Hot Rods Nature Abhors a Vacuum, Or, The Hemi A Roadster fills a void.
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Jul 18, 2020.
  1. BamaMav
    BamaMav
    from Berry, AL
    Could you pull a fiberglass mold off of it? Then make a glass copy you could paint?
  2. flynbrian48
    flynbrian48
    That is possible, although wall hanger might be better, given my clumsy fiberglass skills. Said the guy who's built three 'glass cars...
    Stogy, millersgarage and loudbang like this.
  3. Hmmm' .. .. wonder if you could assess whether a 3D printer could copy that. "Lost PLA" casting.
    @gimpyshotrods is a treasure on this board. Partnering old with new is a fine line, but he seems to do well with that. His thoughts may do you right, or not. :)
    Stogy, 5window, tb33anda3rd and 2 others like this.
  4. Everybody cuts them and fastens or welds after casting them. Leave the center upright post on one side so you cast a "U" shape and the cut off "L" shape, should be easy to cast that way. Angeles foundry in Los Angeles on Pico Bl. is good for odd ball stuff like this. JW
    Stogy, flynbrian48 and loudbang like this.
  5. flynbrian48
    flynbrian48
    Well, the blueprint is finished, all I need now is some steel tubing for the frame, a front axle, and boom, in a couple weeks it'll be done... 118925281_10224549965919268_6346633391270369554_n.jpg
    Stogy, brEad, Fitty Toomuch and 10 others like this.
  6. 1-SHOT
    1-SHOT
    from Denton
    My windshield frame came from Sellers and it was cast in 2 pieces. Split right down the middle. I feed it out a little and TIG it together down the middle and filed it. You know there is shrinkage when you cast something off a pattern a foundry They should be able to tell you how much. It’s doable it will just take a little work. But I think they really make a 29 look good. I saw a picture I’ll attach it of a 29 roadster with a 33 hood and grill. The louvers and the grill accent the coach line on the 29 cowel . I be following to see how you do this time around. Frank ECAEF38B-DB01-4833-A7D1-B40007753A31.jpeg
    hfh, Stogy, brEad and 6 others like this.
  7. flynbrian48
    flynbrian48
    Somebody on FB (who also has a Sellers on his '29) told me that O’ Brien Truckers had a Hallock style W/S for ‘28/‘29’s for almost $1,000 less than I could have one cast from my pattern. So I bought one.
    brEad, ffr1222k, tb33anda3rd and 8 others like this.
  8. DDDenny
    Brian, nothing to do with your project but I seem to remember the windshield frame that SoCal used to promote theirs was carved out of wood and airbrushed to look like chrome.
    Looked pretty good in their early literature.
    If someone can prove otherwise I'll be happy to erase it from my foggy databank.
  9. 1-SHOT
    1-SHOT
    from Denton
    Woods and Baker and Studebaker electrics had Wood windshield frames
    Stogy and loudbang like this.
  10. flynbrian48
    flynbrian48
    I could paint the wood buck silver and call it good.
    Stogy, chryslerfan55 and loudbang like this.
  11. Bandit Billy
    Bandit Billy
    You're just like Chip Foose! But I like your builds better.
  12. flynbrian48
    flynbrian48
    I'm just like Chip Foose, but have no artistic abilities whatsoever!! Like Chip, I did use a Sharpie to draw that sketch, which my wife liked well enough to put on the fridge door right alongside our grandson Milo's (he's 5) art, so, it must be pretty good.:p
    Stogy, seb fontana, Blues4U and 3 others like this.
  13. flynbrian48
    flynbrian48
    My Hallock windshield arrived yesterday from O’Brien Truckers, and I couldn’t be more pleased. I spent about half an hour tonight with a drill, cutoff wheel and 4 1/2” grinder and have it nestled down on the cowl. It’s not a perfect fit, bit this is a glass body of unknown heritage, I think it’s close enough for a little sculpting with Mar-Glass and Rage Gold to be perfect.
    I’m thinking now about whether to buy a frame or build one, and I’m looking for a transmission. I’m leaning towards a 700R4, I’ve had enough of rowing a 4 or 5 speed.
    Stogy, GordonC, tb33anda3rd and 4 others like this.
  14. flynbrian48
    flynbrian48
    Frank, since you mention the coach line at the cowl, I thought you might like that the doors with this body are longer, by about 6" at the top (at the rear, the front is stock shape), and curve down and forward, matching the the cowl line. I like it, and will be cutting new door jambs in the body. I think I can use the doors as a mold for the jams, I'll just wax 'em up, tape them on about 3/16" further back in the body to allow for some clearance, and glass 'em up as a pattern for door jambs. It'll be nice for entry and exit. And look pretty damn cool.
