Hot Rods Model A Roadster Parts question
Discussion in 'The Hokey Ass Message Board' started by harleycontracter, Oct 20, 2020.
  1. harleycontracter
    harleycontracter
    I'll be looking for door hinges, inner and outer door handles and latch mechanisms soon. Are all those parts specific to a roadster ? Want originals Thanks
  2. low down A
    low down A
    those lock mechanism's you speak of would be interesting on a roadster
  3. harleycontracter
    harleycontracter
    You know what I meant Latch mechanism LOL
  4. Paul, I know you are trying to stay with original parts, but finding good original hinges and unworn latches is hard to do. Did you check with Eric from A's & more to see if he has anything, or knows who might have what you need. As far as inner and outer door handles, originals that are not split or cracked are very tough to come by. I will contact some model A vendors down here to see what they may have. Otherwise, just go with the reproduction stuff for now. I have reproduction inner handles on my roadster, but if I find some good originals, I would get them to replace what I have. I have a worn original door latch on my roadster, but I have a reproduction latch to replace it for now.
  5. Flathead Dave
    Flathead Dave
    from So. Cal.
    Be careful when you purchase used hinges.
    People often get them mixed up or will tell you what you want to hear with bad information and then you'll have hingeas for the wrong class.
    Sent from my SM-G973U using The H.A.M.B. mobile app
  6. kb cookout
    kb cookout
    Which years 1928-29 or 30-31 ??? hinges are different , early 28 had no outside door handles and different door latches
    later kb
  7. continentaljohn
    continentaljohn
    They are hard to find around here as well:D image.jpg
    kidcampbell71 likes this.
  8. harleycontracter
    harleycontracter
    I probably end up with repops But thought I'd get knowledge in case I stumble on some . Really appreciate all your advise and the advise of the other members. You've all guide me through a few builds
  9. harleycontracter
    harleycontracter
    Nick, I talked to Eric months ago. He's not selling parts Decided just to build motors FYI
  10. continentaljohn
    continentaljohn
    What year are you looking for ? Outside door handles are also different as the 30-31 are stainless and 28-29 are nickel plated if I remember correctly.
  11. continentaljohn
    continentaljohn
    I used to make the door latch that wore out but prices of tool steel made it impossible to make them reasonably... image.jpg
  12. wheeldog57
    wheeldog57
    The repop hinges are made well. . . . The holes don't line up though! I had to re-drill. After a few weeks in the elements they look original
    continentaljohn likes this.
  13. harleycontracter
    harleycontracter
    Building a 31 Roadster 30/31
