Projects '23 Ford Roadster build aka The Incredible Hulk
Discussion in 'The Hokey Ass Message Board' started by Paul, Feb 22, 2018.
  1. Bravo!
    Stogy, loudbang and Paul like this.
  2. Nice patches!
  3. triumph 1
    triumph 1
    That body went together quickly. Amazing work as always! You make it look so easy
  4. Paul
    Paul
    Editor
    Folded bottom edge passenger side
    Worked the edge slowly with vise grips and pliers
    Followed by thousands of light taps of hammer on dolly
    Again, will need some more massaging but it is getting close
    PXL_20200930_212014093.jpg PXL_20200930_231728591.jpg PXL_20200930_231742592.jpg PXL_20201001_003307966.jpg
    Just Gary, Tman, Aaron D. and 15 others like this.
  5. 31Apickup
    31Apickup
  6. RodStRace
    RodStRace
    Beautiful!
    Any thoughts of pulling a mold after the body is straight?
  7. Paul
    Paul
    Editor
    Thanks, no but I have thought it sure would be easier to start with one, a glass body that is.
  8. Paul
    Paul
    Editor
    Started folding the lip on the other side.
    El Hueso, OFT, brEad and 11 others like this.
  9. Man .. soooo' tidy. Always so tidy, & right. Awesome.
    Just Gary, brEad, loudbang and 2 others like this.
  10. Paul
    Paul
    Editor
    Thanks man,
    still looks crude to me,
    especially when there are so many examples of near perfect metal shaping out there.
    loudbang and kidcampbell71 like this.
  11. Paul, not everybody has a Pulmax! You are doing it your way which is likely the way most of us would do it. Great job, great pics thanks for all your input.
  12. Paul
    Paul
    Editor
    Filling holes
    PXL_20201002_162613600.jpg PXL_20201002_171815004.jpg PXL_20201002_171837312.jpg
    OFT, brEad, loudbang and 5 others like this.
  13. Tim
    Tim
    from KCMO
    Looking good man.
  14. Paul
    Paul
    Editor
    Driver side welded and dressed..
    patmanta, OFT, brEad and 9 others like this.
  15. Paul
    Paul
    Editor
    Alfred's brother Frank just stopped in to see what condition the HULK's condition was in..
    scott27, OFT, brEad and 7 others like this.
  16. 64 DODGE 440
    64 DODGE 440
    from so cal
    As a builder of cigar box guitars, I like your door chime.
    Stogy, Jet96, loudbang and 1 other person like this.
  17. Paul
    Paul
    Editor
    Passenger side welded and dressed..
    Stogy, cactus1, patmanta and 5 others like this.
  18. Paul
    Paul
    Editor
    Welded and cleaned up cowl top to sides.
    Majority of welding now done on the shell, set body back on frame to map out floor.
    PXL_20201007_002058957.jpg PXL_20201007_002125887.jpg PXL_20201007_002821589.jpg PXL_20201007_002806041.jpg
  19. Looking good, @Paul!
    Stogy, Paul and loudbang like this.
  20. Paul
    Paul
    Editor
    Scored a very nice door, straight and solid.
    Glad I took the time to shape the bottom of the repaired door and jamb to match the original because this one will fit nice with little work.
    51box, Stogy, dana barlow and 12 others like this.
  21. No Paul, thats pretty good metalwork you are doing. Not crude at all.
    bchctybob, Stogy, loudbang and 2 others like this.
  22. Paul
    Paul
    Editor
    Thanks man.
    Pulled the rear inner body skeleton off the shelf,
    to take patterns of to form a new steel structure.
    chryslerfan55, 51box, Stogy and 7 others like this.
  23. 64 DODGE 440
    64 DODGE 440
    from so cal
    That is definitely going to be one fine little hotrod.
  24. Paul
    Paul
    Editor
    Fitting new door to opening
    Starting floor supporting structure
    chryslerfan55, OFT, 51box and 6 others like this.
  25. Paul
    Paul
    Editor
    Spent way too long on a couple body support pieces.
    Traced the latch side door jambs from wood pattern,
    cut them out,
    split them up the middle,
    transfered them to steel tube,
    sliced the tube on the band saw,
    cleaned them up,
    bent them to shape,
    welded them together,
    ground them smooth
    and test fit..
    Only took about two hours each..
    PXL_20201011_190218465.jpg PXL_20201011_190739078.jpg PXL_20201011_191132870.jpg PXL_20201011_192946472.jpg PXL_20201011_193308854.jpg PXL_20201011_193909902.jpg PXL_20201011_201455319.jpg PXL_20201011_202226773.jpg PXL_20201011_204015066.jpg PXL_20201011_210347843.jpg PXL_20201011_231526525.jpg PXL_20201011_235326644.jpg PXL_20201011_234646948.jpg PXL_20201011_234629363.jpg
  26. I like that method of building up that complex shape
    OFT, loudbang, cactus1 and 1 other person like this.
  27. 51box
    51box
    from MA
    Excellent work, so much good info in this thread
    OFT, loudbang, Paul and 1 other person like this.
  28. dumprat
    dumprat
    from b.c.
    Paul. Could you possibly get them plasma cut or water jet into plate and just tack them together? Might save a ton of time. Just a thought.
    chryslerfan55, loudbang and Paul like this.
  29. Paul
    Paul
    Editor
    I plan to do something like that for the top rails.
    And drawing them up in Cad, finding someone to cut the pieces and then waiting for them to get cut could take weeks and cost hundreds, this felt like it took too long but really only took a day and cost very little money.
  30. Lil'Alb
    Lil'Alb
    from brier, wa
    The Hulk is looking BITCHIN' :D Thanks for sharing as always
