Hot Rods SINGLE MASTER CYLINDER VERSES DUAL MASTER CYLINDER
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Oct 7, 2020.
  1. A member commented about the brake pressure switch and eluded it to be problematic and something that is outdated, much like the single master cylinder.
    I am of the belief that the dual master cylinder, whether it's drum/drum or drum/disc give the braking system a far superior advantage, especially if you experience a brake failure on the front or rear of the car.
    That's not to say a well maintained single cylinder ( fruit jar style) can not be just as safe but in the event of a failure with a brake line or master cylinder the whole system is compromised.
    I have driven my share of cars and trucks with the fruit jar master cylinder and a few cars with mechanical brakes, but we will stick to juice brakes in this discussion.
    Are you a hard core traditionalist and insist on using the single cylinder master cylinder?
    Do you feel better using a dual master cylinder with drum/drum brakes or drum/disc brakes? HRP
  2. alchemy
    alchemy
    Fairly hard core, but I’ll be using dual masters.
  3. V8 Bob
    V8 Bob
    I know the safety advantage of a dual system over a single, having spent much of my life performing in-vehicle brake testing, so I do feel better using a dual master. All my vehicles have one.
    3W JOHN, HOTRODPRIMER and bchctybob like this.
  4. KJSR
    KJSR
    from Utah
    1. Utah HAMBers
    I actually have a mix of both. I have only had 2 brake failures both from failed masters. My first failure was a dual master and it was a complete failure. Getting off the 60 FWY in SOCAL headed to SOCAL Speedshop....went right through the red light....how I wasn't hit I don't know. My second failure was a dual master, just the rear res went dry and the brakes were shitty at best but I still had brakes...made it home. I only change to dual with some other type of change (add a booster) otherwise I have no issues with my single master cylinders. As a plus, my e-brakes all work good :rolleyes:
    3W JOHN and HOTRODPRIMER like this.
  5. Automotive Stud
    Automotive Stud
    Eh, I don't feel strongly one way or another. I built my roadster to be as period correct as possible, but since I was doing everything from scratch I put a dual master cylinder on it, but my '40 and '47 still have stock master cylinders. If I had to take it off or change it I'd consider switching it over but I don't get worried driving them.
  6. Deuce Daddy Don
    Deuce Daddy Don
  7. goldmountain
    goldmountain
    Since I don't think that I will ever be in the position to fully restore a documented hot rod like the McGee deuce roadster or Beatnik Bandit, I will use a dual master cylinder.
  8. 6sally6
    6sally6
    Only brake failure I had was on my "off-topic M-word Ford".......... Dual bowl!
    Second failure was when the cotter pin fell out from the pedal and MC push rod!:eek:
    PTL is was at night about 1 block from the house. I felt the washer...cotter pin bounce off my foot as I pressed the brake.
    First failure rear brake line rusted in two when I was about 5 miles from home. Little traffic/perfectly timed traffic lights/standard shift tranny got me home somewhat safely ;)
    Messy undies both times!!
    6sally6
    Still need to hook up the E-brake!:rolleyes:
    3W JOHN, 31hotrodguy and HOTRODPRIMER like this.
  9. jimmy six
    jimmy six
    Just finished a 1940 race car for the street. For the last 50+ years it had only rear drum brakes from a 57 Pontiac and the stock MC. Front drums were added to the Corvette spindles and the 1940 MC was rebuilt and left under the floorboard. Since the car had been lightened to #2900 the combination works great. At this time we see no need to replace any of it. 3C36022C-D0AF-4729-BE85-D3BFB3054835.jpeg
  10. wicarnut
    wicarnut
    I will never own/drive a car with a single master cylinder again, case in point, my wife's 51 Buick, I redid Entire brake system with ALL NEW parts, thought about changing to a dual master but I did not take the time to do figuring everything was new, should be good to go. The following summer we load up car for a trip and had a new steel line crack at seam/flare at wheel cylinder, result, O brakes, Thankfully we became aware of problem before we came off a ramp at 65 mph, used e brake to stop car after slowing, flatbed ride home. This could have been a disaster with terrible results, I will not make the same bad judgement call again, If I have another old car, first thing I will change is the master to a dual type. There's Traditional and there's Stupid, All my stuff, I've always tried to make my cars safe as possible and my poor judgement in this case in an area that I knew better, no excuses. I, like other old timers had many cars with a single master back in the day, never had a problem, BUT now we/I know better. Lady Luck and/or my Gaurdian Angel has always watched over me. For years, I always joked about I was like a cat, 9 lives, I'm way past that number now and enjoying my life/family, trying hard to stop tempting the Grim Reaper
    3W JOHN, Chicster and HOTRODPRIMER like this.
