Hot Rods I finally got a Roto-Faze distributor!! So let’s do a show your ignition parts thread!!!
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Sep 27, 2020.
  1. That Roto Faze is cool!
    loudbang and Moriarity like this.
  2. Corn Fed
    Corn Fed
    I kinda wondered. That's too bad. What else do you have with a SBC that you could use it on?
  3. The only time I saw a rotofaze under a hood, it was something like a 55 chevy. The only place I saw them was the drag strip. My area had many dual point units but I remember only 1 dual coil unit.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    the only other small block chev I have is in the Astorian and I really shouldn't change anything on that....
    OLSKOOL57, TBirdGirl26 and loudbang like this.
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    You can ship it to me ,I don't have clearance problems in my T !!
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    Here is the February 1956 Rod and custom article on the toro faze distributor
    F47A43B9-F156-4349-922B-4921CA9E369A.jpeg 779DFAF5-8206-4649-A159-FABA52318C19.jpeg 1DD91EE0-1CD0-4618-AD4C-7D3CAAB32A34.jpeg 0298190A-30AB-47DC-A132-9B696A2B9588.jpeg
  7. N.O.S. Mallory 6 cylinder caps Brown and black
    N.O.S. MAG-Spark Coil
    N.O.S. Dual point conversions BlueFlame 6
    Several BlumeFlame Mallorys
    4 Sun 6 Cylinder Sending units
    Rebuilt Dual point conversions and Best coil for BlueFlame
    Spool of Packard 440 wire
    Raja Spark plug ends 440 wire and end are left over from my dads oval track racing in the early 70s
  8. Paul
    Paul
    Editor
    Down to two Olds magnetos, one with tach drive and one without
  9. Paul
    Paul
    Editor
    The lowly Mallory..
  10. brigrat
    brigrat
    from Wa.St.
    DSCF1188.JPG DSCF1189.JPG DSCF1190.JPG Moriarity, If you weren't going to run the tach drive I believe you could modify the dizzy and gain that 1" or more you need. I have modified a couple Spalding/Grant's to fit my needs.....................
    What's that Aluminum spacer between the tach drive housing and dizzy caps, just a spacer or is there a reason for it?
    Here's a Ford 351 Cleveland I lowered 3 1/2" .
    1947knuck, Okie Pete, KiWinUS and 3 others like this.
  11. Moriarity
    Moriarity
    SUPER MODERATOR
    that spacer is the housing for the Mech advance mechanism.... can't really do without that.... If it wasn't a tach drive it may be lower but my corvette has a mech tach
  12. brigrat
    brigrat
    from Wa.St.
    So run a '58 Vette generator! Kinda snowballs doesn't it!
  13. in the case it goes ! Thats a neat dizzy !
  14. This belongs to a friend, Old school racer trick-WICO Model X magneto for a Chrysler flathead 6 mated to a BlueFlame Chev. 6 drive!
    [​IMG][​IMG][​IMG][​IMG]
    1947knuck, Okie Pete, Muttley and 8 others like this.
  15. 56sedandelivery
    56sedandelivery
    Cool! Looks a bit "tall"; sure it'll fit under the low Corvette hood? I am Butch/56sedandelivery.
    Moriarity likes this.
  16. brigrat
    brigrat
    from Wa.St.
    Butch, You got caught not reading the hole thread!
  17. Moriarity
    Moriarity
    SUPER MODERATOR
    4A2BD76B-4D0A-409B-A613-482F2EB6928B.jpeg F510F884-595F-4116-829A-592FD31974DF.jpeg
    Nope won’t fit. Here is a pic of the distributor in my other man a fre. One of the air cleaners on my car barely touches the bottom of the hood and this distributor is an inch higher....
  18. noboD
    noboD
    You guys are hoarders.
    Okie Pete, seb fontana and loudbang like this.
  19. 427 sleeper
    427 sleeper
    Really?!?!?!? Your OTHER Man a Fre... LOL! :D
    seb fontana, loudbang and Moriarity like this.
  20. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^^And he even had the nerve to start this thread!^^^^^^^^^^^^^^
    Remind you of anyone else? Starts with Funk*********** smileyface
    loudbang and 427 sleeper like this.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    Yeah, I just got it last weekend at the swap meet of the duck tail run in Indiana
  22. Please enlighten me, what is the advantage of the Roto Faze distributor? There’s no doubt that it’s way cool, and neat looking.
    Dyno Dave and loudbang like this.
  23. Moriarity
    Moriarity
    SUPER MODERATOR
    2 separate ignition systems, each for 4 cylinders. 2 coils, so more coil saturation time and thus a hotter spark
  24. PhilA
    PhilA
    1. Hydro Tech
    Hood or distributor shaft?!
    King ford, loudbang and Moriarity like this.
  25. yes:D
  26. saltflats
    saltflats
    from Missouri
    20201004_165625.jpg Joe Hunt 348/409 :)
  27. Mr Moriarity,
    Could you possibly show us a pic of the flamethrower with the top cap off, just to see how the Vac canister hooks up inside the unit?
    Much appreciated if you could.
    Chris
    UNSHINED 2 and loudbang like this.
  28. Moriarity
    Moriarity
    SUPER MODERATOR
    C65B62FE-9B95-4CB3-BD79-36DCA2CFEB87.jpeg 25721857-C8BB-4B99-AE1E-10E3367FCEED.jpeg C20F4E4B-731B-484B-AD7F-CCA0861E694E.jpeg 3809E346-0D4D-49D3-9982-E0B2737989CE.jpeg
  29. Thanks Moriarity,
    Just trying to work out what the difference is between the Vac and non vac units(regarding the plates and mechanisms)
    I am going to try and modify one of mine.
    Cheers for the reply.
