My search skills suck at best! Is there a small V8 cap with male terminals? HEI style?? Thanks for your time Terry aka dirt t
I bought one of these a while back, worked good the problem was I could not get replacement part's. MSD is so damn expensive.
I have one of these in my 26T coupe, SBC 355. Chinese made. ProComp, I think. It works OK. Replacement caps and rotors are available through Summit. The vacuum and mechanical advance both pull in about 22 degrees. Too much on both. I can't even get it apart to change or limit either advance mechanism. Can't get a good ignition curve set. It is getting replaced with a Dave's Small Cap HEI. A points distributor converted to HEI with adjustable advance curves.
You can buy cap and rotor also off eBay and most swap meets sell the modules for $10... I've run one on my avatar for 4 years.. I do carry an extra module, but not needed yet.
Dang, I just went to a thread I'd saved here about the same thing, a quality unit for around 130-140$, just clicked on it and got HAMB ERROR, must have strayed OT I guess.
https://swapmeetparts.com/product-c...tributor-w-spark-plug-wire/chevy-small-block/ Maybe some offshore part but mainly built in California. Have bought 5 of these units and love them. Warren
"saltflats", it's an HEI distributor on its own.. Not a conversion... Cap, rotor and module are all specific to this type of distributor but extras can be bought for it...
One site alludes that the A-Team Performance Part Number CR6973R Will fit but I couldn't find confirmation on it. They do sell a black one https://www.swperformanceparts.net/...ies-Distributor-Cap-Rotor-Kit-Black/743547833
