Technical Need help decoding a small block Chevy engine
Discussion in 'The Hokey Ass Message Board' started by Jamoke, Sep 29, 2020.
  1. Jamoke
    Jamoke
    In the back of the engine it does say 5.7 but when I look up the number that's on the head it says the heads are from a 305 and here is a photo of the pad on the passenger side if you can help me decode this it would be great want to see if it's worth building this engine 20200929_122030.jpg
  2. S10_37
    S10_37
  3. Bob Lowry
    Bob Lowry
    Look at the driver's side, behind the head, on the bellhousing flange. If you want to know the year and month of
    production, look at the same place on the passenger's side.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
    305 heads have been put on 350's/5.7's many a time. Are the heads 416's?
  5. Mr48chev
    I'm not finding FPR in the regular go to sources for suffix codes. I have to go with S10-37 in that you need to start with the casting number of the block from the back left corner.
  6. Jamoke
    Jamoke
    Yes
  7. Jamoke
    Jamoke
  8. Jamoke
    Jamoke
    I'm really don't understand it this engine have a throttle body injection on it and it says the suffix code is a 1978 no TBI in 78
  9. J. A. Miller
    J. A. Miller
    from Central NY
    Paging @squirrel please pick up the white courtesy phone.
    Deuces and lothiandon1940 like this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
  11. Mr48chev
    Suffix code orange sbc (2).jpg Where are you finding any FPR suffix code? unless my eyes are seeing it wrong.
    I even found one source I have never seen before http://mkmann.com/pdf/SBBlockID.pdf
    That shows the codes by year and it isn't there.
    Now what is the casting number off the back of the block?
  12. Jamoke
    Jamoke
  13. Jamoke
    Jamoke
  14. Mr48chev
  15. Jamoke
    Jamoke
  16. Mr48chev
    What I can find is that the engine was assembled in flint Michigan on July 2. What year I don't know but that would come with the date code on the block plus the casting number will give the bore size and an approximate year. I've pretty well blown the last hour on this, have been on more sites that have suffix codes than you can count and none as I said before show an FPR code at all for any engine.
    https://www.speedwaymotors.com/the-toolbox/small-block-chevy-engine-codes/28660
    http://casting.brianesser.com/engine-codes-2/small-block-chevrolet-engine-suffix-codes/
    This is the normal small block Chevy go to suffix code source
    https://nastyz28.com/decode.php
  17. Black Panther
    Black Panther
    from SoCal
    The assembly code is FPR...I couldn't find it anywhere either. The stuff stamped underneath might be a partial vin. Can't tell. Its a later 70s engine at the earliest because of the short pad for the assembly info. I think they switched to the short pad about 1977 give or take a year or two..
  18. Jamoke
    Jamoke
    Thank you so much for your hard work trying to find this I have a feeling that somebody put a lot of stuff from different engines on this block I also think it's a waste of money for me to build this I understand the 305 heads from small combustion chamber but they do not flow worth a shit
  19. flatheadpete
    flatheadpete
    from Burton, MI
    ...One of the better things from Flint...days gone by.
  20. Jamoke
    Jamoke
    And also these are center bolt heads throttle body injection with 5.7 on the back of the engine
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Those are not 416 305 heads.
  22. Jamoke
    Jamoke
    1986-91 14101081 305 1.84 1.5001 - junk cylinder head for high performance
  23. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Your the one who agreed that they were 416's earlier is my only point.
  24. Jamoke
    Jamoke
    Sorry about the misunderstanding
  25. egads
    egads
    FPR --truck 1987 350 160 hp manual
  26. squirrel
    partial VIN says CH...... which means Chevy truck from 1987, so yeah, it looks like the post above this is the answer you're looking for
  27. mike in tucson
    mike in tucson
    from Tucson
    egads is correct
    federal emissions 1 ton according to the book
  28. Jamoke
    Jamoke
    That explains the non roller set up thank you everybody for the help
