Technical Need advice on how to fix a bounce rear end
Discussion in 'Traditional Hot Rods' started by Lowbow38, Oct 23, 2020.
  1. Take the Lowering Block's out & it will Ride Great!
    Just my 3/5 cents
    Live Learn & Die a Fool
    deathrowdave likes this.
  2. ...if the u-bolts were the correct length, there wouldn't be a scrub issue...
    Just Gary likes this.
  3. Lowbow38
    Lowbow38
    Thank you all for giving me insight in what I need to look at and figure out and fix. I’m going to see what I can do about getting the leaf springs from being flat and I will cut the ubolts down so they aren’t that close to the ground. There’s a lot of work that still needs done on this truck. I was also thinking about removing the leaf spring set up all together and C notch the frame and put a 4 link system in to.
  4. Weedburner 40
    Weedburner 40
    Also, your shocks original application if 63 to 82 Corvette IRS, so they are valved stiff. The springs are going to be stiff as their original application is a Dodge four wheel drive pick up front spring. Eaton-Detroit does make a replacement spring for the CE application that works much better, but they aren't cheap. Hope this helps.
  5. Lowbow38
    Lowbow38
    I do have a question about the leaf spring pack itself. One the top leaf I have one eye that is pointing down and one that is pointing up, how should I have the eyes when everything is bolted up? Also I noticed that at my center point of my leaf springs that the leafs are longer in one direction. What direction should I have the leaf with more material going. Sorry to have questions that might both you all, I’ve been a VW guy for ever and I’m just getting into old fords
  6. Questions don't bother anyone here. Everyone is more than happy to help. The only flack people get is when they have already made up their mind about how to do something, ask anyways and then argue with the advice given if it doesn't match what they had already decided to do. You are trying to learn and have a good attitude about it. You will get lots of help.
    Sent from my SM-G950W using The H.A.M.B. mobile app
  7. olscrounger
    olscrounger
    Lots of good info given--the eye on the end facing down is a reversed eye-lowers about 1 1/2? maybe
    Weedburner 40 above can fix you up with the right parts I'm sure--used many of his parts on 40's
  8. Atwater Mike
    Atwater Mike
    ONCE the geometry gets 'adjusted', take note of shock rates. Monroe shocks come in variables: 10/90, 20/80, etc. We found on light cars ('28-'32 fenderless 1800 lb. typival) a 30/70 shock worked best. (30 'easy' in, 70 'hard' out)
  9. Happydaze
    Happydaze
    Ref the unequal lengths of the spring from the 'center point', it makes no difference, as long as the wheels are where you want them to be in the arches - and the same on both sides, naturally!
    Chris
  10. Ebbsspeed
    Ebbsspeed
    After a couple flat tires at speed the scrub line will be OK.
  11. Lowbow38
    Lowbow38
    I’ll take care of those Ubolts once I get the rear end suspension dialed in
    bchctybob likes this.
  12. Country Joe
    Country Joe
    I have a Chassis Engineering leaf spring kit on my car. I took the smallest leaf out to soften the ride but, it got very bouncy as you described. I put it back in and it settled down. I also called CE and they told me the correct length the shock should be as it sits. I was bottoming out due to the shocks being too compressed at rest. I corrected that and it works great now.
    And, my springs are also longer from the leaf pin forward than back.
  13. Almost always, the longer side of a leaf pack is to the rear.
  14. grumpy65
    grumpy65
    :D:D:D That's funny.
    Exactly what I was thinking......................a self-remedying problem.
    olscrounger likes this.
  15. Lowbow38
    Lowbow38
    So I’m going to do a couple things to see if I can fix this issue, I’m going to put the leaf back in that took out and I’m going to modify the shackle bracket and move the mount forward a inch to see if that corrects my issue, I’ll take a better ride than the stance I have any day.
  16. Mimilan
    Mimilan
    That is a contradiction !
    Shorter springs are stiffer.
    If the springs were too soft, it wouldn't bounce until the suspension bottoms out.
    Having the axle that will arc forward is a desirable quality. It promotes roll understeer and is stable.
    The only major difference with a reverse arch is behind the axle [the shackle swings forward during compression]
    The OP needs to get a tape measure and measure the shock length at ride height.
