Hot Rods License plate Flipper
Discussion in 'The Hokey Ass Message Board' started by sdluck, Oct 17, 2020.
  1. sdluck
    sdluck
    Some years ago they made a vacuum flipper kit for the rear license plate,I am looking for one. Search showed only electric which is fine but I was looking for a vacuum on .My license plate hides my Quick
    change . This is on a Model A Thank you
  2. Budget36
    Budget36
    I think you could whip one up? Would be easier with electric solenoid tho
  3. sdluck
    sdluck
    Do you have any Ideas?
  4. Stu D Baker
    Stu D Baker
    from Illinois
    Dan Fink Metalworks. He makes the vacuum operated unit.
    kidcampbell71 likes this.
  5. Budget36
    Budget36
    Heck, thinking further, an inexpensive linear motor would be slick as well
    jimmy six likes this.
  6. Budget36
    Budget36
    Okay. Sd. Pivot the plate
    linear motor to one side of it
    rod from the motor pushes the plate up. Or, if you built it in a fashion that the rod would pull the plate in. Never see the rod that way
  7. Stu D Baker
    Stu D Baker
    from Illinois
    Dan uses a couple of vacuum choke actuators, a plastic tank, some tubing, and a swinging Stainless steel hinged plate. So,.....you can do this if you want.
    lothiandon1940 likes this.
  8. sdluck
    sdluck
    Thanks guys
  9. Move the plate.
    mgtstumpy, chop job, 5window and 3 others like this.
  10. If you're trying to build your own, look for a heat riser pull-off(GM), or headlight door actuator. Not common, but I found some at swap meets.
  11. sdluck
    sdluck
    Thank you all for your suggestion.
  12. ekimneirbo
    ekimneirbo
    Don't think I would want run vacuum all the way back to the rear of a vehicle. The electric ones are kinda pricey. How about one of those controls like they use for a lawn mower throttle. Really "old school" technology.;)
  13. Stu D Baker
    Stu D Baker
    from Illinois
    Actually depends on how and where you run the rubber line. I installed one on my avatar in 1989. Still works like the day I installed it. There a lot of ways to make OP's idea work, and a lot of hurdles to consider along the way.
    ekimneirbo likes this.
  14. Spring loaded door hinge. Might require you to bend down a little to operate...
    Muttley likes this.
  15. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    Did you ever think of just moving the plate?
  16. ramblin dan
    ramblin dan
    I picked up a motor for a quarter glass on a mini van. I'm going to adapt the arm and s OIP.jpg ee if it has enough travel on it.
  17. 1971BB427
    1971BB427
    from Oregon
    A simple electric door lock solenoid can easily be reworked to work for a license plate flipper. Simply hinge the plate bracket at a point partway down each side, and attach an operating rod under the car to pull the plate up and down with the solenoid.
  18. Mr48chev
    I can see Vacuum as being nifty if the vacuum pull brings the plate down in sight and no vacuum lets a light spring pull it up out of the way. Plenty of heater and AC vacuum actuators kicking around that would be plenty strong.
    Just like any longer vacuum line you could use steel tubing for the majority of it and rubber at the ends.
    olscrounger, Tman and Stu D Baker like this.
  19. That will not help if your using it for the red light cameras.;)
  20. GTS225
    GTS225
    How about a cruise control bellow from a 70's vintage car? Engineered to hold against throttle return spring pressure, and is linear in design.
    Just my pie hole making noise......Roger
    VANDENPLAS and Tman like this.
  21. 5window
    5window
    You could use a fuel door turned 90 degrees
  22. Mr48chev
    One of those should be easy to find And as he said strong enough.
    The problem with a hand flipped plate is that when you go to leave an event you forget to flip it. Vacuum operated means that when the engine is running the plate shows and when the engine is off the plate flips up. No remembering to flip the plate or flip a switch.
    There also a number of hidden license plate holders both manual and automatic if you want to pay the bux Electric that speedway sells https://www.amazon.com/Electric-Hid...ds=Hidden+License+Plate&qid=1603127096&sr=8-8
    Hand pull out for Corvette https://www.amazon.com/Altec-Produc...ds=Hidden+License+Plate&qid=1603127096&sr=8-2
    Stu D Baker likes this.
  23. Mimilan
    Mimilan
    Or even easier to find!
    A vacuum blend door actuator [from a heater]
    The great thing about vacuum is....... When you're "flat to the boards" when street racing there is no vacuum, so your plates automatically flip up :D
  24. If their memory's that bad, how do they remember where they parked their car when it's time to leave?
    Tman likes this.
  25. Keep forgetting about those modern things, I was looking for vacuum cans, when most heat systems were still cable!
  26. RMONTY
    RMONTY
    Easy now, none of us are getting younger! :eek:
  27. [​IMG]
    Please excuse the foreign car, this is the first thing that came to mind. Driven by some dude named Jim or something..
  28. Gus68
    Gus68
    from Minnesota
    How about the 4x4 actuator for an S10? They a strong enough to engage the front axle. And have a cable, so you could mount it anywhere and run the cable to the licence plate.
  29. hotrodjack33
    hotrodjack33
    Back in the 80s, I built a retractable license plate and tailight unit for my '40 pickup...was going for the "drag truck" look. I used a GM power window motor and switch so I could raise it up AND down. Mounted a 4" arm on the motor and ran a cable to the taillight unit. Mounted the whole taillight unit on a pair of spring-loaded screen door hinges so there would be constant tension on the unit and it wouldn't flop around when lowered. 37d.jpg
    wraymen and chevy57dude like this.