  11. TrailerTrashToo
    TrailerTrashToo
    Spring 1964 - I am 19 year old college drop-out pumping gas at the corner Jenny station. Get sent out to do a jump-start with the stations 1956 Ford F150. This truck is Jimmy Donnelly's baby. Jimmy was a good mechanic in his day, but now in his mid-80's. He recently hired a Ford dealer mechanic to go through the this F150, including new brakes and brake hoses.
    The jump-start was successful, on the way back, I stopped at the cross-walk for a line of kindergartners. Then pulled into the station and returned the truck to it's usual parking spot. THE BRAKE PEDAL WENT TO THE FLOOR WITH A SQUISHING SOUND!
    One of the new flexible front brake lines hit the rim on a tight turn - eventually cutting a weak spot in the brake line.
    When I hear all the b.s. about "a properly maintained single circuit brake system" - I WONDER HOW DIFFERENT MY LIFE WOULD HAVE TURNED OUT IF I MOWED OVER A FEW LITTLE TYKES LIKE BOWLING PINS.
    Russ
    EDIT: First of 3 brake failures - the others were worn out ford trucks - I was passenger in the Econoline (not mine) - The 1959 F250 was taken off the road before it actually failed and got a dual master cylinder and the appropriate 10 PSI check valves.
    3W JOHN, HOTRODPRIMER and wicarnut like this.
  12. bchctybob
    bchctybob
    I think I’ve only had one, maybe two brake failures over all these years (single systems) so I guess I can make the argument that single M/Cs have a pretty decent record but I have trouble building a car with a known single point failure in the braking system. So even when I would really rather have hanging pedals and a GMC master, I opt for floor pedals and a quality dual master and modern brake parts hidden underneath the floor. Especially since I used to be notorious for not getting around to installing or hooking up the E-brake on my own cars. Also my family often rides in or drives my cars and I won’t endanger them just for the cool factor.
    3W JOHN, wicarnut and HOTRODPRIMER like this.
  13. squirrel
    If it has a dual on it, I probably won't switch to single...although I did on one car :)
    I don't really care what anyone else does with their car. I expect quite a few dual conversions don't have sufficient piston travel to actually work when one side fails, and my guess is that not many people check this (just open a bleeder, see if you still have brakes).
    My newest car has single, and it stops a hell of a lot better than the T did.
    RICH B, Flat Six Fix, F-ONE and 8 others like this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    The 36 pickup has a single 40 master cylinder
    BAD51FDC-95D9-4D4F-8432-BB6C88625926.jpeg Miss elegance has a chrome single master...
    0FCF3857-657E-4115-9CDA-B1B918344E8F.jpeg My impala has a single master cylinder, but I chromed it
    The corvette, the 40 and all the rest of my cars have single masters except one, the Astorian has a dual cylinder only because it was there when I bought it. I am proactive enough to be able to replace brake hoses and rebuild wheel cylinders before it would ever be a problem.....
  15. TrailerTrashToo
    TrailerTrashToo
    It is possible to install a dual master cylinder on a car with floor pivoted pedals.
    This is in my 1962 Volvo custom. It took me a couple of weeks to get the X, Y & Z measurements within 1/16" of the original Volvo master cylinder. The actuator rod perfectly fit the new cylinder.
    Start with some heavy channel and remove everything that did not look like a bracket. I had to send the welding out, then keep test fitting and trimming excess metal.
    Proportioning valve.jpg Wilwood remote set bought from Summit. Adjustable rear proportioning valve has a thread for a brake light switch. I've already failed one of these hydraulic switches, also discovered that it takes a fair amount of pedal pressure to turn on the brake lights. Now have a mechanical switch in parallel with this hydraulic switch (Belt and suspenders...).
    3W JOHN, Elcohaulic and HOTRODPRIMER like this.
  16. Jim. you and Mark are the type of guys I was talking about, proper maintenance & being proactive assures nether one of you will ever experience a single master cylinder failure. HRP
  17. 41rodderz
    41rodderz
    from Oregon
    Even though being up on maintenance is a good thing , HRP there is no assurance that problems will not occur. Sorry but your statement is false , false and false.
  18. My 51 GMC is getting dual and power because it is a daily and will tow. My A Tudor is getting a clutch/brake MC and a good ebrake.
