Projects Rigid, flaring tool no. 345
Discussion in 'Traditional Hot Rods' started by sloppy jalopies, Oct 24, 2020.
  1. sloppy jalopies
    sloppy jalopies
    anyone have or use one ?
  2. Ridgid makes quality stuff so no issues there, but this type of flaring tool can be a PITA to use in some places, and a certain amount of skill is needed to get good flares. The double-flare die for brake lines can be a bit fragile, I've broken several of them.
    More money, but as close to idiot-proof as you can get....
    https://www.amazon.com/MASTERCOOL-72485-PRC-Universal-Hydraulic-
    Transmission/dp/B06WD86RLH/ref=psdc_15707271_t1_B01NCYKQSN
    Worth every nickel to me, and I've loaned this out a few times and gotten nothing but rave reviews back. Eastwood makes a cheaper similar unit but theirs is bench-top unit only, the hydraulic can be used on the vehicle in some cases if need be.
  3. Yes, I have one. Good for flares, not good for bubbles.
  4. geoford41
    geoford41
    from Delaware
    I have a Rigid 377 that I use on 37 degree AN flares, I find it works great and has a ratching feature that as soon as you form the flare it stops from going too far,
    I use mostly 1/4" 304 SS tubing with back up sleeves so no double flare capacity. I have flare the new style copper/ steel tubing and it works great.
    I believe I bought it from Home Depot for around $115
  5. deathrowdave
    deathrowdave
    from NKy
    I have a 45 and 37 degree , Rigid flare tools . Mine were made years ago in the good ole US of A . Never one is sure to date .
  6. sloppy jalopies
    sloppy jalopies
    this tool has the 3/16" fraction stamped into the unit but they never milled the half holes on each side... it says 3/16" but...
    no worries, they stamped the fractions a certain distance apart...
    but milled the gripping slots closer together as the holes got smaller... 1/4" is stamped beside the 3/16" hole... 3/16" stamping isn't beside any hole...
    gonna be fine...
