Hot Rods Cody Walls Builds 32 Ford 3 window coupe “The Ardun Killer “ .
Discussion in 'The Hokey Ass Message Board' started by Cody Walls, Aug 21, 2019.
  1. Can we get a better look at your wishbone to rear end mount set up?
  2. GEBHARD
    GEBHARD
    from TX...
    Just looked through this thread for the first time......looks pretty dang kool....:cool:
  3. What GMC rods ARE those???
  4. Cody Walls
    Cody Walls
  5. Cody Walls
    Cody Walls
  6. Cody Walls
    Cody Walls
  7. Cody Walls
    Cody Walls
    Nos Gmc 302 rods
  8. AmishMike
    AmishMike
    Color me confused.... How did u get pic of valves/head at end of cylinders?.. Great build love it
  9. Cody Walls
    Cody Walls
    I’ll post them once I get back to the shop
    Stogy and loudbang like this.
  10. Thanks, Cody! I'm guessing that they're longer- any modifications to make them fit the 261 crank?
  11. Cody Walls
    Cody Walls
    Marshall had to machine them down to fit the 261 crank ,, Ross pistons already makes a piston shorter to run these in a Chevy ,
    chriseakin and loudbang like this.
  12. Gotcha- have heard of using 261 rods in an early ('28 and earlier) Chevy 4, but nice to know that 302 rods might work as well and give even more squish :D
  13. It looks like you found a Cyclone adapter too.
    Is the bottom ring cut off like mine?
  14. Cody Walls
    Cody Walls
    It’s loaned to me for mock-up until I can find one . This one actually has the ring broken off of it .
  15. Block is upside down looking down through the cylinders from the crankcase.
  16. AmishMike
    AmishMike
    Not familiar with that engine now notice bearing - of which there are only 4 instead of 7 I am used to. Tks for answering stupid question
    loudbang and Speedy Canuck like this.
  17. Cody Walls
    Cody Walls
  18. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I like it - especially the coach work you are doing.
    Very trad.
    -Brent-, Stogy, Cody Walls and 3 others like this.
  19. Cody Walls
    Cody Walls
    Thank you
  20. Cody Walls
    Cody Walls
    Ha ,far from showing off , just working and posting progress .
    Thank you
  21. You’re welcome.
  22. Cody Walls
    Cody Walls
    alfin32, Tman, lucky ink and 21 others like this.
  23. Cody Walls
    Cody Walls
    This was what the inside of the trunk lid looked like , and the main reason I got a new skin. It was pretty thin at the bottom . With the new skin I epoxied and painted the underside the put DynaMat between the layer before I put the two pieces back together
    4” out
  24. Sheeez' .. .. that is nice !!
    Stogy, Cody Walls, brEad and 4 others like this.
  25. RustyDogg
    RustyDogg
    On top of all the great work you're doing, thanks for the steady updates. You're a true craftsman.
    Stogy, Cody Walls and loudbang like this.
  26. ^^^^^^what Rusty said x 2
  27. Elcohaulic
    Elcohaulic
    What's this, no thongs or tennis shoes?? I cringe when I see people wearing beach clothes while building a car LOL...
    lucky ink, Cody Walls, TFoch and 5 others like this.
  28. Cody Walls
    Cody Walls
    The start of building my trailing arm rear suspension, I didn’t have room for hairpin out back . But I wanted to build a trailing arm out of Ford parts . And this is what I came up with . I know individually these rear arms are not strong , but welded together is another story . There not done yet as these are just progress pictures
    The 40 bells were to short short for my application so I had to go with truck bells , there going to get Torino ends and 9”Axel , HotRod Works is going to be doing the conversion , and Walden kingmount brakes
    Brassworks is building the Radiator for me , since the rad and grillshell are down below the front crossmember this will fix my issue with the lower rad hose