  15. flynbrian48
    flynbrian48
    No photo because I don't have it yet, but I'm having my buddy Dave Grey build a pinched '32 frame for the car. I priced '32 rails to build my own, even considered making one from rectangular tubing, and decided if I want to get it done in my lifetime the very small difference in cost outweighed spending months building a chassis that looked like I'd build my own chassis. With age comes wisdom.
    Anyway, he builds them pinched for the '28-29 cowl, a little kick in front to get them down, all the crossmembers in, frame spread at the rear to line up with the wheel wells, and bobbed rear horns. I'm gonna use coil-overs at the rear, and the Ford 9" I have. In front I'll keep it simple and use a dropped axle, and another set of the Wilson Welding aluminum backing plates and Buick drums like I had on the '34.
  16. flynbrian48
    flynbrian48
    So, this happened, and the T’bird banished to the back of the shop. Then I tipped my big roll around tool cabinet over (bumped something on the floor) and just walked away.
  17. rockable
    rockable
    :mad::mad::mad::mad::mad: Sometimes it is just best to walk away.
  18. Bandit Billy
    Bandit Billy
    You know the rule...pics or it didn't happen
  19. bchctybob
    bchctybob
    ^^^^ Yeah, everyone loves a good train wreck....
  20. flynbrian48
    flynbrian48
    Oh, it happened. My brother in law helped me set the roll around base back up, no small feat as the drawers (still full of tools, all piled up at the fronts of them) slid out as we tried to right it. and, being on castors, it just wanted to roll back as we tipped. Finally, I slid a 4x4 under the front as we lifted it, it bumped up against the side of the T'bird so it couldn't slid back any further and we could set it up. I haven't had the nerve to look at the door of the 'bird to see if I damaged it. It was no bueno.
    In better news, I ordered a bunch of shiny stuff for the roadster. Chrome "Superbell" axle, spring, and bones along with chrome perches and other hardware. The split bones I found on eBay, the sellers description was "...chrome is not flawless...", but the photos looked nice, and I don't build flawless cars anyway. I originally was going to get raw steel stuff and paint everything, and I thought a drilled axle and bones would be cool, but it seems everybody in the country must be building hot rods, forged axles are "...on backorder..." everywhere, but fancy chrome ones (more $$) are available. Cheap, no name cast ones are out there, but I don't want to buy crap just to save a couple hundred bucks.
    I'm now on the hunt for a transmission. I'd like to get one locally, it doesn't really matter what, but I need a trans before I can get the proper adaptor from HotHeads.
  21. loudbang
    Think of the mishap as a Treasure Hunt because you will be finding stuff in corners and under other stuff for years. :rolleyes:
    Nostrebor, rockable and millersgarage like this.
  22. Bandit Billy
    Bandit Billy
  23. flynbrian48
    flynbrian48
    One thing(s) I hope I can find sooner rather than later are the little dies that go in the end of brake line tubing from my flare tool set. :mad:
  24. Nostrebor
    Nostrebor
    I would be sorely tempted to use all my golfing words and possibly kick the cat if that happened to me. Feeling your pain!
  25. rockable
    rockable
    Those are hard to find replacements for. If I remember correctly, I got mine from the Matco guy. If not, it was Snap On. Good luck! A flaring tool kit ain't worth spit without those little buttons.
  26. cfmvw
    cfmvw
    Cast aluminum shrinks about 1/4" per foot, so you need to make those allowances in a pattern. When I was building the Dave Gingery lathe in his Shop From Scrap series, the lathe bed pattern was 24 3/8" long. After the casting was cool, it came out to a little under 24".
  27. flynbrian48
    flynbrian48
  28. flynbrian48
    flynbrian48
    It was like Santa came early today. A bunch of beautiful shiny chrome, and a trunk lid that fits!
  29. BamaMav
    BamaMav
    from Berry, AL
    The futures so bright you gonna need sun shades! Pretty!
  30. flynbrian48
    flynbrian48
    Oh, I scored a trans from a guy who pulled a 305/350 TH combo from his '55 to put a 5.3/4L60 in, for cheap. It's dirty but fluid is clean and doesn't smell burnt, so now a call to Hot Heads for an adaptor and I have a drivetrain.
