much as a stock tin cover...theyre super cool, early 60s period race stuff.
  13. gonzo
    gonzo
    Very neat. Thanks for the info.
    loudbang and Stogy like this.
  14. Ericnova72
    Ericnova72
    from Michigan
    Instead of knurling, you might check into Line-2-Line coatings, they have a high build abradeable skirt coating that is also a graphite lubrication style sacrificial coating, that can do a pretty large clearance build-up. Much the same as what is coming on new production coated pistons.
    Coat to reduce clearance more than needed, then the coating clearances itself in operation. A lot more stable than knurling, longer life too.
  15. ottoman
    ottoman
    from Wisconsin
    I second using this coating... we used it (or a similar product) for years with great results
    loudbang, kidcampbell71 and Stogy like this.
  16. pirate
    pirate
    from Alabama
    Had to chuckle a bit looking at “terms” toward the bottom where it says COD (cash on delivery) have to have a few years behind you to know what that means in this day where most things are pre-paid or paid for with credit card.
  17. greybeard360
    greybeard360
    Did you measure the pistons on the skirt or at the top next to the top sing groove? That could explain the excess clearance. Pistons are smaller above the top ring.
  18. drumyn29
    drumyn29
    I'm going to drag my engine and pistons back to my machinist and have him properly measure my bore and piston, my tools suck!
    I guess I need to find a set of 303 olds rods also since there are no aftermarket bearings for 1949!:mad:
  19. drumyn29
    drumyn29
