Technical ***September 2020 Banger Meet Thread - Four Months of 2020 to go***
Discussion in 'Traditional Hot Rods' started by Jiminy, Sep 1, 2020.
  1. guitarguy
    guitarguy
    Haha, actually pretty light at 531 grams.
    7.5 to 1 with my T block, A crank and rods, and Fronty head.
    My wallet is empty, I feel like I just shook it upside-down going down the road. Can't wait to get the bill for the engine work. I'm sure it'll be worth it though.
  2. Reddy
    Reddy
    Savage Coupe
    Snyder's Antique Parts,
    Have the three carb finned intake manifold part number is A-945-tpl USA made for $235.00
    Mike
    Savage Coupe and winduptoy like this.
  3. Chad,
    That is very good, mine are about 570 but have no dome. They are a little thicker deck thickness, built around 13:1 CR.
    I am sure it will all be worth it in the end, keep at it, John
  4. Hey Fellas
    Haven't signed in in a couple years. Life, work etc...
    Anyway nice to be back. Still have my cars they just don't get driven as much
  5. Savage Coupe
    Savage Coupe
    from Washington
    Ordered one up, hopefully I won’t get an email next week saying they are no longer available. Thank you for the help!
    winduptoy likes this.
  6. Bearing Burner
    Bearing Burner
    from W. MA
    If your wallet is empty you need to find an additional job for your wife.
    Old Dawg, Outback, winduptoy and 4 others like this.
  7. railcarmover
    railcarmover
    'there's a hole in daddy's arm where all the money goes'
    Old Dawg, Outback and winduptoy like this.
  8. winduptoy
    winduptoy
    Welcome back....always liked your signature
    Tiny and Old Dawg like this.
  9. Love it, my dad drove truck recognized it right off.
    Old Dawg likes this.
  10. OK finally getting close. standard bore diamond B block with the bigger intake valves, winfield grind cam, Simmons power head, dual 81's and a Mallory distributor...... what spark plugs o_O
    Old Dawg, Star 351 and Jet96 like this.
  11. winduptoy
    winduptoy
    don't know the short answer don't even know the spark plug hole size
    Spark Plug Heat Ranges:
    The following list of 7/8-18 inch spark plugs fit the original Model A head. However, the results of the use of some of them could be detrimental to your engine or at the very least, foul out. In other words, just because a plug has the correct thread and length to screw into your Model A head does not mean it is the one you should use.
    A heat range test (discussed below) is the best way to determine the correct spark plug for a particular engine setup and a person’s driving habits. Champion plugs appear to be the brand most frequently used but that does not detract from the quality results of other brands.
    Champion recommends the W-18 to be the modern replacement for the 3X as their heat ranges are fairly close.
    Concerning the W16Y, according to Champion, the W16Y, being a projected nose plug, is hotter than the W18 or even a W20 at low speed but cooler at high speeds over 5500 RPM, which according to Champion, the high RPM is necessary to cool the projected nose with a rush of incoming cooler air even though there is greater combustion. Obviously, such high RPM will never apply to most Model A’ers. Regardless, however, most people report that the W16Y runs cooler than the W18 at ANY speed in a Model A.
    The performance of the W16Y in a Model A, as compared to Champion’s general description of its performance as a projected nose plug, appears to be an area of controversy for some Model A’ers. However, the Champion 7/8 plugs, including the W16Y, fit a variety of industrial and agricultural engines that run under all kinds of running conditions and loads and obviously Champion does not feel the need to make statements about how the W16Y specifically performs in many Model A’s.
    Consequently, if some Model A’ers make blanket statements based on the results of the W16Y’s cooler performance in many Model A’s it should be considered inaccurate as a blanket statement because the W16Y may not perform the same in other engine brands as well as some Model A’s. Plus, the results of Champion’s work would no doubt be determined under controlled conditions where the air/fuel ratio, spark intensity, etc., would be near perfect which is not the case for most Model A’s.
    So it's still best to use the following list as a general guide, but also do your own heat range tests and reach your own conclusions and opinions when running any of these plugs in a Model A engine.
    Champion (hotter down to colder):
    W89D
    W16Y (For Model A engines it ought to be somewhere between W18 and W14)
    W20
    W18 (About equal to the original 3X per Champion)
    W14
    W10
    Also the original 3X which Champion lists as normal along with the W18.
    Motorcraft (hotter down to colder):
    TT15 (the same as Champion W89D)
    TT10 (the same as Champion W14)
    TT8 (the same as Champion W14)
    TT4 (the same as Champion W10)
    Autolite:
    3076 (the same as Champion W14 and Motorcraft TT10)
    Mopar (hotter down to colder):
    P-9-7S
    P-9-6S
    P-9-5S
    Prestolite (hotter down to colder):
    78-10
    78-8
    Stitt (hotter down to colder):
    137 BSP
    197
    147 B
    13/10
    Larry Brumfield
    August 2016
    Jet96 likes this.
  12. brjnelson
    brjnelson
  13. V4F
    V4F
    from middle ca.
    i run NGK plugs
    Jet96 likes this.
  14. Gary in MN
    Gary in MN
    Northwood IA 2020 hill climb. Gary
  15. Guess I will run the 3X since I have them and see how the work out. Thanks
  16. Chopp'd49
    Chopp'd49
    It finally runs. .030 29 block. D4b Thomas style head. Equalizer dual intake. 2 stromberg 81’s. Reds header. SOS front cover and pulley. VW points distributor. A5BC9DC8-618B-4AD8-9812-7F4AEA1D201A.jpeg
  17. winduptoy
    winduptoy
    Good looking car...is that why the Vdub is parked, you need a dizzy for it?
  18. Chopp'd49
    Chopp'd49
    Nope - That is the Daughters graduation present. It runs great!
  19. Mikko_
    Mikko_
    from Sweden
    Got my new FSI distributor in the mail today, looking forward to installing it.
  20. railcarmover
    railcarmover
    Vw's and model A's?
    winduptoy and Old Dawg like this.
  21. What is the torque in a hot flathead banger? 30lb?
  22. brjnelson
    brjnelson
    As in engine output torque?? my car was just on a chassis dyno and got 141 foot pounds of torque. Winfield redhead dual 81, 226 inch stroker
    winduptoy, Stovebolt and guitarguy like this.
  23. brjnelson
    brjnelson
    winduptoy, Jet96 and railcarmover like this.
  24. wheeltramp brian
    wheeltramp brian
    Dang that's great numbers!wonder what stock output is .ive heard 40 horse but nothing on torque
  25. V4F
    V4F
    from middle ca.
    i would think more like 45 # ............. mine are @ 55 - 60 ##
  26. guitarguy
    guitarguy
    Anyone have a stock Model A oil pan dip tray they want to give up and ship to me? Need to build a setup for my A crank T engine.
  27. There's a guy selling two A engines near Ashland Ohio for $200. They would be good parts engines... one was converted to an air compressor. https://www.facebook.com/marketplace/item/554851285233853/
    Sent from my SM-N960U using The H.A.M.B. mobile app
  28. guitarguy
    guitarguy
    That's a good price, but I don't have any use for an entire engine, I just need the dip tray in the oil pan.....plus that's pretty far away.
    Sent from my thinks it's smarter than me smart phone using The H.A.M.B. mobile app
    Leon Sandcastle likes this.
  29. I shouldn't post during happy hour LOL
    I am looking for the amount to torque the piston rod nuts. I guess the mains as well.
    Jim
  30. brjnelson
    brjnelson
