Hot Rods Need a little help on a 392 Hemi roller cam, Crower
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Oct 22, 2020.
  1. drumyn29
    drumyn29
    I would love it if someone had a crower catalog to tell me the specs on my cam.
    thanks
  2. Deuces
    Deuces
    Anyone????.....
  3. Casual 6
    Casual 6
    from Great NW
    If you've got some time before you use it, just send it over to Crower and they'll measure it and send you back a timing card with it. Don't know if they've changed policy, but they used to do it no-charge.
    kidcampbell71 likes this.
  4. 4tford
    4tford
    Call Hotheads they might be able to help on that cam they have roller cams for
    gen 1 hemi.
  5. dreracecar
    dreracecar
    from so-cal
    #1 piston TDC, roll cam so that you can rest a straight edge across #6 lifters, install chain (or gear set) SEND IT
  6. drumyn29
    drumyn29
    GOOD MORNIN BRUCE!!!
    Congrats on your daughter becoming an MD!!! Screen Shot 2020-10-23 at 9.41.40 AM.png
    Budget36 likes this.
  7. lippy
    lippy
    from Ks
    Probably have to call Crower. If the number starts with a letter, it's a custom grind. Lippy
  8. drumyn29
    drumyn29
    Just called them but they only have records from 30 years ago.
  9. dreracecar
    dreracecar
    from so-cal
    Isky has a Cam Doctor that they will plot it out and give you the info. Just had them do an old Engle cam. Just around the corner from my shop
  10. drumyn29
    drumyn29
    LookslikeIwillbe stoppingatIskythisweekwhenIpickupthat BAD ASS SCOOP YOU MADE ME!!!
  11. drumyn29
    drumyn29
    Not bad for a Honky!
  12. Budget36
    Budget36
    Is that engine turned?
    oh. Hitting the space bar is not optional for some of us;)
  13. drumyn29
    drumyn29
  14. Deuces
    Deuces
    That^^^^^looks like a much younger "Wild Willie"..... Without the beard....:confused::D:rolleyes:
