Technical Model a with 39 transmission wishbone mounts?
Discussion in 'Traditional Hot Rods' started by Gasolinedeniz, Sep 30, 2020.
  1. Hi guys, is it just me ? Looks scary to me, if i hit the brakes the whole weight of the car is on this two tiney bolts? How did you fix this problem? Because of the law in switzerland i can’t split the bones:( 61093D85-C2A1-4100-BE1C-724557A8759C.jpg
    Gesendet von iPhone mit H.A.M.B.
    Nailhead A-V8 likes this.
  2. Are you running a torque tube?
  3. 48fordnut
    48fordnut
    Should be adequate. I see you have grade 8 bolts.
  4. adam401
    adam401
    Id run it without a second thought.
    Brian Lundgren likes this.
  5. Never2low
    Never2low
    I seem to remember in someone’s build thread, where they fabricated a full width cradle, welded in to each rail.
    clem likes this.
  6. sloppy jalopies
    sloppy jalopies
    that wishbone was designed to absorb bump impact but also when you are going 60mph and stomp the brakes the wheels want to stop and the car doesn't... lots of stress when you have to lock them up...
    I see you are bolting through the bell housing bolt holes,
    IMO they are not that strong... science guys to the front...
    clem likes this.
  7. Aaron D.
    Aaron D.
    I agree with you, I would make a mount that spreads across the frame.
    clem and Tim like this.
  8. adam401
    adam401
    On a model A the transmission is the wishbone mount so its not that far removed from what was there. Fuck it if your not comfortable with it change it. Can't enjoy a car you dont have faith in.
    joel and 62SY4 like this.
  9. rusty valley
    rusty valley
    i made my own mount. similar to what you show, except i went further up the bell housing so i could get 2 bolts on each side. its a tight fit that needs to ground to fit the shape pretty close to get 4 bolts, and have it sit nice and flush on the trans bolt surface
    Tim likes this.
  10. Thank you guys, guess i make a whole cross member:)
  11. Deuce Daddy Don
    Deuce Daddy Don
  12. Deuce Daddy Don
    Deuce Daddy Don
    Back then I ran a flattie" with '39 trans & juice brakes. My "Freeway Flyer" going to work in L.A..
  13. jimvette59
    jimvette59
    I put a Vern Tardel 32 cross member in my Model a chassis. It includes the wish bone mount. Check it out.
  14. 51 mercules
    51 mercules
    I'm running a 39 trans in my Model A with a torque tube and a similar wishbone mount from Clings, no problems.
    1stGrumpy likes this.
  15. I guess i have no space because of my whole brake set up
    AB Normal likes this.
  16. Need springs on those bolts so the ball can float lightly . Going by memory I thought I drilled a third hole for a third bolt
    I try to check my AV8
  17. Yep your missy the center third bolt F71F64C1-B500-470E-B035-F70340284D3F.jpeg
    Nailhead A-V8 and tb33anda3rd like this.
  18. 4bangerbob
    4bangerbob
    from AB, Canada
    when you are braking the wishbone force at the ball is going up towards the transmission. I would think if you could modify the bolt on support such that it rests against the bottom of the transmission would improve the mounting. To carry it further if you extended the mounting brack to the rear and added a couple of additional mounting points at the rear of the transmission (rear torque tube / u joint bracket?) you would eliminate the bending that can occur with the current mount, since you have a bending moment occurring from the flange of the transmission to the centre of the wishbone ball.
    Gasolinedeniz likes this.
  19. hardtimesainit
    hardtimesainit
    Street is neat....shows a picture on how your mount should be installed ! The grade 8 bolt UP through the bottom of bell is strong/clean install. Your problem at this time, is that you have to MARK HOLE location now while you have adaptor properly located.
    Then trans has to be removed to place thru bolt once hole is drilled. I use a self locking nut withred locktite and cotter ...if you like.
    You may have to shim adaptor with a Large washer to level !
    There is one other way that this can be done. If picture comes thru, it will show a trans with adaptor WELDED and BRAZED in place.
    I have this frankentrans now. It has ‘32 rear mount; ‘39 gears; 3” fork and adaptor welded. Good ole American genuity !
    Dont know what case is ? NUMBER: 68-7222 ?
  20. Fred A
    Fred A
    from Encino, CA
    1. Upholstery
    Tune in Guys: 51... has it and Street... nailed it with a picture. Such brackets have been around for ages with bolts from two angles. Quite common to find the hole through the bottom of the trans already drilled. Home brew brackets may not have the third bolt without a clue. Good Luck: Fred A
  21. Like 51 mercules, I used the Clings setup in my '29 with a '38 transmission. No problem!
    51 mercules likes this.
  22. rally1
    rally1
    You’re missing the third bolt for that bracket.
    See pic.
    Ken
  23. As @4bangerbob mentioned, as you brake, the wishbone yoke is pressed up into the transmission.
    At no point is the whole weight of the car on that point. The weight is carried by the front and rear springs and weight is transmitted to the axle and tires.
    On a Model A setup, the wishbone ball is captured by two bolts and a cup into the bottom of the transmission. Doesn't look much different here.
    Hnstray likes this.
  24. Well, then, that changes everything!
  25. Model A Gomez
    Model A Gomez
    I've ran that adapter on two different cars, a flathead V8 A and a banger powered A with a V8 trans and had no problems at all. Everything is real solid, there is no real strain on the rear of the wishbone especially if you use the stock springs on the ball clamp.
  26. gotthard
    gotthard
    i have a crossmember which probably will solve your problem. it is a original 32 k member without the legs and was installed in a model a. and i also live in switzerland
  27. Unfortunately the wishbone would not reach :rolleyes:
  28. Hnstray
    Hnstray
    from Quincy, IL
    @Gasolinedeniz
    One other factor here, the substantial length of the wishbone acts as a long lever to dampen and control any axle rotation forces created by the brakes. Ford designed it with that in mind. The wishbone also controls axle movement created by unequal forces applied to the front wheels, such a bumps and chuckholes. But, again, the lever effect is up to the task in anything less than a serious collision.
    Given the mass of the engine and trans, and the design of their mounting points, IMO, a wishbone mount such as you have pictured should be quite adequate so long as it is carefully fabricated to attach securely.
    Ray
  29. rpu28
    rpu28
    from Austin
    If you apply only the front brakes, the rear radius rods are in compression as the the frame keeps the rear axle from continuing to move down the road by itself.
    If you apply only the rear brakes, the rear radius rods are in tension as the rear axle tries to dragy the frame to a halt.
    If you apply front and rear brakes, the force on the rear radius-rod ball cup is the sum of the tension and compression on the radius rods - which could even be zero.
    Of what value is this analysis to choosing the right bolt set-up for this guy's radius rods? Probably none, but I thought it was interesting.
  30. thought the same
