Technical Free Up Stuck Zipper -Fixed
Discussion in 'The Hokey Ass Message Board' started by ken bogren, Oct 28, 2020.
  1. ken bogren
    ken bogren
    I picked up this door pocket for my 61 F100 several years ago and never got the zipper to move. Any suggestions. zip-1.jpg
  2. ken bogren
    ken bogren
    Here's the plastic pocket itself for anyone who hasn't seen one.
  3. fortynut
    fortynut
    Tomato ketchup. Let it soak. Then use Dawn Dishwashing Liquid as a lubricant. The ketchup has acetic acid and the tomato in it will react with the brass to free up whatever crud is built up. Soap is a good lubricant. Lot of people use bar soap on the bottom of wooden drawers to make them slide. If this fails use some white lithium grease. It does wonders with cranky locking mechanisms.
  4. Casey Riley
    Casey Riley
    from Minnesota
  5. Rckt98
    Rckt98
    Candle wax.
    pitman, 1oldtimer and Paul like this.
  6. Kroil will help to getack to normal
  7. dan31
    dan31
    2x on the clap stick ,bar soap to stop it from happening again, also works great on snaps ( boat covers, ect )
    Mr48chev likes this.
  8. ken bogren
    ken bogren
    Thanks guys. I had already tried WD40 with no luk, I'll try these suggestions, probably not all at one .
    chryslerfan55 and Mr48chev like this.
  9. Mr48chev
    Give us some feedback on how it came out, I have some zippers on my boat canvas that are the same as that that need some attention.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    fauj and alanp561 like this.
  11. Mimilan
    Mimilan
    That can sometimes make them worse.
    Soak the area with white vinegar and leave it overnight. It will disolve any oxidation.
    Usually the WD40 will create a barrier for the vinegar.
    Once you get it freed, use skateboard graphite as a lube
  12. Graphite powder is great and crap doesn’t stick to it.
    The key is to get it moving forward first before trying to undo.
    03GMCSonoma likes this.
  13. pitman
    pitman
    ^^^ Nothing like a
    'rolling-start'!
    Barrelnose pickup likes this.
  14. 62SY4
    62SY4
    from Irwin, Pa
    Lanolin...ie GOJO. It will lubricate and not harm the vinyl. Some of these suggestions could wreck that white vinyl.
    I have one of these pockets NOS for my '64 (it's also hard to zip) Some of the battle you are facing is the plasticizers have left in the last 50 years and the material has shrunk, removing from the box should have helped some, but there is residual tension on the zipper, the arc adds another layer of difficulty
    Boneyard51 likes this.
  15. Have a shop that does boat canvas,or leather repair sew in a new one. A local shoe repair sewed a new zipper in my 50 year old motorcycle jacket,and it didnt cost a fortune.Who ever said if its got tits,or a automatic transmission eventually it will give you trouble forgot zippers.........
    seb fontana likes this.
  16. 62SY4
    62SY4
    from Irwin, Pa
    That's an option, bit you still have 50 year old material. Bob Drake offers a pair of repop door pockets, with new chrome plastic trim for around $200. I will say the repop pockets are nice, but they only come in black vinyl and the material is not as heavy as the originals.
  17. ken bogren
    ken bogren
    That's an idea, but if I went that route I think I'd have them make a whole new thing, zipper and nice shiny white vinyl.
    I have thought about just skipping the vinyl thing and just installing the pocket and trim. It almost seems like the vinyl might make the pocket less usable.
    But I like the isea of getting the zipper working, anyhow.
  18. Mimilan
    Mimilan
    Use the white vinegar trick, and be patient.
    Also could you show us a "Close-up" of the slider from the other side. [the puller]
    Some sliders are of the "locking type" with a metal locking spring with a tooth that locks into the zip.
    If you pull too hard on one of these it will damage the zip.
    You need to get a needle under the spring and lift it [and slide it]
    These type of sliders are very common on Tents where a zip is sometimes left halfway
    jnaki likes this.
  19. alanp561
    alanp561
    I'm pretty sure a "clap stick" isn't what you intended for use;)
    dan31 likes this.
  20. ken bogren
    ken bogren
  21. ken bogren
    ken bogren
    Wel I've soaked a few inches of the zipper (at the clasp) in white vineger for about three days to no avail.
  22. patsurf
    patsurf
    this sounds just like me being told to use "c l r" for a carb dip-it will look new!!well,no....
  23. 54vicky
    54vicky
    zip-6_LI.jpg it looks as if the material on edge is caught under zipper.the one side shows more teeth than other which I think is if material is caught and it was forced down it may have jammed may try closing it will be hard but may be only way.once (if)closed than lubing with wax etc hopefully it will work.good luck
    X-cpe and jnaki like this.
  24. Kiwi 4d
    Kiwi 4d
    If its still stuck, get a quick un pick for sewing stitches . Get your upholstery shop to fit a new zipper.
  25. ken bogren
    ken bogren
    BINGO! That insight made it possible to get the zipper fully open! THANKS!
    I grabbed the tab with a pair of pliers and pushed it back towards Open and the towards open a bit less, a few teeth at a time. Once I got past the caught material I just kept working the tab abck and forth a few teeth at a time until it finally popped open a few inches at a time.
    Still very dirty, but at least it works, now to clean it up so it works smoothly.
  26. 54vicky
    54vicky
    happy that it worked for you I have had it happen more times than I can count.
