Projects 1941 Chevy Sedan Build Thread
Discussion in 'The Hokey Ass Message Board' started by Voh, May 8, 2011.
  1. Voh
    Voh
    Got the flange shaped to the body and the fender opening enlarged. No turning back now.
    TFoch and Shadow Creek like this.
  2. Voh
    Voh
    My ‘41 didn’t have any parking lights when i got it. I watched for some for quite a while with no luck. After looking at different cars a the shows, I decided on those from late 40’s fords. Thoughts?
    TFoch likes this.
  3. 6inarow
    6inarow
    No on the Ford parking lights. the stock ones are a nice looking feature in the 41 IMO
  4. Voh
    Voh
    After a number of years, I finally pulled the trigger on the wheels for the sedan. I opted for the US Wheel, Deuce style. The rears are 15x6 and the fronts are 16x4.5. The plan is for Firestone 820-15 on the rear and Firestone 650-16 on the front. will also be running the '41 caps on the fronts. IMG_0004[1].JPG IMG_0005[1].JPG
    TFoch likes this.
  5. Voh
    Voh
    Tires got here yesterday!
    6inarow and TFoch like this.
  6. Can't wait to see the look of it sitting on the ground!
  7. Voh
    Voh
    I picked up the wheels from powder coat on Friday! Very happy with the turnout. IMG_0482[1].JPG
    juan motime, chryslerfan55 and Uribe like this.
  8. Voh
    Voh
    I was able to get the tires mounted up last week and tested them on the car friday. the rear works, the fronts are too big. Now I have a pair of tires forsale.
  9. Voh
    Voh
    Accidentally posted this on my tire size thread.
    chryslerfan55 and Shadow Creek like this.
  10. Voh
    Voh
    Was able to get the drivers side on Saturday.
    And thought i would show some fun pics of the shop
  11. Voh
    Voh
    Rolled it out to day to sweep the floor.
    Shadow Creek and chryslerfan55 like this.
  12. brokedownbiker
    brokedownbiker
    I really like the skirts on your sedan, I've been wondering what my car would look like with them. It hasn't been easy to find pix of the sedans with skirts so I was pleasantly surprised to find this build thread. You've got metal fab skills that are waaaaaay beyond mine, it is always amazing to me to see how easy you guys make it look, lol.
    I have the same car, 1941 2 door sedan with Mustang 2 front suspension. I've got a 283 with a TH350 behind it, 4 wheel disc brakes. It is the most comfortable and easiest driving car I own, the ride quality is almost as good as my 2010 Challenger (and much more fun to drive). You'll be happy with yours when you get it on the road, I'm sure!
  13. Voh
    Voh
    thank you @brokedownbiker. My skills are nearly that of the others I see, but might not be to bad for a weekender.
  14. Voh
    Voh
    Worked on the exhaust this weekend. Passenger side went well. Drivers side will take a little more time until I get clear of the steering shaft, then it should be a mirror image of the passenger side. trying to decide if I should fight it up and over the axle or sneak under it.
    Shadow Creek and 72yenkonova like this.
  15. Voh
    Voh
    was able to get the drivers site tacked together from the manifold to the muffler and welded the passenger side up fully.
  16. buick bill
    buick bill
    from yreka;ca
    just found your thread .thnx to rainy day and corona ! likin what im seein ! keep on keepi on . ive got a 41 sd coupe . my latest obsesion . kinda going a little different route .235 3spd. etc. .stock trans. and rear for now .but im going to do a 69 nova 3spd and rear.real soon. did you use the stock rear leafs? ive been told if you flip frnt to back the pins come out in the right location !? my frnt steered as bad as yours and everyone elses . had the stock shocks rblt and it steers way better but i havnt got a real alginement yet , so im hopeful it will be alot better! probably will end up not happy that i didnt go with the pinto setup , but i was trying to keep it period correct ! anyway , grt car .ill be watching the progress . these 41s are totally kool .luv the direction your going 41-chevy-spec-deluxe-2-630x420.jpg 1941-Chevrolet-Special-Deluxe.jpg
    indianbullet and 72yenkonova like this.
  17. Voh
    Voh
    Couple of questions. On both sides, have some issues at the outer edges of the taillight pad, including a couple of holes. Looks like someone even brazed it at some point. I have been trying to decide what the best plan of attack might be. One of which is frenching the factory taillights. Any suggestions?
  18. 1971BB427
    1971BB427
    from Oregon
    [QUOTE="buick bill, post: 13822524, member: 70121 did you use the stock rear leafs? ive been told if you flip frnt to back the pins come out in the right location !? [/QUOTE]
    No, incorrect. The rear springs have the same distance centering pin to eye both directions. But what you can do is disassemble the stack, and use a carbide 3/8" drill bit to drill a new center hole in the main leaf. Then the other leafs can be bolted back to the stack to make it centered. Usually have to remove or trim the longest leaf before reassembling though.
    My '39 Chev coupe sat way too high, so I tossed all but my main leaf, and used flatter leafs from a '58 Chev 1/2 ton front axle. I put 3 on for a total of 4 leafs, to get the stance I wanted.
    chryslerfan55 and 72yenkonova like this.
  19. Voh
    Voh
    Little work here and there on it this weekend. But rolled it out both days to clean the shop and look at it outside. IMG_6414[1].JPG
  20. 1971BB427
    1971BB427
    from Oregon
    Always better to get them outside so you can stand further back and really see what's going on with the stance. Working up close all the time is almost like building them with blinders on your eyes! Until you can get back, you just don't know for sure what you have going.
  21. long island vic
    long island vic
    60 s internat8onal pickup front springs are the correct center
  22. Voh
    Voh
    Was able to get into the shop a bit this weekend. Got the taillights frenched in.
    Many stated how the factory lights are iconic, but there were some issues with the mounting pad areas.
  23. Voh
    Voh
    The taillights compliment the new recessed turn signals.
    72yenkonova likes this.
  24. Voh
    Voh
    Chipping away on different parts of the project. This weekend I was able to get a couple coats of paint on the dash. IMG_7796[1].JPG
  25. Voh
    Voh
    Was able to get some time on the headlights this weekend. Started out with 54' mercury rings from speedway. Trimmed, pie cut and shaped them to fit. The headlights are currently on the backside and offset back 7/8".
  26. Voh
    Voh
    No pictures to add, but I was able to finally get the brakes bled this weekend. took some pedal massaging, but we are good to go. Another milestone complete.
    Also some frustration, as this can of all-metal seems to have expired, as I cant get it to set. Will need to wire wheel it back off.
  27. buick bill
    buick bill
    from yreka;ca
    how are you liking the huck brakes ?
  28. Voh
    Voh
    Haven't driven it yet. quickly working on that task.
  29. Voh
    Voh
    The dash is back in and i have started running the wires.
  30. Voh
    Voh
    Just for looks.
    Shadow Creek likes this.