  19. BJR
    BJR
    I put dual masters on anything I build. After all the time and $ spent on a car, a dual master is a must for me.
  20. Mr48chev
    I don't remember having a master cylinder fail to the point you couldn't get it to stop with enough pumping or pressure, It is always a wheel cylinder or brake line that fails in 99% of the cases and half a set of brakes is far better than no brakes.
    Bought a 55 Nash Metropolitan ragtop when I was 17 a few weeks after I bought it I was running down the street at noon to go to a burger joint for lunch and hit the brakes and the pedal went to the floor. I had blown a front wheel cylinder. I picked a gap between the car in front of me and a car parked on the side of the street and went though it leaving some green paint on one bumper bolt on the parked car and putting a faint crease in my rear quarter. No damage to the early 50's Chevy except green paint though. I limped down a back street to the burger place, got lunch limped back to work using my park brake and getting out of town on back streets made it to the highway and made it home where I pulled the wheel cylinder and sanded the inside and replaced the cups.
    I've had single piston brakes go out since that but not with that much excitement. I had room to maneuver in those cases. One was a front hose on a 62 Impala that I bought cheap, Bad front hose on that one that ended up being a three hose replacement and full brake job.
    HOTRODPRIMER likes this.
  21. Dennis D
    Dennis D
    So, if a person doesn't agree with you they are?
    3W JOHN, 2OLD2FAST and HOTRODPRIMER like this.
  22. Torana68
    Torana68
    from Australia
    um, traditional? do I get a prize?
    Anything will fail if its not maintained, bin your 60year old hard lines, fit new flex lines and change your fluid regularly and you should never have a bad brake day (oh and hook up and adjust the emergency/park brake!!!)
  23. Maybe you can explain to me why, in your learned opinion, my statement is false, false and false?
    With that wide brush you are painting with try to remember NOTHING is infallible, any system can fail, new or old and you can take that to the bank! HRP
    3W JOHN likes this.
  24. bigdog
    bigdog
    I'm old enough that I grew up with vehicles with single circuit brakes, and everything I build will have dual circuit. Even properly maintained brakes can fail. I only had it happen once, but I guarantee you will never forget it.
  25. Thepartsbinguy1
    Thepartsbinguy1
    from Space
    I have had the brakes fail once. Luckily I was on a dirt road going slow and was able the just drive home and re-rout a new line. 60E40B52-C5C4-4357-8E8D-1BFFDB6C5F31.jpeg C2A6266C-CD13-4D8A-BE66-3C59C0E37E41.jpeg 5037018B-FC40-4913-AD7D-5567E2392E79.jpeg
  26. junkyardjeff
    junkyardjeff
    My recently purchased 65 Mercury has a new single master cylinder and will see how it does,I always get the parking brake to work before a car hits the road just in case.
  27. 41rodderz
    41rodderz
    from Oregon
    o_Oo_Oo_Oo_Oo_O:oops:
    Exactly !!! Anything can fail . New old , maintained or not maintained. It is a black and white answer. Unless you are the right hand of GOD , you or anybody else cannot make a statement that guys like Squirrels or Mr. Moriarity “can be assured, that you won’t have failed brakes with a single fruit jar master cylinder”. Your words not mine. Logic and common sense says you cannot profess that statement . That’s why your words are false .
    2OLD2FAST likes this.
  28. The Magic Ratchet
    The Magic Ratchet
    I've had brake failures in vehicles with both single and dual master cylinders. A failure in a single master cylinder leaves you with nothing but the emergency brake, which in older cars can be mediocre or worse. A failure in a dual master cylinder leaves you in a much better situation, worst case scenario the pedal goes to the floor and only applies partial pressure to 2 of the wheels. The problem to me isn't so much the prospect of a failure, or the maintenance of the system, or "traditionality" as much as it is highway conditions. Traffic today is such that other drivers aren't going to leave anyone adequate room to have a failure, modern streets are (poorly) designed to leave you no room to maneuver in an emergency, drivers will cut in front of you and stop short just because they want to get in front of you. In today's driving, you need every edge you can get.
    Happy Motoring!
    Lou
    3W JOHN, seb fontana and HOTRODPRIMER like this.
  29. You answered your own question.
  30. Obviously in your opinion I lack logic and common sense and it is your opinion and I don't concur, let's just agree to disagree. HRP
    Flat Six Fix, warbird1 and 3W JOHN like this.