    Then deduct enough length for when the axle hits the bump stops [allow for shock inclie axlenation]
    The Monroe 33033 shock has a length of 10.125" when fully compressed
    It could be bottoming the shocks out before the axle hits the bump stops.
    Also he should remove the bump stops and take it for a ride.
  17. grumpy65
    grumpy65
    The smart option.
    If you can't drive it because it's too low, you could have saved a lot of money by just taking a picture of it to hang in you garage instead...................;).
  18. Lowbow38
    Lowbow38
    With the rear end there is really only about an inch of travel when trying to make it move, basically when driving down the road the rear end feels so still that it feels like the whole back end of the truck is bouncing but not due to the suspension, never once have I heard a bang or a clunk sound with the axle hitting the frame. It’s almost like the rear end has no movement at all with or without the shocks
  19. Lowbow38
    Lowbow38
    The back end isn’t to low, this is how it’s stance is now, the front is much more lower and it handles pretty well, but the back end is stiff as hell. Would think that even removing the shocks I’d have a lot of movement but it feels the same
  20. grumpy65
    grumpy65
    Can we get some close-ups of this area?
  21. Mimilan
    Mimilan
    If you want to fix it [without machine gunning $$$ at it] you will need to try a few things and also measure a few things.
    Measure the shock travel as suggested. [it costs nothing]
    Also remove the bump stops [rubber bump stops dont clunk like steel ones]
    A car will squat more than 1" under gentle acceleration ,so it could be constantly sitting on the bump stops.
    Remove the lowering blocks [Just to see if the ride improves, and there is no binding]
    If the rear is still too bouncy with the lowering blocks removed, it usually means the frequency is too high [too stiff for the suspension load]
    If that is the case, then load up the bed with some weight to see if it goes away.
    If the springs are too stiff, then the best remedy is to soften them by removing a leaf, then re-arching them to restore spring load.
    If you have to do this,you might need to add "override bars" to prevent spring wrap!
    You really need to use a tape measure before and after when doing this sort of suspension tuning.
    edit: In suspension terminology , spring stiffness is the spring rating [lbs/in] eg: a 100 lb/in spring will compress 1" with 100 lbs on it, and the same spring will compress 3" with 300 lbs on it. [unless they are progressive rating]
    Spring load is the unloaded height [or shape] , You can have a 100 lb/in spring designed to carry 700 lbs. It is shaped to settle 7" when loaded [this explains why spring compressors are needed for some installations]
    Softer springs are usually longer or have a deeper arch
    Lowbow38 and grumpy65 like this.
  22. Lowbow38
    Lowbow38
    I can get pics of that area tomorrow and post them
  23. Rickybop
    Rickybop
    I kinda like a bouncy rear end.
    Had to say it. :p
    Saw your thread a couple times, Lowbow38. Good to see all the help. Good luck.
  24. Lowbow38
    Lowbow38
  25. Lowbow38
    Lowbow38
    I hope I can get it figured out. It’s driving me crazy
  26. grumpy65
    grumpy65
    Follow any advice given by @Mimilan . This is one of the members on here that will really be able to help you out.
    Lowbow38 likes this.
  27. gene-koning
    gene-koning
    Sorry, but my statement is not a contradiction. Though generally, a shorter spring is stiffer, not all short springs are stiff. The number of leafs in the spring pack, and the thickness of the spring leafs determine how stiff a leaf spring is, not the length of the spring.
    Besides that, my comment was based on what I see with his spring and shackles. With the leaf spring higher at the center then it is on the ends, the shackles have to be able to move forward for the leaf to function. The way his are will not ever function correctly. If his springs were higher on both ends then they are at the center, the spring and shackle set up he has would be working correctly, but his spring has the arch going in the wrong direction for his shackles to work as it currently is. Then we would be talking about shocks and bump stops. Doing anything short of correcting the leaf spring and shackle set up he has, will not have any effect on his problem. Gene
    Atwater Mike and 2OLD2FAST like this.
  28. Lowbow38
    Lowbow38
    Found the paperwork with the specs of my leaf springs
  29. gene-koning
    gene-koning
    And that is how your springs should look with them mounted on your truck, but they don't. If they looked like that, they would probably work correctly. Gene
  30. Lowbow38
    Lowbow38
    In the next couple days I’ll take everything part and mark everything where it is now and take photos and post them on here, hopefully with everyone’s help I’ll be able to figure out this problem
